Canon Pro 8K Camera Coming
  • A Canon 8K camera with a Super 35mm imaging sensor is “in beta version” (we interpret this as undergoing field testing). These are the specifications:
    Rumored specs
    • 8K 3.2μm Super 35mm imaging sensor
    • High-Speed 3D
    • Dual Gain Output
    • Dual Pixel AF II
    • Dual Native ISO
    • DIGIC DV X (Faster AF, Faster I/O, Faster UI)
    • DCI 8K 60fps 12b RAW
    • 4K RGB (2-Green-pixel binning on sensor) 90fps 12b RAW Output
    Info via canowatch
  • 3 Replies sorted by
  • As a leading company in imaging technology, Canon is working to develop 8K solutions in anticipation of further advances in image expression. A compact, lightweight 8K camera that can be used in a variety of shooting styles. EF Cinema Lenses boasts an extensive lineup of wide-angle and telephoto lenses. 8K display with high brightness, high contrast, and high color gamut. The blending of four real 4K projectors enables a large screen projection of real 8K images. From input to output, the Canon 8K solution provides an unparalleled viewing experience
    800 x 458 - 60K
    800 x 495 - 46K
    800 x 412 - 46K
  • This will come with new lenses.
