Lumix G9 firmware reverse engineering
  • 28 Replies sorted by
  • @mee Did you try the service menu? On mine I could change almost all settings with the service menu, including pal/ntsc and remove the time limit. I'm not referring to the menu but the service menu.
  • DrDave sorry, I was sleep deprived for both of those posts, and in the second sorta forgot this started from G9 question. I am not sure what you mean by service menu, but are you referring to G9 or G7?
  • Never mind.
