SIGMA fp Cinema Camera with CinemaDNG raw
  • 199 Replies sorted by
    Last photo shows that no one in Sigma cared much about efficient cooling. Just look how thick the thermal pads are, meaning that designers did not move properly copper plate closer.
    Thermal design is very similar to $15-30 Chinese TV boxes. Very similar, they also have such pads and plate.
    800 x 500 - 83K
    800 x 554 - 57K
    800 x 514 - 59K
    800 x 524 - 69K
    542 x 500 - 30K
    800 x 529 - 59K
  • @DrDave I cannot find the spec for h264. But, really, there is absolutely no reason to use this camera and shoot using H264, even if 10bit. There is not even a log profile. You can directly attach a Samsung T5 to the body and by usb-c shoot 4K 30 in 12bit RAW. That's how the camera really shines. And with the T5 it is still more compact than any existing full-frame camera, including the new Sony small version.
    You can shoot up to 4K 25 fps 8bit RAW internally, and that will actually be more robust than even 10bit All-I and looks great.
  • No 10 bit internal for H264?
  • Low light test, in a dark church and at night for Halloween decorations:
  • Sigma fp Flip Screen mod, and soon to be available cage and NVME or SATA SSD mount
    1499 RMB around $222 plus shipping
    use Google Translate
    https://item.taobao.com/item.htm?id=623177837309&fbclid=IwAR1dwjkg0Vbw3_rkPHpwDdLjwoIoXGeoJcSSbJJDegRq_-WhBxD_6V9gR08
    578 x 453 - 55K
  • New firmware v2.01
    • Corrected the phenomenon of displaying white corners on DNGs or CinemaDNGs in some development software when using the following combination:
      • SIGMA fp and Panasonic’s LUMIX S 20-60mm F3.5-5.6 with the Lens Optics Correction function Vignetting setting set to ‘auto’, when the focal length is 20mm and aperture value of F3.5.
    • Corrected the bug related to Blackmagic RAW codec recording over HDMI with Blackmagic Video Assist 12G model manufactured by Blackmagic Design.
    • Corrected the bug related to Compressed RAW over HDMI recording with Atomos Ninja V monitor-recorder.
    https://www.sigma-global.com/en/download/cameras/firmware/#fp
  • @markr041 Thank you for your insights, i know it's about the Olpf and i hoped that Braw would mitigate this but unfortunately my FP exhibit moiré on some fabrics even in a 6K Dng in photo mode. I asked Rawlite for an Olpf for the FP, they are centered on BMD products but we never know.
  • @Faudel Thank you for looking, closely.
    First, I see what you see.
    Second, lost detail cannot be brought back. So that is a real issue for BRAW.
    Third, highlight "rolloff" is a property of the de-mosaicing, which is all done in DaVinci Resolve for DNG RAW. BRAW is partially de-mosaiced by the BM VA as you say and then fully processed by DaVinci Resolve. Resolve was set to process both files with the same transform, and I could see that highs were rolled off in BRAW without any further changes. So, the greater whites for DNG RAW is all me and the software, since I could use the controls in Resolve to muck around with highlights for both. In principle, anything the BM VA does to the RAW stream, Resolve can do also, maybe better. So, I could have rolled off the whites, but as you see, the whites are not over the top.
    I do not see how partially de-mosaicing or any de-mosaicing can reduce moire, which is due to the lack of an optical low-pass filter in the camera and perhaps line skipping to go from 6K to 4K. In principle, there might be a software fix of some kind, but I doubt that is part of the BRAW de-Bayering since many cameras do have the filter.
  • @markr041 Thank you for the comparison. Cdng seems slightly sharper but the big difference is in the white patch on the color checker. Luminance value is 69% in Braw while 75% in DNG, you can also see it in the left fist of the Muay-Thai fighter. Is this due to your post processing or does Braw brings a better highlight roll off ? On another side, as Braw is using some debayering operations , does it minimize moiré issue on the FP ?
  • New firmware for Video Assist 5” 12G HDR and Video Assist 7” 12G HDR specifically (and only) for Sigma fp features and improvements:
    Added support for 100 and 119.88fps on Sigma fp for Blackmagic RAW. Improved color temperature in Blackmagic RAW on Sigma fp (maybe this gets rid of the green tint). Fix trigger recording when outputting Blackmagic RAW on Sigma fp
    Also needs Sigma fp firmware update to 2.01.
  • Or in my head!
  • @calmist Or are you seeing more sharpening? How could there possibly be more real detail? There is chatter on the internet that BRAW sharpens and noise reduces. And, besides, I see the opposite (but the difference is so small it is hardly worth anything and may be in my head) as have some other commenters.
  • I am seeing slightly more detail with BRAW.
  • Meanwhile, I do not see the point of externally recording 12bit BRAW or 12bit ProResRaw on a camera that can record true 12bit RAW (DNG RAW) internally. So, I looked to see if there was one (BRAW vs. DNG RAW):
    The BM Video Assist 12G was used to record BRAW from the Sigma fp via HDMI. The highest quality setting for BRAW was used (constant quality).
    DNG RAW was recorded to an SSD attached by USB-C cable to the Sigma fp.
