25-50mm F1.7 Leica DG Micro Four Thirds Lens
    The new interchangeable lens will be added to expand the G Series lineup, and the LEICA DG 25-50mm F1.7 is also under development. It covers from 10mm to 50mm (35mm camera equivalent:20-100mm) together with the LEICA DG VARIO-SUMMILUX 10-25mm / F1.7 ASPH. (H-X1025) which is currently available and has been met with high acclaim. These two lenses have common aperture, high descriptive performance, shape and operability so that it is easy to make the creator’s own unique image product using these two lenses with minimal workflow.
    With this lens, Panasonic demonstrates its commitment to further providing maximum product value as a tool for users to unleash their creativity and challenge the ever-changing photo/video culture in the digital era.
  • 18 Replies sorted by
    698 x 448 - 47K
  • Panasonic is proud to introduce a new telephoto zoom digital interchangeable lens, the LEICA DG VARIO-SUMMILUX 25-50mm / F1.7 ASPH. (H-X2550), which boasts a large F1.7 aperture throughout the entire 50-100mm (35mm camera equivalent) zoom range with exceptionally high optical performance clearing the stringent LEICA standards. The LEICA DG VARIO-SUMMILUX 25-50mm / F1.7 ASPH. excels at both photo shooting and video recording, satisfying professional photographers and videographers alike.
    The new LEICA DG VARIO-SUMMILUX 25-50mm / F1.7 ASPH. (H-X2550) is been designed to be paired with with the LEICA DG VARIO-SUMMILUX 10-25mm / F1.7 ASPH. (H-X1025), a currently available lens which has been highly acclaimed by creators. They both feature the full-range F1.7 high-speed aperture that provides beautiful bokeh and high descriptiveness. The two lenses cover a focusing distance from wide angle to telephoto, functioning as eight fixed focal length lenses (20mm / 24mm / 28mm / 35mm / 50mm / 75mm / 85mm / 100mm, 35mm camera equivalent) providing the same or an even higher level of descriptiveness than a fixed focal length lens can offer. They have common aperture, high descriptive performance, shape and operability, enabling creators to produce their own unique image product using these two lenses with minimal workflow.
    Comprising 16 elements in 11 groups, the lens system features an aspherical lens and three Extra-low Dispersion (ED) lenses that effectively suppress the axial chromatic aberration and chromatic aberration of magnification. Spherical aberration and distortion are also corrected by the aspherical lenses for stunningly high resolution. The use of aspherical lenses and the optimum design of the lens system results in a compact size and light weight while still achieving outstanding optical performance.
    Compatibility with a maximum 240-fps high-speed sensor drive realizes high-speed, high-precision auto focusing. In addition to the silent operation achieved by the inner focus drive system, the stepless aperture ring and micro-step drive system in the aperture control section help the camera to smoothly catch up to brightness changes when zooming or panning. The optical design achieves exceptional barycentric stability to minimize image shifts during zooming. A focus ring is equipped for intuitive, precise focusing and linear/ non-linear setting can also be switched with this ring. The LEICA DG VARIO-SUMMILUX 25-50mm / F1.7 ASPH. also excels in video recording performance with a mechanism that suppresses focus breathing at entire zoom range.
    The LEICA DG VARIO-SUMMILUX 25-50mm / F1.7 ASPH. boasts minimum focusing distance of 0.28m (at wide end, 0.31m at tele end) and the maximum magnification ratio of 0.42x (35mm camera equivalent) for superior macro photography. The rugged dust/splash-resistant* design for high mobility withstands use under harsh conditions even in 10 degrees below zero. Filter diameter is in 77mm.
    The LEICA DG VARIO-SUMMILUX 25-50mm / F1.7 ASPH. (H-X2550) will be available at valued channel partners for $1,799.99 at the end of August.
    Dust and Splash Resistant does not guarantee that damage will not occur if this lens is subjected to direct contact with dust and water.
  • Looks like it got pushed back to late August: https://www.diyphotography.net/price-release-date-for-panasonic-25-50mm-f-1-7-leaked-by-amazon-ahead-of-announcement/
    Definitely will get this lens though, if it can stand up to the scrutiny of reviewers.
  • LEICA DG VARIO-SUMMILUX 20-50mm / F1.7 ASPH. H-X2550 lens is built for mirrorless Micro Four Thirds (MFT) mount cameras, enabling F1.7 aperture brightness throughout the entire 50-100mm (35mm camera equivalent) zoom range. Its exceptionally high optical performance is suitable for both professional photographers and videographers. Comprising 17 elements in 12 groups, the lens system features three aspherical lenses and four ED (Extra-low Dispersion) lenses that effectively suppress the axial chromatic aberration and chromatic aberration of magnification. Spherical aberration and distortion are also corrected by the aspherical lenses for stunningly high resolution. The use of aspherical lenses and the optimum design of the lens system results in a compact size and light weight. Compatibility with a maximum 240-fps high-speed sensor drive realizes high-speed, high-precision auto focusing. In addition to the silent operation achieved by the inner focus drive system, the stepless aperture ring and micro-step drive system in the aperture control section help the camera to smoothly catch up to brightness changes when zooming or panning. The optical design achieves exceptional barycentric stability to minimize image shifts during zooming. A focus ring is equipped for intuitive, precise focusing and linear/ non-linear setting can also be switched with this ring.
    Fun thing is that this specs differ from previous.
    679 x 662 - 51K
  • Specs
    • 16 elements in 11 groups (1 aspherical lens, 3 ED lenses, 1 UHR lens)
    • min focus distance is 0.28m at 25mm and 0.31m at 50mm
    • 77mm filters
    • φ87.6×127.6mm
    • 654g
  • Panasonic 25-50mm f/1.7 lens will be officially released next week
    794 x 569 - 61K
