Nikon D6 Camera Topic
  • 34 Replies sorted by
  • Nikon D6 firmware version 1.33
    Fixed an issue that would in very rare instances result in a burst of two photos being taken with a single press of the shutter-release button when Single frame was selected for release mode.
    https://downloadcenter.nikonimglib.com/en/download/fw/419.html
  • Firmware update v1.20
    • A Recall shooting functions (hold) item has been added to Custom Setting f3 Custom controls. Assigning this role to a control lets you recall previously-saved values for settings such as exposure and metering by pressing the control once during viewfinder photography. The previous values can be restored by pressing the control a second time. Recall shooting functions (hold) can be assigned to the Preview button, Fn1 button, Fn2 button, Fn button for vertical shooting, AF-ON button, Sub-selector center, AF-ON button for vertical shooting, Movie record button, or Lens focus function buttons.
    • A new option, Prefer sub-selector center, has been added to the Custom Settings menu at position f13. Although at default settings the sub-selector cannot be used to position the focus point while the center is pressed, selecting Off for Prefer sub-selector center lets you hold the center and still position the focus point by pressing the sub-selector up, down, left, or right. You can, for example, assign AF-area mode to the center of the sub-selector and then use the sub-selector to position the focus point while the center still serves in the AF-area mode role.
    • A Focus point selection speed item has been added to Custom Setting a17 Focus point options. The speed at which the focus points for viewfinder photography can be cycled by holding the sub-selector or keeping the multi selector pressed up, down, left, or right can be chosen from Normal, High, and Extra high.
    • Ratings are now displayed at all times during playback zoom, even when None (image only) is selected for playback display options.
    • The camera can now more reliably focus on poorly-lit low-contrast subjects when dynamic-area AF is selected for AF-area mode.
    https://downloadcenter.nikonimglib.com/en/download/fw/396.html
  • Sensor
    800 x 528 - 47K
  • Tokina again
    We would like to inform You that we found functional issue with Tokina opera 50mm f/1.4 FF (Nikon F mount) when used with Nikon D6 camera (released on June 5, 2020). Other Tokina lenses work normally.
    Affected model: Opera 50mm F1.4 FF (Nikon F mount).
    Symptoms:
    • When the power of the camera with the lens attached is turned ON, AF might not work properly.
    • After the camera recovers from "Sleep mode" AF might not work properly.
    • We are currently investigating the issue and will inform you as soon as possible.
    We sincerely apologize for any inconvenience this issue may cause.
  • Fight between coporations looks like this:
    Thank you for purchasing and using our products.
    We have found that some SIGMA interchangeable lenses for Nikon are not fully compatible with the Nikon D6 released on June 5th.
    When certain lenses are attached to this camera the following phenomena will occur.
    Products concerned:
    • SIGMA 12-24mm f/4 DG HSM | Art
    • SIGMA 14-24mm f/2.8 DG HSM | Art
    • SIGMA 14mm f/1.8 DG HSM | Art
    • SIGMA 28mm f/1.4 DG HSM | Art
    • SIGMA 40mm f/1.4 DG HSM | Art
    • SIGMA 85mm f/1.4 DG HSM | Art
    • SIGMA 105mm f/1.4 DG HSM | Art
    • SIGMA 135mm f/1.8 DG HSM | Art
    Phenomenon:
    • It takes time to start even if the camera power is turned on
    • Autofocus does not work
    Nikon made special small changes, and, of course they tested and made sure that competition will have small issues.
  • Some Tamron lenses have issues
    Dear Tamron product users and potential purchasers. Thank you for your continued support of Tamron products. We would like to announce you that we have confirmed that some of our lenses do not work properly with the Nikon D6 released on the Japanese market on June 5, 2020.
    Affected models:
    • Tamron SP 35mm F/1.4 Di USD (Model F045) for Nikon
    • Tamron 17-35mm F/2.8-4 Di OSD (Model A037) for Nikon
    Symptom:
    1. AF does not work when the camera power is turned on after mounting the lens with the camera power off.
    2. AF does not work when the camera returns from sleep mode.
    We are currently working on the cause of those issues and will inform you of updated information in our website. We sincerely apologize to all users and potential purchasers for any inconvenience this issue may cause.
