135mm F2.5 APO Mitakon Zhong Yi Optics Affordable Portraits Lens
    • 9 Elements in 7 Groups
    • Min Distance - 1m
    • 67mm Filters
    • Available for Canon EF, Canon RF, Nikon F, Nikon Z, Sony FE
    • 79mm x 137mm
    • 845g
    • $299
    PR
    Zhong Yi Optics, the leading wide-aperture lenses manufacturer in China, has rebuilt their old 135mm f/2.8 lens into 135mm f/2.5, available in Canon EF, Canon RF, Nikon F, Nikon Z, and Sony FE mounts. The new 135mm lens benefits working in difficult lighting, also offering great control of depth of field. The lens is composed of high-quality ultra-low dispersion elements that form ultra-sharp images with minimal chromatic aberration. Well-built with metallic housing, the focus throw is comparatively long to give accurate focus control.
    Buttery Smooth Bokeh
    Mitakon Creator 135mm f/2.5 renders an exquisite bokeh by 9 blades of circular aperture. The background is softly blended like butter. Great control of depth of field can be achieved with focus technique, offering high level of creative potential with the lens. The perfect separation of subject from the background makes the lens ideal for portrait photography.
    Premium Image Quality – Ultra Sharp, No Vignette
    Zhong Yi has improved the optical design of Mitakon Creator 135mm f/2.5 lens based on experience of producing 135mm lenses. 2 Super ED (extra-low dispersion) glass and 2 ultra-high refraction Index glass elements are precisely deployed to provide optimal sharpness. Images taken by it are showing sharp details even across the corners, with minimal field curvature to ensure the highest possible resolution is retained along edges of the area in frame.
    Apochromatic (APO) Lens
    Super ED and ultra-high refraction Index glasses incorporated the design of Creator 135 f/2.5 lens help achieved the APO quality. Chromatic aberration is well suppressed to the slightest. No more distracting color fringing is found along areas with highlighting parts over the image. A perfectly colored, extraordinarily sharp portrait image with beautiful bokeh is achievable under strong lighting with this lens.
    Premium Built Quality with Retractable Hood
    Clear scale marking on the aperture ring and focus ring are embedded on the robust metal barrel. A long focus throw enables precise focusing on target objects. The Lens hood is designed to be longer than it used to, helping to reduce lens flare and ghosting.
    Internal Focusing and No Focus Breathing
    The new 135mm has an internal focus design, on which no extension/retraction on the lens housing when adjusting the focus ring. Filters, matt boxes, or other camera accessories can be mounted on it solidly. Focus breathing is designed to be minimal that the transition of shifting area in focus will be silky smooth.
    Pricing and availability
    The new Mitakon Speedmaster 135mm f/2.5 lens is available now on our official website (https://zyoptics.net/) and other authorized resellers. The US retail price is $299
  • 7 Replies sorted by
  • Scheme and MTF
    715 x 324 - 21K
    780 x 334 - 49K
  • Looks almost as good as my $10 Rokkor :)
  • But first image of white car hood you see clear fringing .not sure it could be my eye .if it’s apo than this should be much more less at least wide open
  • Nice ! Hope they are making an affordable APO line .mainly a 50 and 85mm possibly F1.8 or 2
  • Nice bokeh, doesn't look that sharp but hard to tell from the samples.
    800 x 534 - 66K
    800 x 524 - 39K
