Panasonic DC-BGH1 m43 Cine camera, stone on Z-CAM grave
  • 98 Replies sorted by
  • @endotoxic.....jaja....what future ? You're recommending purchasing a camera based on 'future upgrades" ? That's pretty thin. It has no ibis. This reminds me of the last cam pany released. Seems they're chasing old markets, instead of blazing new trails. I can't understand why it doesn't have ibis and 4k/120p. Appears to me pany probably thought these box cams are a good way to sell addons. See all those screw mounts. Thurs morning should be more interesting.
  • Future upgrades kurth
  • no 4k 120p ? Why would someone buy this over a gh5 ...other than wanting to look the part ?
  • ohhh boy, this is going to take so many canon c70 sales. yes it does not compare, i can buy 3 of them from the price of almost 1 c70 or rig completly 2 for price of c70, is vey atractivve and in about a year price will drop, and REMEMBER!!! BGGH2 VERSION AND BGGH3 VERSIONS OF THIS WILL COME!
    DONT FORGET this is sony starvis sensor and it does support 120fps in 4k on specs, quad bayer coding HDR many upgrades can be done even 14 bit of color or raw output. HACKING THIS CAMER so yea paired with Ai life recognition you have a really compeling camera specilly with speed booster.
    HUGE LENS LINEUP
    800 x 720 - 61K
    800 x 560 - 85K
  • Info from one dealer
    They stopped waiting for new Z-CAM stock, and will switch to selling this camera. :-)
  • English PR
    Panasonic is proud to announce the release of the its first box-style LUMIX Mirrorless Camera, DC-BGH1. Based on the Micro Four Thirds System, the new LUMIX BGH1 offers increased flexibility and access to an extensive lens lineup, bringing together technologies Panasonic has acquired though the development of professional cinema cameras, camcorders and the LUMIX GH series.
    With today’s increased demand for streaming in addition to traditional broadcasting, the LUMIX BGH1 provides a versatile solution in the form of an easy-to-use expandable camera that can be used in multi-camera, drone, IP remote control and live-streaming environments.
    The Panasonic LUMIX BGH1 will be available at RRP £1899.99 from mid-November 2020.
    Professional-level video quality achieved by high sensitivity and wide dynamic range
    The new LUMIX BGH1 integrates a 10.2-megapixel Live MOS Sensor with Dual Native ISO technology and a Venus Engine. Dual Native ISO technology seamlessly utilises two circuits to create two separate native ISO settings, which is used in Panasonic professional Varicam models. Normally, noise increases as sensitivity rises with a single native ISO image sensor, however, an image sensor with Dual Native ISO minimises noise generation by choosing an optimal circuit to use according to the sensitivity before gain processing. As a result, the BGH1 is capable of a maximum ISO 51200 high sensitivity recording.
    The LUMIX BGH1 enables 4:2:0 10-bit C4K/4K 60p / 50p internal video recording. It records video with a designated gamma curve compatible with ITU-R BT.2100, and you can now choose Hybrid Log Gamma (HLG) in Photo Style. A low-bit-rate recording mode C4K/4K HEVC/H.265 for HLG is also available.
    The V-Log L featuring log characteristics with 13 stops of wide dynamic range is pre-installed. It is also capable of C4K/4K 4:2:2 10-bit output via HDMI.
    The VFR (Variable Frame Rate) lets users record overcranked / undercranked video in C4K/4K (60 fps, maximum 2.5x slower in 24p) and FHD (240 fps, maximum 10x slower in 24p)*. The minimum frame rate for quick motion video is 2 fps.
    User convenience in film production and simple scalability with external devices
    The LUMIX BGH1 benefits from a new heat dispersion structure to achieve unlimited video recording. The body frame is composed of aluminum and magnesium alloy, making the camera both durable and lightweight.
    The LUMIX BGH1 is a compact box-style camera complying with Power over Ethernet+ (PoE+) protocols. Control over maximum of 12 LUMIX BGH1 cameras*1 is available using Panasonic PC software 'LUMIX Tether for Multicam'. With a future firmware update, it will also support wired IP streaming (RTP/RTSP).
    In addition to a USB 3.1 Type-C port, it is also equipped with a 3G-SDI and a HDMI Type-A terminal, which can be used for simultaneous output. Furthermore, Genlock IN and Timecode IN/OUT functions which enable multi-angle synchronised video recording are available, allowing the user to build a scalable system with external monitors, rigs and gimbals supplied from other manufacturers.
    The LUMIX BGH1 is equipped with a double SD Card slot for backup recording or relay recording.
