Got Netac SSD and cage. Coupon worked, thanks Vitaliy!
Working coupons
Goldenfir SSDs
512GB for $36.49 and below, use codes in first topic post and posted later.
New coupons
SmallRig Cages - best quality among affordable Chinese made cages
https://www.aliexpress.com/item/32789233639.html
https://www.aliexpress.com/item/32850258393.html
Very fast SATA controller with 5 ports
I used such to add many drives to storage/media servers.
XIAOMI Wowstick Portable Electric Screwdriver
Use general coupon from above.
Personally have same, use for various things together with manual screwdrivers.
I wish bits storage will be not so nice looking, but more handy, Xiaomi now have such separate :-)
Otherwise have almost all bits you will need in life.
Very nice present also.
JAKEMY 49 in 1 Precision Screwdriver, one of two sets I have
Useful if you need to fix something fast.
Anti theft backpack with charger
Use general coupons from this topic.
New coupons
Good monopod our team is using
Leveling bases
Very important item if you like to shoot on small photo like tripods, saves tons of time.
Such sales time is best to get them.
CO2 detector with proper NDIR sensor
Very important to have proper air flow, as CO2 affects your efficiency and how you feel a lot during long edits.
As low as $56-57 shipped with select and general coupons.
It is superb price.
ZHIYUN Official Smooth 4
Use general coupons from topic.
FeiyuTech Vimble 2 Smartphone Gimbal
Use $2 seller coupon and general coupons in topic above.
Two high CRI panels set with stands
Get seller coupon.
Use also general coupons above in topic.
BOYA BY-WFM12 VHF Wireless Lavalier Microphone - best among entry level ones!
Use seller coupons and discount and general coupons in topic above.
Very nice price overall.
It is really reliable thing, not high end, but works good.
FeiyuTech G6 Plus 3-Axis G6P Handheld Gimbal for very good price
Use select coupons, seller discount, and coupons in topic above.
Superb deal now on wireless video transmitter
Nice price instead of usual $219.
Use $12 select coupons and also remember to use general coupons above.
Famous iFootage design stabilizers, below $70 with coupons
For some work such thing is more useful than gimbal. And always handy to have.
If you want to build cheap but good custom water cooling system - check BykSki
Such systems are much better compared to most all in ones, upgradable.
So you can start from single CPU block +radiator and go up to 4 GPUs + CPU blocks + 2-3 big radiators.
Important, as all CPUs becoming more and more power hungry.
Nice DDR4 memory
Hold normal overclocking 3000-3200Mhz, for new Ryzen can be even better.
Use generals coupons from this topic.
Professional 24 Color Card Test Color Chart
You can get it at best price now.
Nice 20cm computer fan
Will be below $14.6 delivered. Get multiple to use coupons.
Fan has really nice air flow and noise performance. Using such personally.
Cheap fluid head
Such are made for photo like tripods and monopods. Of course during really cold days outside their behavior changes, so for winter you need to check them first and may be change grease.
