Litra Litrastudio RGBWW LED Light
    • 2,400 Lumen Constant / 3,000 Lumen Overdrive / 6,000 Lumen Flash
    • 97 TLCI /CRI (90+ CRI and 95+ TLCI)
    • CCT, HSI, RGBWW, Gel and Effects Modes
    • Adjustable CCT from 2,000 -- 10,000 K
    • Adjustable Green / Magenta in CCT mode
    • 0-100% Fully dimmable
    • Manual OLED display
    • Controllable by Bluetooth/Smartphone App, DMX Dongle and Flash Sync Cable
    • Bluetooth App Controls with multiple light synch capabilities
    • 50 degree beam angle with blended smooth lux beam
    • Waterproof to 10M/30FT
    • 810G MIL SPEC
    • Precision crafted aluminum body
    • Intelligent thermal management
    • Standard 1/4 20 mount in base
    • 9,000 mAh rechargeable, fast swappable lithium ion battery
    • Battery life of 20hrs on low, 1hr at 2,400 Lumen
    • 45W Quick Charge adaptor with USB PD2 Type C cable
    • Custom Light Modifier Kit with Barn Door, Soft Box, and Honeycomb
    • Dimensions: 140 x 100 x 50.75 mm
    • Weight: 950g
  • 1 Reply sorted by