    Other practical features
    • Supports anamorphic lenses (4:3)
    • Tally lamps (one front, one rear), as well as a network connection lamp
    • Φ3.5 Audio (in/out) jack compatible with XLR microphone DMW-XLR1 (sold separately)
    • Generic remote control unit φ2.5mm
    • 2.4GHz Wi-Fi connectivity and Bluetooth 4.2 (BLE)
    • Bundled accessories including a Cable lock band, AC adapter and AC cable
    • Remote camera control using application software (LUMIX Tether for Multicam*² and LUMIX Sync)
    • Tethered photo shooting with LUMIX Tether for Multicam*² software
    • A SDK*3 (Software Development Kit) for camera control via USB will be available free of charge.
  • @Sph1nxster Full NDI support seems unlikely since traditional NDI uses a proprietary codec that generally requires hardware support. NDI HX might be possible though as this is essentially just H.264 at the codec level.
    Panasonic already has NDI HX support in several of their recent camcorder releases such as the CX10 and CX350 (as well as in their PTZ cameras). It seems like this camera will be using Lumix firmware and menus more similar to the GH5S rather than the Panasonic camcorder firmware though. If they do add NDI HX support, it would almost certainly be a $300 add-on (as with their other cameras) due to the NewTek NDI license fees.
  • Sold at "Face / Eye Recognition AF". Shame it doesn't have a framing display like the Z-CAM... This body will eat into Z-CAM (which is collapsing anyway, because of the Huawei situation).
  • Really hope they develop a way to do NDI with this camera. That is the future for sure
  • Japanese description
    Customizability that flexibly responds to the needs of professional video production sites, from multi-cameras to conventional shooting styles
    LUMIX's first innovative box-style body is packed with the advanced video performance cultivated in the LUMIX GH series. By laying out a highly expandable interface for professional use on the body in order to support multi-camera shooting, which is becoming a trend, we support a wide range of professional video production sites in all directions. By linking with monitors, recorders, microphones, rigs, tripods, gimbals, drones, operating equipment, etc. made by other companies, we provide a high degree of customization according to user needs. We can handle a wide range of tasks, from compact one-man shooting to team-based shooting sites that require the operation of multiple units.
    Excellent video performance that inherits the genealogy of the GH series
    High-sensitivity image quality realized by 10.2M Live MOS sensor and dual native ISO technology The 10.2M Live MOS sensor with excellent high-sensitivity effective pixels realizes beautiful depiction even in low-light environments. In addition, it is equipped with "dual native ISO technology" that has two dedicated circuits for each pixel. When setting high ISO sensitivity, which amplifies noise, switching between "low ISO sensitivity circuit" and "low noise / high ISO sensitivity circuit" enables more natural and beautiful still image / video recording with reduced noise. I made it. The highest ISO sensitivity for regular use is ISO51200, and the extended ISO sensitivity is ISO204800, expanding the possibilities of shooting range.
    Full video recording mode such as Panasonic's Micro Four Thirds standard's first Cinema4K 60p 10bit video recording
    60p 10bit recording is realized in Cinema4K (4096 x 2160) mode. Even for fast-moving subjects, you can shoot natural and smooth images while suppressing the rolling shutter distortion phenomenon, and you can record high-definition and realistic videos. 10-bit recording, which has 64 times the amount of information as 8-bit recording, provides gradation and subtle nuances of gradation, increasing the degree of freedom in editing and grading. It has twice the color information and 128 times the amount of information as a whole compared to 8-bit recording. 4: 2: 2 10-bit recording can be internally recorded on an SD card, and ALL-Intra recording is also supported. High bit rate recording up to 400 Mbps supports advanced non-linear editing. The HDMI output can output 4: 2: 2 10bit 4K 60p video, and can record high quality 4K video to an external recorder. It also has a full range of video recording modes for professional video production sites, such as 4K anamorphic video recording that supports 4: 3 aspect anamorphic lenses.
    Unlimited recording time in all recording modes
    The heat dissipation structure equipped with a high-precision heat dissipation simulation and heat dissipation fan has realized unlimited recording time within the guaranteed operating temperature in all video recording modes. By enabling long-time shooting, we can meet the trust of a wide range of professional shooting sites, such as uncut shooting for over 30 minutes and documentary shooting.
    13-stop V-Log L with excellent highlight resistance
    This unit has a wide dynamic range of 13 stops with excellent highlight resistance. It draws finely from the dark part to the highlight part, enabling highly flexible color grading in video production editing. When shooting V-Log L, you can check the look at the finish with the V-Log view assist function that displays the image after applying the LUT on an external monitor. Also, in post-production, you can create consistent pictures by combining with the LUMIX G series that supports V-Log L, the Panasonic cinema camera VariCam that supports V-Log, and the movies shot with the full-size single-lens camera LUMIX S series. You can edit the video of.