    ISO 3200 (native), F8.0, Auto WB, for all clips.
    Canon EF 35mm F2.0 and EF 100mm F2.8 Macro in Full Frame and Crop Mode.
    In Resolve, the input gamma and gamut was set to BlackMagic Film Generation 4 for both.
  • Free Ninja V Pre-Release Beta update for FujiFilm GFX100 & SIGMA fp is now available. This enables 12bit ProResRaw recording on the Ninja V via HDMI from the Sigma fp (4KDCI 24p, 4K UHD up to 30p, FullHD 120p).
  • You can still shoot with the BM Video Assist 12G and the Sigma fp, it is just awkward. Punching the record "button" on the VA screen hurts stability. The VA 12G with batteries is bigger and heavier than the Sigma fp with most lenses. I mounted the camera on the VA. It works...
    4K DCI 24P BRAW, Q0 (the highest quality) shot on an SD card in the VA:
  • Operating conditions of the Blackmagic Design Video Assist 3.2 and SIGMA fp firmware Ver.2.00
    We would like to announce that the SIGMA fp firmware Ver.2.00, which was released on 25 June 2020, is now able to record in Blackmagic RAW via the Blackmagic Design Video Assist 12G model with its latest firmware update, Blackmagic Design Video Assist 3.2. This was launched by Blackmagic Design on 17 July.
    Please note the phenomenon below, which is the result of SIGMA’s investigations into the operating functionality of a SIGMA fp when recording in Blackmagic RAW via Blackmagic Video Assist 12G, for which the firmware has been updated to Blackmagic Video Assist 3.2.
    Confirmed phenomenon
    REC trigger does not work properly.
    SIGMA will continue to observe the operating functionality of the camera and provide any necessary firmware updates at a later date.
  • Cheers, looks fun, and yeah, if I had CDNG internal maybe I'd use it...
  • Anyway, enough of this technical mumbo jumbo! Here is a fun 4K 12bit DNG RAW video from the Sigma fp. This is about the only live music you can watch these days (and record):
  • @kellar42 Thanks for the info. But...
    You can losslessly compress DNG RAW files using Slimraw on a computer and reduce the file sizes to 40% of the originals (a reduction of 60%). If you are willing to go "virtually" lossless then you can reduce to 25%, just like you can do for ProResRAW. So, if the lossless ProResRAW files are 40% the size of lossless DNG RAW files, there is no size advantage to ProResRAW at all at all. And as computers get faster and programmers get more sophisticated, in the future the compression - without loss - may be greater.
    One can use a Ninja V on the Sigma fp, just like on the Panasonic S1H, to get ProResRAW. I own it, so I can do it - I have no bias based on the fact that it is the only option for RAW, like it is for the Panasonic cameras. To get any RAW from the EV1 or the S1H you MUST use the Ninja V.
    The question still remains whether there is any advantage to shoot ProResRAW (or BRAW) when one can shoot internally 12bit DNG RAW on the Sigma fp and compress them to 40% (or less) of the original size in post.
  • @markr041 You are correct I don't know the math used to compress raw that RED, Canon or Apple are using. I don't know what Blackmagic is doing, either, but I know they're partially de-bayering in camera, unlike the other three.
    Redraw, Canon Cinema Raw Light and ProRes Raw are all smaller than CDNG, yes? They are all raw, yes? That is the point I am getting at. Codecs evolve, files get smaller, "virtually losslessly".
    There is no noise reduction in ProRes Raw, either - and Apple made a Denoise plugin specifically for ProRes Raw in FCPX because raw logically tends to be noisier since no in camera noise reduction is happening.
    I have nothing against CDNG, but for me, with an Eva1, or hopefully soon S1H, or any one of a bunch of other cameras using Atomos recorders gives me an amazing PRR file that I can cut immediately in FCPX with greater control for color and finishing than the internal codecs.
    I don't need you to invest in anything...I was initially responding to someone above ( hardimpact ) who said PRR was partially de-bayered in camera to avoid a red lawsuit, which is false. Whatever Apple and Red have worked out internally (again, sorry I "don't know much too", lol) - Pro Res Raw is not de-bayered in camera. It is far more flexible and powerful than many people who don't know their way around FCPX have said on the internet. I am hoping for a long and continued development with it and am glad to see it spread across cameras.
  • @kellar42 I am sorry, if you do not know then you do not know. ProRes Raw is not simply "better" compression of real RAW video because it is "newer." I am not an expert either, but that is certainly not true.
    The fault is not us; the problem is that Apple and Atomos are simply not being transparent about what processing is going on. There are reports there is noise reduction, which reduces detail but also allows more compression. Some people claim they see this. I don't know, but what I an sure of is it is not simply a better lossless compression algorithm. Or is it?
    The real question is other than files size, given that Slimraw can reduce DNG RAW to 30 to 40%, why should one invest in this "new" sauce requiring bulking up the rig, worrying about multiple batteries, etc. DNG RAW works effortlessly in DaVinci Resolve. No one is complaining about processing DNG RAW. I am not. Easier processing is hardly a justification - uncompressed video is really easy to process no matter what the packaging. Again, I do not know more than you on this topic, but you seem not to know much too.