  • For digital single-lens reflex camera "D6" scheduled to be released on June 5, 2020 (Friday), some parts are unavaibale due to the influence of the coronavirus infection. Some of our customers may not be able to get the product on the release date. Delays can continue and affact delivery time to all future customers.
  • Buffer tests
  • The digital single-lens reflex camera "D6" and "filter case FTC-01" that were announced as scheduled for release in May 2020 will be released on June 5, due to the impact of the new coronavirus infection in Japan.
  • Today, Nikon Inc. announced the retail availability of the new Nikon D6 DSLR, which was unveiled in February of this year. The D6 will be available in the U.S. starting on Thursday, May 21 for the suggested retail price (SRP) of $6,499.95* for the body-only configuration.
    Whether on an assignment or in the studio, Nikon’s flagship D6 DSLR always delivers. The D6 incorporates Nikon’s most powerful AF to date, featuring a high-density system with 105 selectable cross-type AF points to help capture pivotal moments again and again, even in the most challenging conditions and environments. Since every second counts, the uncompromising D6 incorporates important upgrades to enhance photographers’ workflow and accelerate file transfer capabilities, offering time-saving and customizable options during and after capture. Additionally, the D6 offers robust reliability, unrivaled low-light capability, amazing versatility, 4K UHD multimedia capabilities and a mechanical shutter frame rate that can capture at a blazing fast 14 frames-per-second (fps).
  • Nikon D6 will be shipping out in Canada in the first week of May. And that's May 2020, not 2021!
    D6 is one of them main focus for Nikon, lot of cheaper cameras can be pulled from the market.
    If you will see issues with top bodies it can mean that Nikon id on the brink of collapse also.
  • Apology and Notice of Delay in the Release of the Nikon D6 Digital SLR Camera
    MELVILLE, NY – Thank you for choosing Nikon for your photographic needs.
    As a result of delays in the procurement of parts and components from a third-party cooperating company due to measures implemented in response to the spread of COVID-19, the release of the new Nikon D6 digital SLR camera, originally planned for March 2020, will be delayed. We sincerely apologize to our customers and all those concerned for any inconvenience this may cause.
    We are now planning to release the Nikon D6 in May 2020 and will announce the new release date once it has been determined.
    We will continue to closely monitor the situation and do our utmost to deliver this new camera as soon as possible. Thank you for your understanding and patience in this matter.
  • AF sensor
    Exposure RGB sensor
    AF Processor
    571 x 483 - 38K
    720 x 428 - 33K
    789 x 525 - 63K
  • DECISIVE POWER. FASTER WORKFLOW. ABSOLUTE RELIABILITY: THE NEW NIKON D6 GIVES PROFESSIONALS THE EDGE WHEN IT MATTERS MOST
    The New Nikon D6 Offers the Most Powerful AF System in Nikon's History, and Continues the Brand Legacy of Professional Cameras That Deliver Connectivity, Dependability and Streamlined Workflow
    Nikon Inc. has unveiled the D6, a new professional-grade DSLR built for those in need of extreme reliability and ultimate performance.  The D6 addresses the needs of professionals and press agencies, and is faster and more powerful than ever before. Offering the most powerful AF system in Nikon's history, this flagship DSLR camera delivers crucial improvements to modern workflow while also accelerating file transfer capabilities. Promising unparalleled low-light performance, powerful agility, advanced 4K UHD multimedia capabilities and a mechanical shutter frame rate boosted to a staggering 14fps, the D6 will redefine the way pros work.
    The Most Powerful AF in Nikon's History: The D6 leaves nothing to chance. To maximize hit rate, it is equipped with a newly developed, densely packed 105-point AF system in which all the focus points utilize cross-type sensors and all points are selectable. Through the new focus point layout and the use of a triple-sensor arrangement for each focus point, the D6 achieves AF coverage that is approximately 1.6x denser than that of the D5. The D6 also sports an expanded focus detection range which increases the detection area for single point AF and dynamic area AF, making it easier to achieve focus on a subject even when slightly outside the focus point.