    Video look that pursues unified picture creation with the cinema camera VariCam Cine-like D2 / V2
    It is cinema-like and impressive by utilizing the cinema-like gamma that reproduces the look that reflects the painting concept of Panasonic's cinema camera VariCam and S1H without log shooting or color grading in post production. You will be able to make pictures. You can select "Cine-like D2" that prioritizes dynamic range and "Cine-like V 2" that emphasizes contrast from photo styles.
    Real-time face recognition AF with improved tracking accuracy by supporting head recognition and strengthening the recognition function
    Real-time recognition AF with enhanced AF tracking performance for humans is installed by adding "head recognition" of the human body to the automatic recognition algorithm that applies deep learning, which is an advanced technology in the AI ​​field. Even in a moving subject or a scene where the face of a person is hidden, the camera automatically determines the shooting intention based on the position, size, and angle of view of the head and human body, and keeps focusing while suppressing background omission. "Face / Eye Recognition AF", which detects a person's face and eyes and automatically focuses on them, and "Head Recognition" make it possible to continue recognizing even small faces in the distance. The combination of enhanced "Human Body Recognition AF" and "Face / Eye Recognition AF" realizes more accurate AF tracking for people. It is also equipped with "Animal Recognition AF", so it demonstrates high focus performance for animals.
    Equipped with a double SD card slot
    Equipped with two SD card slots according to the shooting application. You can set "relay recording" to switch from the first to the second SD memory card when the capacity is full, "backup recording" to record simultaneously with two SD memory cards, etc., so you can shoot movies. You can select the most suitable recording method. The SD memory card is compatible with UHS-II Video Speed Class 90.
    Equipped with BNC terminals (3 units) and LAN terminals (PoE + compatible) for the first time as LUMIX
    Equipped with 3 BNC terminals, PoE + compatible LAN terminal, and HDMI terminal to control multiple cameras during multi-camera shooting and realize efficient operation.
    • BNC terminal: Supports 3G-SDI output, time code (TC IN / OUT), Genlock input 3G-SDI is capable of FHD 60p 4: 2: 2 10bit external output, in addition to long-distance cable routing You can also prevent the cable from coming off. HDMI is capable of 4K 60p 4: 2: 2 10bit external output. Since it also supports simultaneous output from HDMI and 3G-SDI, you can increase the degree of freedom in video recording and monitoring by using or using both 3G-SDI and HDMI terminals together. In addition, the time code (TC IN / OUT) automatically records information on hours, minutes, seconds, and the number of frames to support efficient video editing. Since the Genlock input matches the frame phase, it enables highly accurate synchronization, for example, when switching high-speed subjects with multiple cameras. By using the time code and Genlock input together, you can achieve advanced operations in multi-camera shooting.
    • LAN terminal: PoE + compatible, controlling multiple cameras from a PC If you connect to a PoE + (Power over Ethernet) compatible device, you can also supply power using a LAN cable.
    Multiple units (up to 12 units) can be controlled from one PC
    You can control the camera from your computer by connecting this unit to your computer using a hub and LAN cable. You can check the live view on your computer screen by installing the dedicated software "LUMIX Tether for Multicam" that will be released when this unit is released. You can also change settings such as the specified camera aperture, shutter speed, ISO sensitivity, and white balance, allowing you to make detailed settings smoothly when shooting with multiple cameras. It is also possible to perform the same control via a USB cable.
    • "VFR (Variable Frame Rate)" that can record smooth slow motion and crisp quick motion images
    • Additional assist functions convenient for movie shooting "Zebra pattern" "Spot brightness meter" "Brightness level setting" *"Anamorphic desk ease display" that allows you to check the finished image after shooting anamorphic *Remote shooting function by smartphone application "LUMIX Sync"
    • Easy pairing with a smartphone, "Bluetooth (R) 4.2" that can be connected to the camera at all times with energy saving
    • "Wi-Fi (R) 2.4 GHz" that allows wireless connection
    • "Low temperature resistant design" of -10 ° C that can be used even in cold regions *11 "screw holes (tripod mounting part)" that can be expanded by attaching rigs, cages, tripods, etc.
  • Photos
    744 x 691 - 52K
    725 x 623 - 46K
    800 x 597 - 41K
    796 x 731 - 57K
    742 x 610 - 48K
    773 x 771 - 68K
    716 x 519 - 38K
  • Filter... Organic one perhaps?
