30mm F1.4 Irix Prime FF Lens
    • F1.4 ~ 16 aperture range
    • 11 rounded shape iris blades
    • Min focusing distance - 0,34m
    • 140 degrees rotation angle
    • Distance scale - metric and imperial
    • 86mm front filters
    • Weather sealing using 3 rubber o-rings
    • Dimensions (L x D)
      • Canon EF mount - 107 x 94 mm
      • Nikon F mount - 105 x 94 mm
      • Pentax K mount - 106 x 94 mm
    • Weight
      • Canon EF mount - 863g
      • Nikon F mount - 851g
      • Pentax K mount - 857g
    • Included accessories
      • Lens hood
      • Front lens cap
      • Rear lens cap
    PR
    The newest Irix 30mm f/1.4 lens is a product based on the 30mm Cine model, and therefore intended for the much more demanding film industry market. The entire optical structure of the lens is identical in both versions - the main emphasis here is on the vividness of the image. Of course, the photographic version has a completely different housing, while retaining the optical properties of the cine version.
    Main Features
    • Beautiful Bokeh
    • Fast f/1.4 Aperture
    • Rear focusing
    • Weather-sealed construction
    • Aperture control from the camera
    • Focus confirmation on the Camera
    • Compatible with PASM semi-automatic modes
    • Full record of exposure parameters in EXIF
    • 61,9 degree field of view
    • "Focus Lock" function
    • 140-degree rotation angle of the focus ring
    • Reinforced internal structure
    • 86mm filter mounting front thread
    • Mounts: Nikon F, Canon EF, Pentax K
    Optical properties
    The Irix 30mm F / 1.4 features a modern optical design that includes 3 ultra-low dispersion glass elements, 2 high reflectance glass elements and one aspherical lens. There are a total of 13 elements in 11 groups that provide sharp details, vivid colors and ultra-low distortion - 0.95%. However, what deserves special attention is the smoothness and “cine look” of the image it offers. The lens is designed to work with 35mm full frame sensors. It is worth emphasizing the use of a new, 11-blade design aperture with rounded edges, which ensures a pleasant and very vivid background blur. It works in the range of f/1.4 to f/16.
    DRAGONFLY Version - Characteristics
    The lens housing is a continuation of the Dragonfly manufacturing standard known from earlier Irix models (45mm and 150mm). It’s most important aspects are:
    • Reinforced internal structure based on metal elements
    • Scratch-resistant lens finish
    • Anti-slip focusing ring with special finish for easy operating
    • Engraved markings filled with UV-reactive paint
    • Sealings to protect against dust and water
    • Hardcase included
    Focusing Ring
    A special focusing ring with a characteristic shape has become a kind of hallmark of Irix 150mm and 45mm lenses. Many of our clients pay attention to the convenience it provides. The newest Irix 30mm is following same way. Special texturing and properly selected rubber material which covers it, allows for reliable and precise focusing. Dedicated emboss lets you to feel the ring’s position. This makes focusing even easier!
    The Focus Lock function is also a hallmark of Irix lenses - it allows you to lock the focusing ring in a specific position. It’s especially useful when you want to keep a specific distance to the photographed object (zone-focusing) or you want to keep perfect focus at infinity in landscape photography or astrophotography.
    Designed for any challenge
    Irix customers often use their lenses in extremely difficult conditions. Therefore, the construction of the Irix 30mm f/1.4 lens had to meet their needs. Only the best materials were used. The guarantee of operation in all conditions is ensured by a system of seals located in key places of the lens, and rear focusing - thanks to which the lens does not change its dimensions while focusing. These properties allow not only to work in difficult conditions, but also guarantee the cleanliness of the mirror chamber and the sensor of the camera you are using.
    Available mounts
    The Irix 30mm f / 1.4 lens will be available with Nikon F, Canon EF and Pentax K mounts.
    Price and availability
    The lens will be available for sale in October 2021, we will inform you about exact availability and pricing in a separate press release.
  • 3 Replies sorted by
    800 x 526 - 54K
    800 x 534 - 45K
    650 x 681 - 69K
