25mm F1.4 II Panasonic Leica DG, 2019 version
  • 4 Replies sorted by
  • UK PR
    Panasonic has upgraded its LEICA DG 25mm fixed focal length lens for the Micro Four Thirds system standard, adding a new splash/dust-resistant* construction and compatibility with max. 240 fps sensor drive for high-speed autofocusing. The wide maximum aperture of F1.4 makes the new LEICA DG SUMMILUX 25mm / F1.4 II ASPH. (H-XA025) a high-speed standard lens for the Micro Four Thirds system with the same angle of view as a 50mm lens for full-frame systems.
    Offering a focal length that is truly flexible and suited to a wide range of subject matter, the LEICA DG SUMMILUX 25mm / F1.4 II ASPH. features stunningly high resolution and contrast from the centre to the corners of the image, despite its large aperture. It also provides smooth focus transition and out-of-focus highlights, producing beautiful bokeh that makes pictures even more attractive.
    The lens construction comprises 9 elements in 7 groups, including 2 aspherical elements and 1 UHR (Ultra High Refractive) index lens. The UHR index lens and the glass moulded aspherical lenses ensure high quality from the centre to the corners of the frame while maintaining a compact and lightweight design. Panasonic Nano Surface Coating is also applied to minimise ghosting and flare to provide high-contrast and clear images even when shooting towards a light source. Surpassing LEICA’s stringent certification standards, exceptionally high image quality is guaranteed from this lens.
    Incorporating an inner-focus drive system and stepping motor the new LEICA DG SUMMILUX 25mm / F1.4 II ASPH. is capable of smooth, silent operation to complement the latest LUMIX G camera’s high-speed, high-precision contrast AF systems for both photo and video recording. It is also compatible with VENUS Engine processors that drive LUMIX camera systems at max. 240 fps, so it can take maximum advantage of cameras with high-speed AF.
    Realizing the potential of a large-aperture lens in a compact, lightweight body, the new rugged-design LEICA DG SUMMILUX 25mm / F1.4 II ASPH. achieves both high picture quality and portable size, fitting in perfectly with the latest LUMIX G Mirrorless Cameras.
    Lens will be available for £579.99 from 24 October 2019.
  • PR
    Panasonic announced today it has renewed its LEICA DG fixed focal length lens based on the Micro Four Thirds system standard. In addition to the large F1.4 aperture, the new LEICA DG SUMMILUX 25mm / F1.4 II ASPH. (H-XA025) features splash- and dust-resistant* construction for heavy field use and is compatible with max. 240 fps sensor drive for high-speed AF.
    Despite its large aperture, the LEICA DG SUMMILUX 25mm / F1.4 II ASPH. features stunningly high resolution and a descriptive performance in all areas of the image, while supporting versatile use with its 50mm (35mm camera equivalent) focal length. In addition, the renewed lens provides smooth defocus for a beautiful bokeh effect that creates even more stunning pictures.
    The lens system, comprised of nine elements in seven groups, uses two aspherical lenses and one UHR (Ultra High Refractive) index lens. The UHR index lens and glass mold aspherical lenses achieve uniform description from the center to the corners of the image, while Panasonic Nano Surface Coating on the lens minimizes ghosts and flare.
    Incorporating an inner focus drive system and stepping motor, the new LEICA DG SUMMILUX 25mm / F1.4 II ASPH. is capable of smooth, silent operation and works with the camera’s high-speed, high-precision contrast AF system for both photo and video recording. It is also compatible with the sensor drive at max. 240 fps to take maximum advantage of cameras with high-speed AF.
    Realizing the potential of a large-aperture lens in a compact, lightweight profile, the new rugged-design LEICA DG SUMMILUX 25mm / F1.4 II ASPH. achieves both high picture quality and mobility, and takes advantage of the latest LUMIX G Digital Single Lens Mirrorless Cameras. Having passed rigorous standards to be certified with the world-renowned LEICA name, exceptionally high image quality is guaranteed.
    The LEICA DG SUMMILUX 25mm lens will be available in October for $699.99.
