14mm F1.8 Sony GM Lens
  • 20 Replies sorted by
  • NiSi Filters Japan released SONY FE 14mm F1.8 GM Holder, a square filter holder exclusively for Sony's E-mount ultra-wide-angle single focus lens FE 14mm F1.8 GM.
    You can mount two 100 mm wide square filters.
    The holder frame supports 360-degree rotation.
    715 x 609 - 46K
    694 x 572 - 40K
  • @markr041 Yes I know it but I film essentially underwater and the lack of a native fisheye lens is a big drawback for Sony. Owners of the adapter you mentioned reports a poor IQ. Keep in mind that underwater you have to find a good port solution for it. The most common solution for fisheye uw is the combo Canon 8-15mm + Metabones and some port extension and a huge 230mm glass dome. For apsc format Tokina 10-17 is one of the most common lens used underwater. While on land shooting is a mediocre lens, underwater is simply amazing. Go figure!
  • Still no sign of a native fisheye lens from Sony
    726 x 772 - 63K
    768 x 646 - 56K
  • PR
    Sony further expands its E-mount lens lineup with the introduction of the FE 14mm F1.8 GM (model SEL14F18GM) – a compact, large F1.8 aperture, ultra-wide angle lens that allows users to capture the world with new perspectives, especially when shooting landscapes, architecture, starry skies and interiors.
    “The newest member of Sony’s G Master series, the FE 14mm F1.8 GM, delivers extraordinary resolution, fast and quiet autofocus and is remarkably compact, “said Yann Salmon Legagneur, Director of Product Marketing, Digital Imaging, Sony Europe. “We are constantly innovating based on the needs of our customers and will continue to develop the best technology so that they can realise their creative vision.”
    Extraordinary Resolution in a Compact and Lightweight Design
    The new FE 14mm F1.8 GM features a compact optical design, measuring just 3⅜ in x 4 in and weighing just 16.3 oz, with advanced optical technology that delivers superb resolution and stunning contrast. Two XA (extreme aspherical) elements maintain excellent resolution throughout the image area even at corners, which enables its compact and lightweight design. Two ED (Extra-low Dispersion) glass element and one Super ED glass element result in optical refinements that suppress chromatic aberration and deliver excellent contrast and precise rendering at all apertures.
    Users can faithfully render light point sources thanks to a maximum aperture of F1.8, making it possible to capture astrophotography or shoot in other low-light environments without having to use extremely slow shutter speeds. When shooting in challenging lighting conditions, Sony’s original Nano AR Coating II technology maximises clarity by subduing flare and ghosting.
    The FE 14mm F1.8 GM can produce beautiful bokeh at F1.8, even with the ultra-wide 14mm focal length. With a 9.8-inch minimum focus distance, the FE 14mm F1.8 GM offers expanded possibilities for close-up still and video shooting and creates stunning bokeh known to Sony’s G Master premium series of lenses. In addition, its precise XA elements, a 9-blade circular aperture mechanism and optimally managed aberration allows the FE 14mm F1.8 GM to produce exquisite background bokeh without the undesirable onion-ring effect.
    Advanced and Quiet Autofocus
    Using two XD (extreme dynamic) Linear Motors, focus can be accurately acquired and maintained even when shooting with narrow depth of field at F1.8, giving professional shooters the reliability they need to get the job done in challenging conditions. Moreover, the FE 14mm F1.8 GM enables quiet AF with minimal vibration for smooth focus transitions, perfect for video content creation.
    Professional Level Control and Reliability
    The new lens also features several advanced and versatile control options including, a focus hold button, a focus mode switch and a focus ring to ensure smooth, efficient operation in a wide range of shooting environments. For added customisation, a number of functions can be assigned to the focus hold button from the camera body interface. The FE 14mm F1.8 GM also features Linear Response MF for direct and precise manual focusing. An aperture ring that allows intuitive aperture control is also included. For added creative freedom, the FE 14mm F1.8 GM includes a rear filter holder that accepts standard sheet-type filters for ND, colour correction, soft filter, etc.
    A dust and moisture resistant design[i] provides the reliability needed for challenging conditions. The front lens element features a fluorine coating that repels water, oil, and other contaminants. The rear element is also fluorine coated to keep that surface clean when changing the rear filter. The lens also has a built-in petal hood that effectively blocks extraneous light that can cause flare and ghosting.
    Pricing and Availability
    The new FE 14mm F1.8 GM will be available in May 2021 at a variety of Sony’s authorised dealers, for an estimated retail price of €1,600 EUROS.
    For detailed product information on the lenses, please visit: https://www.sony.co.uk/electronics/camera-lenses/sel14f18gm
  • Price - 1600€
    Record MTF
