Sony Airpeak S1 Drone Project
  • 13 Replies sorted by
  • Sony Electronics Inc announced their first-ever professional drone, the “Airpeak S1”[i]. An introductory model in the new Airpeak line, the S1 is the world’s smallest[ii] drone that can be equipped with a full-size mirrorless interchangeable-lens Alpha camera, opening up a new world of creative possibilities.
    The new drone utilizes a proprietary motor, propeller, control system and sensing technology, allowing it to fly at extremely high speeds with very stable wind resistance. Additionally, the Airpeak S1 features an advanced remote controller that can support the production of high-quality aerial images and freely control the aircraft. It also includes obstacle detection, automatic flight control via sensing and increased safety via cloud management of the aircraft and flight information.
    “Sony is excited to launch our new drone business with the Airpeak S1,” said Yang Cheng, Vice President, Imaging Solutions, Sony Electronics Inc. “Combining an extremely compact size with some of Sony’s most advanced imaging, sensing, AI and robotics technologies, the S1 will allow content creators, storytellers and commercial professionals to capture that which they’ve never been able to capture before.”
    Aircraft with Advanced Flight Performance
    The new Airpeak S1 offers dynamic flying capabilities, including a maximum speed of 55mph (90km/h)[iii], a maximum angular velocity of 180°/s[iv], and a maximum tilt angle of 55°[v].
    Propulsion technology using a combination of Sony developed key devices provides wind resistance in strong wind speeds up to 44.7mph[vi] (20m/s). An example can be viewed HERE.
    Independently developed propulsion device and flight control system
    In addition to the lightweight, highly efficient, sturdy and responsive proprietary 17″ propeller and brushless motor, the Airpeak S1 is equipped with an ESC (Electric Speed Controller) for optimal control of these components. A unique, high-performance flight control system integrates the propulsion device and all sensor information to ensure stable flight and high maneuverability.
    Stable Flight by Sensing
    Stereo cameras equipped with Sony’s image sensors are installed in 5 locations (front, back, left, right, bottom) of the aircraft. Sony’s Vision Sensing Processor, which processes camera data at high speed and with low power consumption, and proprietary algorithms are used to accurately estimate the aircraft’s spatial position and orientation in real time, enabling stable flight even in environments where GNSS (Global Navigation Satellite System) reception may be hindered, such as indoors or under bridges. The Airpeak S1 is also equipped with a unique high-performance flight control system that integrates all sensor information such as IMU (Inertial Measurement Unit), direction, barometric pressure and infrared ranging to optimize the propulsion device.
    The Airpeak S1 uses Multi-directional sensors to enable its obstacle braking function. The front, rear, left and right stereo cameras and the infrared range-finding sensor mounted on the top recognize obstacles in the vicinity of the aircraft, allowing the aircraft to automatically decelerate and stop according to the behavior of the aircraft and the surrounding conditions.
    Multiple Camera and Lens Variations
    Users have the flexibility to choose the right Alpha system for their desired application to expand their filmmaking horizons. The Airpeak S1 is compatible with a wide range of camera bodies including: the Alpha 7S series and FX3 for high descriptive capability with suppressed noise, the Alpha 7R series for ultra-high definition, and the Alpha 9 series and others for distortion-free images. The Alpha 1, which can shoot footage in 8K, is also compatible.
    Free Operability
    The new professional drone includes “Airpeak Flight,” an iOS® and iPadOS® compatible application[vii] that integrates the aircraft, transmitter, camera, and gimbal, allowing the operator to monitor status information such as flight distance and remaining battery power, and change various operations and settings on the screen.
    Airpeak S1 also includes a dual operation mode so that one user can operate the drone, while another user can operate the gimbal and camera simultaneously, all while checking the same image, even in complicated scenes. The FPV (First Person View) camera, which can be tilt-operated from the remote controller, is mounted on the nose of the aircraft and is useful for the operator to check the direction of the aircraft and the direction of travel.
    Highly Efficient Workflow with Automatic Flight
    The new drone includes “Airpeak Base,” a web application that allows the operator to manage equipment, create flight plans, and manage flight logs. In the equipment management, information on the equipment used is automatically listed and managed based on the flight log. This allows the operator to check the condition of the aircraft before going to the field, minimizing on-set issues.