    Maybe this is Panasonic, doing a Sigma Fp meets Zcam E series thing while reaching out in as many directions as possible for intended user.
  • This camera is such an incredibly weird mash-up. So it has the GH5 codecs after all. It has studio (genlock/TC) interfaces but no broadcast codecs. Taking it to OB setups? No 12G-SDI means no UHD. And who runs multicore (SDI/Genlock/TC) in new installations in 2021?? It's all fiber now. Focusing with a LANC controller? In some aspects it's over-provisioned, in others it is decidedly non-pro.
    It will live and die by its price, and not because the broadcasters care about that (they don't, and won't touch it anyway). I think the target market can be gleaned from the battery type: it's the same battery as for the DVX-200! The codecs are in line with DVX-200 too. But this isn't a DVX with removable lens, because unless it's rigged, this camera is unusable. DVX was an all-around grab it and shoot something now camera, jack of all trades, master of none, but still a compelling package because of the built-in stabilized lens and half/ENG form factor. I don't know. The colors better be legendary straight out of this thing, so skipping post could be a selling point.
  • Interesting. The ethernet POE is a nice touch. Shame it doesn't so an NDI signal over that. Or does it?
  • Wireless
    • Wi-Fi: IEEE 802.11b/g/n, 2412 MHz - 2462 MHz (1-11 ch), Wi-Fi / WPA / WPA2, Infrastructure mode
    • Bluetooth: Bluetooth v4.2 (Bluetooth Low Energy (BLE))
    Power
    • Direct power supply
      • AC Adaptor (12V, 3A) (bundled)
      • Li-ion Battery Pack (7.28V) (sold separately)
      • PoE+ (IEEE802.3 compliant) (sold separately)
    • Battery
      • Li-ion Battery Pack AG-VBR59 (7.28V, 5900mAh, 43Wh) (sold separately)
      • Li-ion Battery Pack AG-VBR89 (7.28V, 8850mAh, 65Wh) (sold separately)
      • Li-ion Battery Pack AG-VBR118 (7.28V, 11800mAh, 86Wh) (sold separately)
    • Continuous recordable time (Motion picture)
      • MP4 [4K/60p]: Approx. 270 min, MP4 [FHD/60p]: Approx. 300 min *When using H-ES12060 and AG-VBR59 (sold separately). When the battery is fully charged.
      • MP4 [4K/60p]: Approx. 420 min, MP4 [FHD/60p]: Approx. 480 min *When using H-ES12060 and AG-VBR89 (sold separately). When the battery is fully charged.
      • MP4 [4K/60p]: Approx. 560 min, MP4 [FHD/60p]: Approx. 640 min *When using H-ES12060 and AG-VBR118 (sold separately). When the battery is fully charged.
    • Actual recordable time (Motion picture)
      • MP4 [4K/60p]: Approx. 135 min, MP4 [FHD/60p]: Approx. 150 min *When using H-ES12060 and AG-VBR59 (sold separately). When the battery is fully charged.
      • MP4 [4K/60p]: Approx. 210 min, MP4 [FHD/60p]: Approx. 240 min *When using H-ES12060 and AG-VBR89 (sold separately). When the battery is fully charged.
      • MP4 [4K/60p]: Approx. 280 min, MP4 [FHD/60p]: Approx. 320 min *When using H-ES12060 and AG-VBR118 (sold separately). When the battery is fully charged.
    Dimensions and Weight
    • Dimensions (W x H x D): Approx. 93.0 x 93.0 x 78.0 mm (excluding protrusions)
    • Weight: Approx. 545g (Body only)
  • Interface
    • USB: SuperSpeed USB 3.1 Gen1 Type-C
    • DC IN: DC 12V (11.4-12.6V), EIAJ Type4
    • HDMI
      • HDMI: HDMI Type A
      • Audio: Stereo
      • Monitor-through:
      • 4:2:2 10bit (When [Rec Quality] is set to [4:2:2 10bit] or [4:2:0 10bit].)
      • 4:2:2 8bit (When [Rec Quality] is set to [4:2:0 8bit].)
