Interview with Sony about this camera
Firmware v2.00, Benefits and Improvements
- Makes the Eye AF feature compatible with animals when recording a movie
 - Fixes an issue where the Touch Shutter may not work
 - Improves the operational stability of the camera
https://www.sony.com/electronics/support/e-mount-body-zv-e-series/zv-e10/software/00272347
What all the above seem to have missed is that Sony has a number of good power zooms (with OIS) that can make use of the multi-speed zoom rocker on the ZV E10, and they are only APS-C lenses. You could use them in crop mode on big megapixel FF cameras, but crop mode just takes a slice of the sensor (or, worse, line skips). The ZV E10 oversamples its 4K from 6K. So, its 4K is better. And the FF fx3 and a7s iii do not have a crop mode. So, now multispeed power zooming like a camcorder, but with a relatively big sensor. Not possible before except using Sony's expensive cinema line (FS5, FS7, etc.).
Here is a test of the ZV E10 using the Sony PZ 18-200 lens (FOV equivalent in FF: 27-300). With (gentle) power zooms!
Oh, the one I use is white. There was no pink option.
Testing with the PZ E 18-105 G power zoom lens. this lens has much better OIS thna the PZ 18-200, but trickier power zoom.