    With Airpeak Base, the operator can create advanced flight plans and automatically fly the aircraft along the same course repeatedly, as if the drone were on rails installed in the air. It is able to set the position (latitude, longitude and altitude) and speed of the aircraft along the timeline, and specify the orientation of the gimbal and the timing of video or still image shooting. It can also draw smooth curves on the map. Reproduction flight is an automatic flight function that reproduces the flight route, gimbal, and camera movements based on the flight logs that have flown in the past.
    All aircraft information, including logs, can be uploaded to the cloud via the mobile app Airpeak Flight. Airpeak Base allows users to check the status of the aircraft and can provide notifications if necessary. Users can manage the status of all managed aircraft in one place before flight. Past flight logs can be viewed on the logbook screen, and details such as in-flight errors can also be reviewed.
    Related Services
    “Airpeak Plus,” a cloud service that allows users to use the rich features of Airpeak Base, and “Airpeak Protect Plan,” a service plan to cover accidental damage to the product, will be available to customers. Further details regarding both services will be available on the Airpeak website before the related products and services go on sale
    Pricing and Availability
    The new Airpeak S1 suggested retail price is approximately $9,000.00 and will ship with two (2) pairs of propellers, a remote controller, two (2) batteries and a battery charger. A third-party gimbal made specifically for the Airpeak S1 will be sold separately. The Airpeak S1 will be available for pre-order and ship to customers in the fall of 2021. Airpeak S1 is made in Japan.
    For more information, please visit: https://electronics.sony.com/airpeak
    Sony Group will be exhibiting Airpeak S1 at Japan Drone 2021, a drone exhibition to be held at Makuhari Messe in Chiba, Japan from June 14-16, 2021. In addition, Izumi Kawanishi, Senior Vice President, AI Robotics Business, Sony Group Corp. will provide the keynote speech in the morning of June 14, 2021.
    https://ssl.japan-drone.com/en_la/
  • So it is drone with lidar?
  • Price is $9000
    • With a max speed of 55.9mph (25m/s)1, maximum angular velocity of 180°/s2 and attitude angle up to 55°3
    • Sony developed propulsion device and flight control system
    • Flight time up to 22 minutes4 without a payload.
    • Stable in winds up to 44.7 mph (20m/s) 5
    • Landing gear with open/close legs to avoid appearing into images
    • Detachable propellers for fast easy replacement and transport
    • Sony developed stereo cameras and vision sensing processor with original algorithm for real time 3D spatial awareness
    • Achieves stable flight in enclosed spaces or when out of range of GNSS
    • Equipped with obstacle braking function by multi-directional sensing
    • The world's smallest drone in its class that can carry Alpha series full frame mirrorless cameras.6
    • RCR-VH1 remote controller operates the aircraft, gimbal, and camera while providing real-time image output.
    • Use with "Airpeak Flight" mobile app to control the aircraft, camera, and gimbal in-flight.
    • Dual Operation Mode for independent control of Aircraft and Gimbal/Camera.
    • Equipped with flexible flight modes
    • "Airpeak Base" web app for integrated management of flight plans, flight logs, and equipment
    https://electronics.sony.com/airpeak/p/arss1
  • Old design but if hover is stable in windy condition and if it can fly without drifting so It will be an Inspire 2 killer.
  • Site - https://www.sony.net/SonyInfo/airpeak/?j-short=airpeak
    PR
    Sony Corporation (“Sony”) today announced that it has launched a new project for drones in the field of AI robotics.
    The recent proliferation of drones has contributed greatly to the delivery of previously unseen images, as well as to workflow efficiency and energy savings in the industrial sector. Sony has assigned the "Airpeak" brand to reflect its aspiration to contribute to the further evolution and the creation of the unprecedented value through its imaging and sensing technology as well as 3R technologies (Reality, Real-time and Remote) in the drone area.
    Airpeak will support the creativity of video creators to the fullest extent possible, aiming to contribute to the further development of the entertainment industry as well as to improved efficiency and savings in various industries. Airpeak will also promote this project to enable drone-use with the highest level of safety and reliability in the environments where this has been difficult in the past.
    Sony will continue to post project-related information and obtain feedback from drone users through co-creation activities to prepare for the launch of the project in the spring of 2021.
    The company soon plans to begin seeking for the partners in the professional space who can collaborate on the project.
