War: Sakhalin and global warming scam
  • According to research by Professor, Doctor of Geographical Sciences A.M. Korotkikh (Pacific Institute of Geography, Far East Branch, Russian Academy of Sciences), about a million years ago Sakhalin was occupied by dark coniferous spruce - fir taiga and mixed forests with pine, oak, elm, hornbeam, beech, yew, magnolia, ginkgo and other thermophilic plants. The climate was subtropical. The average annual air temperature was about + 8C.
    Then, about 800 years ago, an intense cooling began. It lasted 250 thousand years. The western part of the island had been occupied by small-leaved alder-birch forests. Larch-birch forest-tundra has formed on the eastern coast. In the south of the island, sparse birch-larch forests appeared. The average air temperature in July did not exceed + 10C, in January it was -20-23C, and the average annual temperature dropped to -6 C. Permafrost appeared, spreading to the south of the island.
    Another warming began 550 thousand years ago. On the western coast of the island, coniferous-deciduous forests began to grow again with the participation of hornbeam, beech, hemlock. The climate was warm and humid: the average temperature of the year was + 6C, January to -6C, July to + 19C.
    This grace stretched for 250 thousand years until a new cold snap. It was very significant. The island was occupied by birch-larch forests, in the north with areas of forest-tundra and permafrost. The average annual air temperature dropped to -5C, in January to -23C, and in July - only to + 14C. the average annual sea water temperature has become 10-12 degrees lower than the present one.
    The paleotemperatures of sea water are determined by the presence of diatom shells in bottom sediments. These microscopic unicellular algae have bizarre siliceous (opal) shells resembling porous spheres with spiked rays or flat (feathery) formations, also with thorns. The colder sea water is, the more carbon dioxide is dissolved in it, which is necessary for diatoms to produce carbohydrates. They flourish both quantitatively and qualitatively - a variety of species.
    In the interval 230-200 thousand years ago, the climate again became warmer than the modern one. The average annual temperatures of the surface layer of sea water exceeded the modern ones by 2-3 C.
    The alternation of warm and cold periods continued, although there was no influence of human economic activity: there was no intake of carbon dioxide into the air, creating a "greenhouse effect," from thermal power plants and automobiles.
    200-130 thousand years ago, a new cold snap came to Sakhalin. The average annual temperature dropped to -5C, in January -30C, in July only + 12C. Surface sea water temperature dropped by 7C to subarctic conditions.
    After that, it warmed up to 95 thousand years ago: the average annual air temperature was + 5-6C, in January only -4C, in July - up to + 20C. The average annual sea water temperature was 13-15 C, which corresponds to the current temperature in the Sea of ​​Japan at 39-40 north latitude.
    The beginning of a new cold snap lowered the average annual temperature by ten degrees, amounting to -5C. In the north, the land was occupied by shrub-herbaceous plants (sedges, grasses), and from trees - larch, birch, alder, dwarf cedar. Tundra, forest-tundra, permafrost appeared.
    Intense warming began 10.5 thousand years ago. And although there were slight cold snaps, in general, the climate was established close to the modern one with an average annual air temperature in the south of the island of +2C.
    With an increase in the temperature of seawater, part of the carbon dioxide is released into the atmosphere, and with a decrease in the temperature of seawater, carbon dioxide, on the contrary, dissolves in water, with a decrease in its content in the air. It is not carbon dioxide that causes climate warming, but, on the contrary, climate warming leads to an increase in the content of CO2 in the atmosphere.
    Big repressions of scientific prostitutes can save the planet, this is for sure.
  • 10 Replies sorted by
  • Finally!
    Mitigating the measures caused by the climate crisis will require the allocation of the world community from $ 6 trillion to $ 10 trillion. Kristalina Georgieva, Managing Director of the International Monetary Fund (IMF), announced this on Friday, speaking at the online forum Reuters Next.
    We do not need billions, but trillions [dollars]. We estimate that $ 6 trillion to $ 10 trillion [needs to be spent] on mitigation measures [of the crisis] this decade,” she said, referring to the climate change crisis.
    At least they are honest finally.
  • A group of scientists from the Space Research Institute of the Russian Academy of Sciences published an article in the Journal of Geophysical Research: Space Physics, in which they reported a significant decrease in solar activity over the past 20 years. According to researchers, the flow of mass and energy in the solar wind has dropped by almost one and a half times compared to the end of the last century. This means that the danger of global warming has been replaced by the danger of a global cooling.