      • Down Convert: Auto / 4K/30p/25p / 1080p / 1080i / OFF
      • Playback
      • 59.94Hz: Auto / C4K/59.94p / C4K/29.97p / C4K/23.98p / 4K/59.94p / 4K/29.97p / 4K/23.98p / 1080/59.94p / 1080/29.97p / 1080/23.98p / 1080/59.94i / 720/59.94p / 480/59.94p
      • 50.00Hz: Auto / C4K/50.00p / C4K/25.00p / 4K/50.00p / 4K/25.00p / 1080/50.00p / 1080/25.00p / 1080/50.00i / 720/50.00p / 576/50.00p
      • 24.00Hz: Auto / C4K/24.00p / 4K/24.00p / 1080/24.00p
    • SDI
      • SDI: BNC Terminal, 0.8V [p-p], 75Ω, 3G-SDI
      • Audio: Stereo, SDI Sound Output Gain Adj.: 0dB / -6dB / -8dB
      • Monitor-through: 4:2:2 10bit
      • Playback
      • 59.94Hz: 1080/59.94p / 1080/29.97p / 1080/23.98p / 1080/59.94i / 1080/29.97PsF / 1080/23.98PsF / 720/59.94p
      • 50.00Hz: 1080/50.00p / 1080/25.00p / 1080/50.00i / 1080/25.00PsF / 720/50.00p
      • 24.00Hz: 1080/24.00PsF
    • Ethernet
      • Remote Control: LAN Terminal (RJ-45)
      • Power Supply: PoE+ (IEEE802.3 compliant)
    • Remote input: φ2.5mm
    • Microphone: Stereo, Wind Noise Canceller: OFF / Low* / Standard / High *When attaching DMW-MS2 (sold separately).
    • External microphone / external audio device input:
      • φ3.5mm for external microphone / external audio device
      • MIC (Plug-in Power) / MIC / LINE is selectable.
      • Stereo/Lens Auto/Shotgun/Super Shotgun/Manual is selectable when attaching DMW-MS2 (sold separately).
    • XLR microphone: Yes with DMW-XLR1 (sold separately)
    • Headphone output: φ3.5mm
    • SD card slot: Slot 1, Slot 2
    • TC IN/OUT
      • Count up: Rec Run / Free Run
      • Time code mode: Drop Frame / Non-Drop Frame (When system frequency [59.94Hz] is selected.)
      • HDMI time code output: ON / OFF
      • SDI time code output: ON / OFF
      • External TC setting: TC Synchronization / TC Output Reference
    • Genlock IN
      • Genlock IN: ON / OFF
      • Horizontal phase synchronization: -206 - +49
    • Fan: Auto1 / Auto2 / Normal / Slow
    • Lamp: Tally Lamp (front/rear) / Card Access Lamp / Power LED / Network LED
  • Other Functions
    • Master pedestal level: 31 steps
    • Luminance level:
      • 8-bit: 0-255 / 16-235 / 16-255
      • 10-bit: 0‒1023 / 64‒940 / 64‒1023
    • LUT view assist: Rec / Playback: HDMI / SDI
    • HLG view assist: Rec / Playback: HDMI (AUTO / MODE1 / MODE2 / OFF) / SDI (MODE1 / MODE2 / OFF)
    • Anamorphic desqueeze display:
      • 2.0x / 1.8x / 1.5x / 1.33x / 1.30x / OFF
      • Rec: SDI
      • Playback: HDMI / SDI
      • Synchro scan: Yes
    • SS/Gain operation: Shutter Duration/ISO / Angle/ISO / Shutter Duration/dB
    • Color bars / 1kHz test tone: Yes (SMPTE / EBU / ARIB) / Yes
    • Knee control: Yes (in Like709 mode)
    • Level Gauge: Yes
    Function Button
    • REC: Exposure Mode / Aperture Value / Shutter Speed / Exposure Comp. / Dual Native ISO Setting / Sensitivity / White Balance / Photo Style / Metering Mode / i.Dynamic Range / Filter Effect / One Push AE / Synchro Scan / Focus Mode / AF Mode / AF Custom Setting (Video) / Focus Peaking / Focus Peaking Sensitivity / 1-Area AF Moving Speed / Focus Ring Lock / AE LOCK / AF LOCK / AF/AE LOCK / AF-ON / AF-ON: Near Shift / AF-ON: Far Shift / Focus Area Set / Rec File Format / Rec Quality / Rec Quality (My List) / Variable Frame Rate / Time Code Display / Sound Rec Level Disp. / Mute Sound Input / Sound Rec Level Adj. / Sound Rec Level Limiter / XLR Mic Adaptor Setting / Special Mic. Directivity Adjust / Image Stabilizer / E-Stabilization (Video) / Image Area of Video / Digital Zoom / Focus Transition / Live Cropping / Q.MENU / Rec/Playback Switch / Video Record / Cursor Button Lock / DISP. / Level Gauge / Histogram / Luminance Spot Meter / Frame Marker / Monochrome Live View / Zebra Pattern / LUT View Assist (HDMI) / LUT View Assist (SDI) / LUT Select / HLG View Assist (HDMI) / HLG View Assist (SDI) / Anamorphic Desqueeze Display / Color Bars / Zoom Control / Step Zoom / Zoom Speed / Destination Card Slot / LAN/Wi-Fi / Info Display (HDMI/SDI) / Fan Mode / No Setting / Off (Disable Press and Hold) / Restore to Default
