100-400mm F4.5-5.6 VR S Nikon Nikkor Z zoom lens
    Features
    • Focal length at the maximum telephoto position becomes 560 mm with the Z TELECONVERTER TC-1.4x, and 800 mm with the Z TELECONVERTER TC-2.0x, while maintaining high resolution*1.
    • Multi-focusing system that utilizes two STMs (stepping motors), enabling fast, precise and quiet AF operation for both stills and videos.
    • Employs an optical vibration reduction function with an effect equivalent to a shutter speed 5.5 stops faster*2, which is the highest among NIKKOR Z lenses.
    • While lateral chromatic aberration is optically corrected, axial chromatic aberration is also significantly reduced via the adoption of Super ED glass and ED glass elements, providing clear images across the entire frame from maximum aperture.
    • Nikon's original Nano Crystal Coat and ARNEO Coat are both adopted to effectively reduce ghost and flare effects even in backlit situations.
    • The highest maximum reproduction ratio of 0.38x (at the maximum telephoto position) in its class*3 that lets users shoot subjects in large size.
    • Employs "Inner Balance Technology" --- a first for Nikon models, that reduces shifting of the center of gravity when zooming in from the wide-angle position to the telephoto position.
    • The shortest*3 rotation angle of 80 degrees in its class for the zoom ring enables users to rotate the zoom ring from the wide-angle position to the telephoto position in just one motion, without adjusting lens holding.
    • A smooth and quiet control ring that realizes high operability.
    • Features a design giving consideration to video recording, including effectively reduced shifting of a focus position when zooming in/out and the angle of view when adjusting focus.
    • Superior dust- and drip-resistant capability*4, high reliability that comes from both robustness and weather resistance, and excellent anti-fouling performance via the employment of fluorine coat are realized.
  • 3 Replies sorted by
  • MTF
    Scheme
    800 x 322 - 27K
    800 x 398 - 48K
  • I want to want this lens, but iI have never felt good about lenses that extend during zooming. I wish they would just make two versions with identical optics. One for those that care about a compact lens, and one for those that want a nearly dust proof lens with a bit more weather sealing and don't mind the additional length/a few more grams..
