Price : $500 (+shipping) Resolution : 800 x 3 (RGB) x 480 Sunhood is included. Main difference is HD/SDI input. It also has HD/HDI output. Batteries - mount for Sony batteries.
I am new here, & 1st of all I want to thank you for all what you are doing to help. I have a Q about the field monitor, which one of this do you think is better & why.
You can't compare this monitors.
First, monitor this topic is about has SDI input and output, and none of the monitors listed in your links have them. Plus it is very cheap for SDI enabled monitor.
I purchased one of these about 3 months ago and just recently resold it.
A few of the issues I had with my screen:
Overscan - The HD/SDI signal, goes beyond the edges of the screen. By this I mean the image being recorded is beyond the edge of the screen. It is very slight but enough to mess up framing. There is no option to correct this.
This issue is not present over the HDMI or SD signals, however every camera with HDSDI I tested had this issue. HDX900, EX3, AF-100.
Viewing angle above or below is horrible.
Image controls are more like a television than a field monitor.
I haven't found a comparable monitor that offers HDSDI in this price range, been sticking to the AJA box and hdmi Ikan.