    • Play: Anamorphic Desqueeze Display / Delete Single / Protect / Rating 1, 2, 3, 4, 5 / Copy / Rec/Playback Switch / Video Record / DISP. / Card Slot Change / Wi-Fi / Info Display (HDMI/SDI) / Fan Mode / LUT View Assist (HDMI) / LUT View Assist (SDI) / HLG View Assist (HDMI) / HLG View Assist (SDI) / No Setting / Off (Disable Press and Hold) / Restore to Default
  • Dual Native ISO
    • [Normal]
      • Native ISO: 160, 800
      • Auto: Auto / 80* / 100* / 160-51200 / 102400* / 204800* *Extended ISO
      • Low: Auto / 80* / 100* / 160-800 *Extended ISO
      • High: Auto / 800-51200 / 102400* / 204800* *Extended ISO
    • [V-Log L]
      • Native ISO: 400, 2000
      • Auto: Auto / 400-25600
      • Low: Auto / 400-2000
      • High: Auto / 2000-25600
    • [HLG]
      • Native ISO: 320, 1600
      • Auto: Auto / 320-51200 / 102400* / 204800* *Extended ISO
      • Low: Auto / 320-1600
      • High: Auto / 1600-51200 / 102400* / 204800* *Extended ISO
    • [Cinelike D2 / Cinelike V2]
    • Exposure compensation:
      • Motion picture: 1/3 EV step ±3EV
      • Still image: 1/3 EV step ±5EV
    • AE lock: Set the Fn button in custom menu to AE lock
    White Balance
    • White balance: AWB / AWBc / AWBw / Daylight / Cloudy / Shade / Incandescent / White Set 1, 2, 3, 4 / Color temperature setting 1, 2, 3, 4
    • White balance adjustment: Blue/Amber bias, Magenta/Green bias
    • Color temperature setting: 2500-10000K in 100K
    Shutter
    • Shutter speed:
      • Motion picture: 1/16,000 - 1/2
      • Still image: 1/16,000 - 1 *Only the PTP command using the software LUMIX Tether for still image shooting.
    Photo Style
    • Photo style:
      • Motion picture: Standard / Vivid / Natural / Landscape / Portrait / Monochrome / L. Monochrome / L. Monochrome D / Cinelike D2 / Cinelike V2 / Like709 / V-Log L / Hybrid Log Gamma / My Photo Style 1-10
      • Still image: Standard *Only the PTP command using the software LUMIX Tether for still image shooting.
      • Picture adjustment: Contrast / Highlight / Shadow / Saturation / Color Tone / Hue / Filter Effect / Sharpness / Noise Reduction / Dual Native ISO Setting / ISO / WB
  • Focus
    • Type: Contrast AF system
    • DFD technology: Yes
    • Focus mode: AF / MF
    • AF mode: Motion picture: Auto Detection (Face, Eye, Body, Animal) / 225-Area / Zone (Oval) / 1-Area
    • Still image: Auto Detection (Face, Eye, Body, Animal) / 225-Area /1-Area
    • AF detection range: EV -6 - 20 (F1.4, ISO100 equivalent, AF (Still image))
    • AF custom setting (Motion picture): AF Speed, AF Sensitivity
    • AF lock: Set the Fn button in custom menu to AF lock
    • Others: AF-ON, Continuous AF, AF+MF, MF Guide, MF Assist, Focus Peaking, Focus Ring Lock, 1-Area AF Moving Speed, Lens Focus Resume
    Exposure Control
    • Light metering system: 1,728-zone multi-pattern sensing system
    • Light metering mode: Multiple / Center Weighted / Spot / Highlight Weighted
    • Metering range: EV0-18 (F2.0 lens, ISO100 equivalent)
    • Exposure mode: Program AE / Aperture Priority AE / Shutter Priority AE / Manual Exposure
    • ISO sensitivity (Standard output sensitivity): Auto / 80* / 100* / 160 / 200 / 400 / 800 / 1600 / 3200 / 6400 / 12800 / 25600 / 51200 / 102400* / 204800* (Changeable to 1/3 EV step) *Extended ISO
  • Specs
    Type
    • Type: Digital Single Lens Mirrorless camera
    • Recording media: SD Memory Card / SDHC Memory Card / SDXC Memory Card (Compatible with UHS-I/UHS-II UHS Speed Class 3 standard SDHC/SDXC Memory Cards and UHS-II Video Speed Class 90 standard SDXC Memory Cards.)
