NVidia Ampere GPUs from RTX 3050 to RTX 3090 Ti
  • 161 Replies sorted by
  • Specs
    659 x 954 - 59K
    800 x 832 - 51K
    800 x 827 - 52K
  • ASUS totally fucked the Nvidia idea with cooling improvement by mostly blocking third fan
    800 x 434 - 51K
    800 x 529 - 54K
    800 x 703 - 75K
    800 x 535 - 59K
  • Broadcast app that will be abandoned in 1-2 years completely
    800 x 434 - 49K
    800 x 478 - 44K
    800 x 465 - 41K
    800 x 492 - 66K
    800 x 448 - 36K
  • RTX 3080 GPU will sell for $699, the same as the current 2080, while the mid-range RTX 2070 will go for $499. NVIDIA says the RTX 3080 is twice as fast as the 2080, while the 3070 is even faster than the RTX 2080 Ti.
    Nvidia specially lowered prices and moved RTX 3090 out of this event focus to avoid negative backslash.
    The RTX 3080 willl feature 39 shader teraflops instead of just 11, and 58 RT TFLOPs, compared to 34. But Ampere's biggest leap is in its AI Tensor Cores, which clock in 238 tensor TFLOPs instead of just 89.
    Nice marketing stunt to replace performance of FP32 into FP16, but this strange terms also need independent explanation.
    Same strange
    NVIDIA says the RTX 3090 can reach 36 shader teraflops, compared to the RTX 2080 Ti’s 13.4 TFLOPs.
  • 4 fan RGB horror
    800 x 577 - 74K
  • RTX 3090 PCB
    800 x 517 - 98K
    800 x 551 - 104K
    Some little fake charts, note that it is in DLSS mode and also using RTX and all on ultra settings.
    Rumors are that as you drop settings and use native resolutions difference drops to 15-20%
    800 x 457 - 38K
    800 x 606 - 93K
    800 x 633 - 89K
  • @Meierhans
    Can be even for 4-5 years. Note that RAM is important, as it makes sense to orient on GPU that will work with 8K properly.
    And if you want cheap two used 1080 TI's are usually better 9and cheaper) in Resolve as I remember.
  • So, do I get this right: 2080 ti (possibly in SLI) will stay the best affordable NVIDIA card for quite a while?
    1009 x 569 - 81K
    864 x 454 - 68K
    975 x 587 - 81K
  • ASUS STRIX
    852 x 440 - 78K
  • One more info on prices
    • Basic RTX 3090 model price will be $1999
    • Good RTX 3090 top designs will be $2999, all models with waterblocks will be >$2600
    • Overclockers boards will have normal consumption at 500w, peak can reach 700w
    • Cards will be very noisy under high load, all air cooled designs will work at 3000-5000rpm during load
  • Gainward
    800 x 677 - 89K
    782 x 757 - 111K
    736 x 477 - 79K
  • Zotac cards list and some photos leaked
    • GeForce RTX 3090 AMP Extreme;
    • GeForce RTX 3090 Trinity HoLo;
    • GeForce RTX 3090 Trinity;
    • GeForce RTX 3080 AMP Extreme;
    • GeForce RTX 3080 Trinity HoLo;
    • GeForce RTX 3080 Trinity;
    • GeForce RTX 3070 Twin Edge HoLo;
    • GeForce RTX 3070 Twin Edge.
    746 x 414 - 29K
    800 x 391 - 50K
    800 x 469 - 51K
    800 x 372 - 40K
    800 x 766 - 58K
    800 x 255 - 45K
  • RTX 3090 GPU
    761 x 559 - 51K
    Present rumors
    • RTX 3060 will start from $400 for worst cards, up to $600 for good
    • RTX 3090 will start from $1400 for 12GB worst model, and up to $2999 for ASUS top 24GB one
    • Top overlocked RTX 3090 will require water cooling and will consume up to 650-700 watts.
    800 x 456 - 53K
    800 x 419 - 61K
  • Huge 3 slots RX 3090 card
    Idea of new design is to maximally increase fans diameter and depth.
    738 x 630 - 93K
    800 x 722 - 75K
  • Rumored prices
    GeForce RTX 3090 cards prices will be from $1400 for cheapest and worst card to $2000 or even $2100 for top fo the line 3 fans versions with best cooling. Many cards can be with water cooling system.
  • NVIDIA will run a digital version of its GTC conference from October 5th-9th. There’ll be a keynote from CEO and founder Jensen Huang on the first day of the event at 9AM ET.
  • RTX 3080 leaks
    Card will have
    • 10Gb GDDR6X RAM, 19Ghz efficient clockspeed
    • 2.1Ghz GPU amde using Samsung foundry
    800 x 533 - 38K
  • @DrDave
    Well, if you need it only for video and alike - simpler to get used 1080 Ti or 2080 Super.
