iZotope RX 8 Released
    • NEW – Spectral Recovery (Advanced Only) – Restores frequencies above 4 kHz, turning bandwidth-limited audio into clear, articulate recordings.
    • NEW – Wow & Flutter (Advanced Only) – Corrects pitch variations and fluctuations associated with tape, vinyl and optical transfers. Use Wow to fix longer, sustained pitch drift, and Flutter to correct pitch variances that occur at faster rates.
    • NEW – Loudness Control (Advanced and Standard) – Instantly load preset loudness targets and conform production audio to broadcast requirements in seconds, and monitor levels using the built-in numeric and history plot readouts for integrated, short-term, and momentary loudness.
    • NEW – Guitar De-noise (Advanced and Standard) – Allows refining to guitar recordings for maximum clarity in seconds. Manage sounds that can unintentionally be emphasized by the effect of compression or limiting, like electrical amp noise and interference, distracting fret or string squeaks, and harsh pick attacks.
    • NEW – 32 Audio Tab Limit (All Versions) – RX 8 doubles the previous 16-tab limit, now allowing users to view and edit up to 32 files within RX Audio Editor.
    • NEW – Horizontal Scrolling (All Versions) – Horizontal scrolling is now built into the intuitive Spectrogram Display. Use the scroll gesture on a trackpad or mouse to scroll through your audio across the X-axis for lightning fast edits.
    • IMPROVED – Music Rebalance (Advanced and Standard) – Users can easily re-animate a mix, make room for scene dialogue in post, remove or isolate vocals for a remix, or even create and export new stems for further processing and mixing.
    • IMPROVED – Batch Processor (Advanced and Standard) – Process many files at a time, view pertinent metadata in your audio, then apply a full series of processors with Module Chain.
    • IMPROVED – De-Hum (All Versions) – Now features independent frequency reduction bands, and a redesigned, intuitive interface.
    RX 8 is now available at https://www.izotope.com and select retailers
    • RX 8 Elements: $99 introductory ($129 regular)
    • RX 8 Standard: $299 introductory ($399 regular)
    • RX 8 Advanced: $999 introductory ($1199 regular)
    • RX Post Production Suite 5: $1499 introductory ($1999 regular)
  • 2 Replies sorted by
  • It is worst and smallest update in more than 6 years
    Most importantly, Dialog Match never made it into RX where it actually belongs.
    Batch processor is still horrible visual clutter and shite, instead of proper simple scripts.
    Spectrum restoration is just mostly mumbo-jumbo (presented in lot of software and plugins before)