    • Lens mount: Micro Four Thirds mount
    Image Sensor
    • Type: Live MOS sensor
    • Camera effective pixels / total pixels: 10.28 megapixels / 11.93 megapixels
    • Aspect ratio / Color filter: 4:3 / Primary color filter
    • Latitude: 13 stops (V-Log L)
    Still Image
    • Recording file format: JPEG (DCF, Exif 2.31)
    • Aspect ratio: 4:3
    • File size (Pixels): 3680x2760(L) / 2592x1944(M) / 1824x1368(S)
    • Image quality: Fine / Standard
    • Color space: sRGB
    • MOV: H.264/MPEG-4 AVC, H.265/HEVC (Audio format: LPCM (2ch 48kHz/16-bit, 48kHz/24-bit*, 96kHz/24-bit*)) *When attaching DMW-XLR1 (sold separately).
    • MP4: H.264/MPEG-4 AVC, H.265/HEVC (Audio format: AAC (2ch))
    • System frequency: 59.94Hz / 50.00Hz / 24.00Hz
    MOV
    • 59.94Hz
      • [C4K] 4096x2160
        • 59.94p, 200Mbps (4:2:0 10-bit LongGOP) (H.265/HEVC, LPCM, High-Res Audio)
        • 59.94p, 150Mbps (4:2:0 8-bit LongGOP) (H.264/MPEG-4 AVC, LPCM, High-Res Audio)
        • 29.97p, 400Mbps (4:2:2 10-bit ALL-Intra)/ 150Mbps (4:2:2 10-bit LongGOP) / 100Mbps (4:2:0 8-bit LongGOP) (H.264/MPEG-4 AVC, LPCM, High-Res Audio)
        • 23.98p, 400Mbps (4:2:2 10-bit ALL-Intra) / 150Mbps (4:2:2 10-bit LongGOP) / 100Mbps (4:2:0 8-bit LongGOP) (H.264/MPEG-4 AVC, LPCM, High-Res Audio)
      • [4K] 3840x2160
        • 29.97p, 400Mbps (4:2:2 10-bit ALL-Intra) / 150Mbps (4:2:2 10-bit LongGOP) / 100Mbps (4:2:0 8-bit LongGOP) (H.264/MPEG-4 AVC, LPCM, High-Res Audio)
      • [Anamorphic 4K] 3328x2496 (4:3)
      • [FHD] 1920x1080
        • 59.94p, 200Mbps (4:2:2 10-bit ALL-Intra) / 100Mbps (4:2:2 10-bit LongGOP) / 100Mbps (4:2:0 8-bit LongGOP) (H.264/MPEG-4 AVC, LPCM, High-Res Audio)
        • 29.97p, 200Mbps (4:2:2 10-bit ALL-Intra) / 100Mbps (4:2:2 10-bit LongGOP) / 100Mbps (4:2:0 8-bit LongGOP) (H.264/MPEG-4 AVC, LPCM, High-Res Audio)
        • 23.98p, 200Mbps (4:2:2 10-bit ALL-Intra) / 100Mbps (4:2:2 10-bit LongGOP) / 100Mbps (4:2:0 8-bit LongGOP) (H.264/MPEG-4 AVC, LPCM, High-Res Audio)
    • 50.00Hz
      • [C4K] 4096x2160
        • 50.00p, 200Mbps (4:2:0 10-bit LongGOP) (H.265/HEVC, LPCM, High-Res Audio)
        • 50.00p, 150Mbps (4:2:0 8-bit LongGOP) (H.264/MPEG-4 AVC, LPCM, High-Res Audio)
        • 25.00p, 400Mbps (4:2:2 10-bit ALL-Intra) / 150Mbps (4:2:2 10-bit LongGOP) / 100Mbps (4:2:0 8-bit LongGOP) (H.264/MPEG-4 AVC, LPCM, High-Res Audio)
      • [4K] 3840x2160
      • [FHD] 1920x1080
        • 50.00p, 200Mbps (4:2:2 10-bit ALL-Intra) / 100Mbps (4:2:2 10-bit LongGOP) / 100Mbps (4:2:0 8-bit LongGOP) (H.264/MPEG-4 AVC, LPCM, High-Res Audio)
        • 25.00p, 200Mbps (4:2:2 10-bit ALL-Intra) / 100Mbps (4:2:2 10-bit LongGOP) / 100Mbps (4:2:0 8-bit LongGOP) (H.264/MPEG-4 AVC, LPCM, High-Res Audio)
    • 24.00Hz
      • [C4K] 4096x2160