    Improving upon Nikon's popular Group AF mode, this function has evolved with support for 17 custom arrangements from which users can choose according to the scene or subject movement. The D6 also demonstrates superior low-light AF performance. The center focus point works down to -4.5 EV1 and the others to -4 EV, making autofocus possible even in dark situations or with low-contrast subjects.
    Unparalleled Performance: The new EXPEED 6 engine's superior image-processing capabilities combined with the vast amount of information provided by the new dedicated AF engine drives high-level performance in any situation. To help capture the decisive moment consistently, the D6 boasts a 14fps2 mechanical shutter with full AF and AE.  The D6 can also shoot completely silent for sensitive situations capturing full resolution at 10.5 fps. For faster frame rates, the Nikon D6 is able to take 2-megapixel images at approx. 60 fps and 8-megapixel images at 30 fps in Live View mode.
    The D6 leverages a 20.8-megapixel FX-Format CMOS sensor, creating images that pop with stunning detail, true colors and exhibiting incredible dynamic range. The ISO ranges from 100 to 102,400, which helps to preserve sharpness and subtle details in even the most challenging light. Additionally, ISO is expandable up to 3.2 million, giving photographers the ability to truly conquer the dark.
    Concentration on Workflow: Building on Nikon's history of serving professionals, the D6 is the most customizable Nikon DSLR yet, designed to speed up the workflow of any user during and after capture.
    • Recall shooting functions create combinations of settings that can be assigned to a specific button to get the perfect shot in a pinch
    • The D6 excels in connectivity and supports the same 1000BASE-T Ethernet standard as the D5, with an approximate 15% increase in transmission speed. The camera also supports a number of options for wireless networking, offering built-in 2.4- and 5-GHz*3 Wi-Fi®4 or traditional wireless transfer using the WT-6 Wireless Transmitter (optional)
    • Includes 14 customizable buttons, assignable to any of 46 unique function choices and a new intuitive menu system
    • Priority Image Transfer gives the ability to move an important image to the front of the queue when speed is of paramount priority, which can easily be done by swiping the touch LCD during playback
    • Security Lock compatibility supports connection of anti-theft cables to provide maximum security for remote applications or when the camera is unattended
    • Built in GPS5 gives accurate time, date and location information for just about anywhere on the planet
    • Dual CFexpress6 slots offer blazing fast read/write times and have the ability to overflow, copy or separate file types
    • JPEG functions allow for the simultaneous recording of two JPEG images with different image size and quality settings, which is convenient for separating images that will be transmitted from those that will be edited
    • Creativity options for multimedia creators including a new interval timer mode to retain the best resolution and enable in-camera time-lapse movie file recording providing professionals the ability to create exceptionally sharp 16:9 4K Ultra HD video
    Absolute Reliability: Nikon's flagship cameras remain trusted in the industry and have been proven on the sidelines, in the studio and even in outer space. With a magnesium alloy camera body and extensively weather-sealed design, the D6 is as tough as the professionals who use it, ready to take on the harshest shooting conditions. The camera offers long-lasting battery life, delivering the safety net and energy-saving performance that pros need on daylong outings. The D6 also employs a USB-Type C connector for faster direct-to-PC file transfer rates than previously possible with the D5.
    Endless Lens Choices: By pairing the D6 with Nikon's extremely diverse selection of F-Mount NIKKOR telephoto lenses, professionals have the most advanced imaging solution in Nikon's history. No matter the job, the client or the location, there's a NIKKOR lens, from the ultra-wide to the super-telephoto. The D6 is also compatible with Nikon's line of creative Speedlights, offering extra creative freedom to enhance natural light and add artistry and drama to any scene.
    Pricing and Availability
    The new Nikon D6 will be available in Spring 2020 for a manufacturer suggested retail price (MSRP) of $8,999.95*. For more information on the latest Nikon products, please visit www.nikon.ca.
    800 x 783 - 79K
    800 x 753 - 74K
    800 x 502 - 48K
  • The Nikon D6 will be officially announced in the first half of February - it could be in the first week of February or around February 12.
    D6 high ISO will be improved by one stop compared to the D5 (not compared to other modern similar cameras!)
