COVID: Aspirin also helps
  • Acetylsalicylic acid (aspirin) is commonly used for primary and secondary prevention of cardiovascular diseases. Aspirin use is associated with better outcomes among COVID‐19 positive patients. We hypothesized that aspirin use for primary cardiovascular disease prevention might have a protective effect on COVID‐19 susceptibility and disease duration. We conducted a retrospective population‐based cross‐sectional study, utilizing data from the Leumit Health Services database. The proportion of patients treated with aspirin was significantly lower among the COVID‐19‐positive group, as compared to the COVID‐19‐negative group (73 (11.03 %) vs. 1548 (15.77%); p=0.001). Aspirin use was associated with lower likelihood of COVID‐19 infection, as compared to non‐users (adjusted OR 0.71 (95% CI, 0.52 to 0.99; p=0.041). Aspirin users were older (68.06 ± 12.79 vs. 56.63 ± 12.28 years of age; p<0.001), presented a lower BMI (28.77±5.4 vs. 30.37±4.55; p<0.0189) and showed higher prevalence of hypertension (56, 76.71%), diabetes (47, 64.38%) and COPD (11, 15.07%) than showed the aspirin non‐users (151, 25.64%, p<0.001; 130, 22.07%, p<0.001; and 43, 7.3%, p=0.023, respectively). Moreover, COVID‐19 disease duration (considered as the time between the first positive and second negative COVID‐19 RT‐PCR test results) among aspirin users was significantly shorter, as compared to aspirin non‐users (19.8±7.8 vs. 21.9± 7.9 p= 0.045). Among hospitalized COVID‐positive patients, a higher proportion of surviving subjects were treated with aspirin (20, 19.05%), as opposed to 1 dead subject (14.29%), although this difference was not significant (p=0.449). In conclusion, we observed inverse association between the likelihood of COVID‐19 infection, disease duration and mortality and aspirin use for primary prevention.
    https://febs.onlinelibrary.wiley.com/doi/10.1111/febs.15784
  • 2 Replies sorted by
  • What is the dosage ?
  • @zcream
    As I understand it is normal cardio aspirin dosage, small.