    Data on space weather in the vicinity of the Earth and on the intensity of the plasma flow from the Sun (solar wind) have been collected since the 60s of the last century. Such data is entered into the NASA OMNI catalog. The data were averaged both in terms of qualitative composition (the ratio of different particles and solar wind parameters) and quantitative analysis (magnetic field strength, particle velocity, etc.). Russian scientists have taken the trouble to study in detail the composition and energy of the solar wind for each point from the NASA OMNI catalog and have used all satellite observations for this since 1976. Thus, the cycles of solar activity from the 21st to the 24th inclusive were covered (the 25th 11-year cycle began in 2020).
    A detailed study of the composition and intensity of the solar wind showed that during the transition from cycle 22 to cycle 23, the mass and energy of the solar wind decreased below the historically recorded levels and did not rise any more in comparison with previous cycles of activity at similar intervals of the cycle. As before, the growth of the Sun's activity resumed in each new cycle after the year 2000, but at a lower level. The declining activity of the Sun has directly affected the weather on the planet.
    https://agupubs.onlinelibrary.wiley.com/doi/10.1029/2021JA029618
  • The amount of heat trapped by Earth’s land, ocean, and atmosphere doubled over the course of just 14 years, a new study shows.
    I propose to put authors of this words into jail for lifetime. Sorry, for double lifetime. Yes, authors of this shit - https://www.theverge.com/2021/6/18/22539924/earth-trapping-heat-climate-change-nasa
    To figure out how much heat the earth was trapping, researchers looked at NASA satellite measurements that tracked how much of the Sun’s energy was entering Earth’s atmosphere and how much was being bounced back into space. They compared this with data from NOAA buoys that tracked ocean temperatures — which gives them an idea of how much heat is getting absorbed into the ocean.
    At the exact same time according to orders of global institutions had been closed thousands of weather stations. Main reason - it is much harder to cheat and fake data and you have easy to compare data going many years back.
    https://agupubs.onlinelibrary.wiley.com/doi/10.1029/2021GL093047
    US and NASA are leading criminal in this new scam.
  • @Mistas
    You try to stand on some objective position and understand that is going on.
    While "global warming" scam is made by few huge sharks who want to continue ripping off all other countries.
    They just invented new "advanced" approach. As soon as they remove direct orders, sponsoring and scientific grants on this - you will be surprised how this whole theme will drop 50-100 times in popularity among scientists. And even more in any mass media.
  • Temperature impacts CO2 in the ocean, yes. But so does the amount of atmospheric CO2. As the amount in the air goes up (man-made or otherwise) so does absorption into the surface water, which is evidenced by ocean acidification. The ocean is currently a carbon sink because pH is going down, despite air temperatures being higher. Question is at what point does the ocean become supersaturated and unable to buffer some of the atmospheric CO2?
    I agree that the global warming we are experiencing has mostly natural causes (solar cycles, geologic time scale variation) but it's more and more challenging to not implicate at least some human contribution to this.
  • @Mistas
    Hmmm, so what is the explanation for ocean acidification going on right now which is reportedly a result of increased carbon in the water? If the oceans have a reduced capacity for carbon storage with higher temperature, then the pH should not be lowering.
    Can you elaborate on this? As it is little messy in my head.
    With change in water temperature changes amount of CO2 that can be dissolved in ocean. You can look at the scientific literature on this.
  • Hmmm, so what is the explanation for ocean acidification going on right now which is reportedly a result of increased carbon in the water? If the oceans have a reduced capacity for carbon storage with higher temperature, then the pH should not be lowering.
  • @BradMowrey
    We are still tiny, despite we are making lot of dirty mess.
    They did it first with Ozone http://www.personal-view.com/talks/discussion/19724/ozone-hoax-rises-again
    Mass media and prositute scientists literally bombed pure people with lies. Total economic consequences caused by shorter lifespan, destruction of perfectly good refrigerators is 1.5-2 trillion of dollars worldwide since 1990. Additional profits of big corporations are in hundreds of billions in same period.
    Take for example "horrible CO2", they never talk with you about its concentration in oceans and that happens as ocean temperatures fluctuate. They also never talk with you about forests and how their mass can be used for CO2 storage. As if you use trees for construction it is same as bury the tree deep into the swamp for 50-100 years, so it won't degrade and release CO2 back.
    Forests are not solution for capitalists as all land is owned by bunch of constantly fighting morons that do not want to give up even cent of their profits.
  • Agree this is long term cyclical. Current rise is different I think. Pollution of most rivers is a sign this time it is industrial capitalist activity run amok. I hope you are right and I am wrong.
  • Earth's temperature reached its highest level in three million years in 2020. This was stated by UN Secretary General Antonio Guterres.
    According to the politician, last year was a record for the number of climatic disasters and extreme weather conditions in various regions. “We are still heading for a catastrophic 2.4-degree rise in temperature by the end of the century,” the secretary general added.
    Read quote above and after this think a little.
    As UN Secretary General is clearly criminal and scammer.
