AMD Navi GPUs, AMD 5xxx series, official topic
  • Make correction that leak is on big AMD fan channel :-) So, some stuff is not fully correct :-) Use logic that guess that.
    • AMD Radeon RX 3080
      • $249
      • 8GB GDDR6
      • Performance ala Vega 64 + 15%
      • Competitor for RTX 2070 or GTX 1080
      • 150W TDP
      • Navi 10 chip
    • AMD Radeon RX 3070
      • $199
      • 8GB GDDR6
      • performance ala Vega 56
      • Competitor for RTX 2060 or GTX 1070
      • 120W TDP
      • Navi 12 chip
    • AMD Radeon RX 3060
      • $129
      • 4GB GDDR6
      • performance ala RX 580
      • Competitor for RTX 2050 or GTX 1060
      • 75W TDP, no external power connector
      • Navi 12 chip
  • 33 Replies sorted by
  • Radeon RX 5500
    RX5500 price is expected to be from $120 to $150 (top one for 8GB version).
    767 x 657 - 41K
    748 x 406 - 47K
    745 x 400 - 45K
  • I went with a used 1080ti for 430$,been using 1060 mini 6gb for a couple years now
  • @sammy
    May be, may be not.
    Note that 1080 Ti used can outperform it sometimes and is much more future proof due to more memory.
  • At 400 to 500$ for new or used GPU , is the 5700xt best option (working with Davinci, fusion, after effects) ?
  • @karl
    Radeon VII is no longer made, actually.
  • I wonder why they started marketing Navi with GPUs that are less performant than their older "Radeon VII" product. Sure, the Navi chipset is more power efficient - but still not as power efficient as their competitors, so I really would have expected them trying to best their older generation with a new high-end model in absolute performance.
  • Video encoders, fps, performance using fast preset
    690 x 752 - 59K
    693 x 618 - 54K
  • Video decoders, fps, performance
    692 x 618 - 60K
    696 x 754 - 60K
  • Two parts define GPU performance in video editing - calculation speed and video encoders/decoders.
    Shaders calc speed
    692 x 536 - 59K
    693 x 933 - 73K
    690 x 929 - 81K
  • Reviews are up
  • On architecture
  • On display engine
    Updated DisplayPort 1.4 HDR is now capable of handling 8K displays at 60 Hz with a single cable. It can also handle 4K UHD at 240 Hz with a single cable. Support of HDR and 10-bit color is included. But only using DSC 1.2a (Display Stream Compression). The display controller also supports 30 bpp internal color-depth. The HDMI implementation remains old HDMI 2.0 without any real progress.
    On video decoders and encoders
    GPU provides hardware-acceleration for decoding VP9 video at formats of up to 4K @ 90 fps and 8K @ 24 fps. H.265 HEVC hardware-accelerated encoding of 4K at frame-rates of up to 60 fps is supported. H.265 HEVC decoding is accelerated at 8K @ 24 fps, and 4K @ 90 fps or 1080p at up to 360 fps. H.264 MPEG4 supports 4K @ 150 fps, and 1080p @ 600 fps decoding; and 4K @ 90 fps and 1080p @ 150 fps encoding.
    Progress is really small and do not see any AV1 implementation here.
    800 x 320 - 40K
    800 x 361 - 45K
  • RX 5700 XT is priced at $449, and RX 5700 at $379.
  • Note that AMD wants to tie you to proprietary subscription cloud for ray tracing in the future
    800 x 437 - 43K
  • Navi also boasts an improved video engine. It can now accelerate VP9 decode at up to 4K90 and 8K24; H.264 decode at 1080p600 and 4K150; encode at 1080p360 and 4K90; H.265 decode at 1080p360, 4K90, and 8K24; and encode at 1080p360 and 4K60. Encoder speed-ups are reportedly as high as 40%.
    800 x 487 - 44K
    800 x 602 - 72K
    800 x 464 - 34K
    753 x 905 - 109K
    800 x 397 - 55K
    800 x 428 - 42K
    800 x 423 - 42K
  • Radeon RX 5700 XT Specs
    • 40 Compute Units
    • 2560 stream processors
    • 1605 MHz in base mode
    • 1755 MHz in Game Mode
    • 1905 MHz in boost mode.
    • 8GB of GDDR6 memory
    800 x 204 - 48K
  • Another failure? Or mining could save them?
  • Asrock prototype cards
    Power consumption will be 225W for better and cheaper one will eat 180W.
    But even best seems to be only RTX 2070 competitor.
    800 x 432 - 80K
    800 x 393 - 59K
    800 x 372 - 48K