        • 24.00p, 400Mbps (4:2:2 10-bit ALL-Intra) / 150Mbps (4:2:2 10-bit LongGOP) / 100Mbps (4:2:0 8-bit LongGOP) (H.264/MPEG-4 AVC, LPCM, High-Res Audio)
      • [4K] 3840x2160
      • [FHD] 1920x1080
        • 24.00p, 200Mbps (4:2:2 10-bit ALL-Intra) / 100Mbps (4:2:2 10-bit LongGOP) / 100Mbps (4:2:0 8-bit LongGOP) (H.264/MPEG-4 AVC, LPCM, High-Res Audio)
    MP4
    • 59.94Hz
      • [4K] 3840x2160
        • 59.94p, 100Mbps (4:2:0 10-bit LongGOP) (H.265/HEVC, AAC)
        • 29.97p, 72Mbps (4:2:0 10-bit LongGOP) (H.265/HEVC, AAC)
        • 23.98p, 72Mbps (4:2:0 10-bit LongGOP) (H.265/HEVC, AAC)
        • 29.97p, 100Mbps (4:2:0 8-bit LongGOP) (H.264/MPEG-4 AVC, AAC)
        • 23.98p, 100Mbps (4:2:0 8-bit LongGOP) (H.264/MPEG-4 AVC, AAC)
      • [FHD] 1920x1080
        • 59.94p, 28Mbps (4:2:0 8-bit LongGOP) (H.264/MPEG-4 AVC, AAC)
        • 29.97p, 20Mbps (4:2:0 8-bit LongGOP) (H.264/MPEG-4 AVC, AAC)
        • 23.98p, 24Mbps (4:2:0 8-bit LongGOP) (H.264/MPEG-4 AVC, AAC)
    • 50.00Hz
      • [4K] 3840x2160
        • 50.00p, 100Mbps (4:2:0 10-bit LongGOP) (H.265/HEVC, AAC)
        • 25.00p, 72Mbps (4:2:0 10-bit LongGOP) (H.265/HEVC, AAC)
        • 25.00p, 100Mbps (4:2:0 8-bit LongGOP) (H.264/MPEG-4 AVC, AAC)
      • [FHD] 1920x1080
        • 50.00p, 28Mbps (4:2:0 8-bit LongGOP) (H.264/MPEG-4 AVC, AAC)
        • 25.00p, 20Mbps (4:2:0 8-bit LongGOP) (H.264/MPEG-4 AVC, AAC)
    Variable Frame Rate, MOV
    • 59.94Hz
      • [C4K] 4096x2160
        • 29.97p (Maximum output of sensor is 60fps), 100Mbps (4:2:0 8-bit LongGOP) (H.264/MPEG-4 AVC, LPCM)
        • 23.98p (Maximum output of sensor is 60fps), 100Mbps (4:2:0 8-bit LongGOP) (H.264/MPEG-4 AVC, LPCM)
      • [4K] 3840x2160
      • [FHD] 1920x1080
        • 59.94p (Maximum output of sensor is 240fps), 100Mbps (4:2:0 8-bit LongGOP) (H.264/MPEG-4 AVC, LPCM)
        • 29.97p (Maximum output of sensor is 240fps), 100Mbps (4:2:0 8-bit LongGOP) (H.264/MPEG-4 AVC, LPCM)
        • 23.98p (Maximum output of sensor is 240fps), 100Mbps (4:2:0 8-bit LongGOP) (H.264/MPEG-4 AVC, LPCM)
    • 50.00Hz
      • [C4K] 4096x2160
        • 25.00p (Maximum output of sensor is 60fps), 100Mbps (4:2:0 8-bit LongGOP) (H.264/MPEG-4 AVC, LPCM)
      • [4K] 3840x2160
      • [FHD] 1920x1080
        • 50.00p (Maximum output of sensor is 240fps), 100Mbps (4:2:0 8-bit LongGOP) (H.264/MPEG-4 AVC, LPCM)
        • 25.00p (Maximum output of sensor is 240fps), 100Mbps (4:2:0 8-bit LongGOP) (H.264/MPEG-4 AVC, LPCM)
    • 24.00Hz
      • [C4K] 4096x2160
        • 24.00p (Maximum output of sensor is 60fps), 100Mbps (4:2:0 8-bit LongGOP) (H.264/MPEG-4 AVC, LPCM)
      • [4K] 3840x2160
      • [FHD] 1920x1080
        • 24.00p (Maximum output of sensor is 240fps), 100Mbps (4:2:0 8-bit LongGOP) (H.264/MPEG-4 AVC, LPCM)
