AMD AM4 Motherboards Selection Guide for Video Editors
  • Topic solely for selection of motherboard for your AM4 Ryzen CPU based system.
    Focused on video editor needs
    I'll be adding systematic info post by post.
    Ideal modern video editor motherboard must allow:
    • Work with overclocked 8 core CPUs fine without VRM issues, preferably be ready for upcoming 16 core chips
    • Have ability to install pair of NVMe x4 SSD drives (one can be using PCIe 2.0), M.2 slot not located under GPU hot air is big plus!
    • Have pair of USB 3.1 Gen2 10Mbit ports so you can transfer data from/to your fast SSD quick - check more . Front panel connector is also big plus.
    • Have or allow to install 10Gbit Ethernet/56Gbit Infiniband network adapter to quickly use directly or dump large amount of footage at NAS/Server.
    • Have proper slots alignment taking in account that some good GPUs have 2.5 slot sized cooling.
    • Installing 2nd GPU always leads to lot of compromises on this platform, but if this is performance bottleneck - go for it.
    Best CPU info
    We are searching board for 8-16 core CPUs, it is not much reason to look for other CPUs.
    Ryzen is gaming/consumer CPU with serious IO shortcomings by design (but less serious compared to Intel consumer line).
    • Ryzen chips have 24 PCIe v3.0 lines.
    • 4x goes to NVMe slot of board (Intel lacks this).
    • 16x go to GPU - and this one on A320 and B350/450 can't be split (aka bifurcation), to force MB makers to buy more expensive chipsets for SLI.
    • 4x is left for the chipset (on Intel it is same). Chipset uses them for lot of things, including making multiple PCIe 2.0 (or PCI 4.0 for X570) lines.
    Note Actual Ryzen 1xxx or 2xxx die has full 32 PCIe 3.0 lines, but it had been decided that it will be too nice to allow consumer PCs to use them all. References that somehow AMD does not have free pins in socket is absolute bullshit.
    Note! Ryzen 2200G or 2400G are designed such way that they provide only 8 PCIe 3.0 lines to GPU instead of 16x and they can't be split.
    So, forget about idea of using them for any advanced tasks.
    Chipset difference
    If you look carefully you understand that you must avoid B350/B450 chipsets at all cost, not mentioning A320.
    • First reason - they do not allow to split x16 into two PCIe x8 slots, this is very bad for us* (see note below).
    • Second reason - they have less general purpose PCIe 2.0 lines, 2 less sounds like not much, but it is very important on our limited consumer CPU IO budget.
    Note about bifurcation/split. As usual in capitalism - it is artificially removed and disabled feature. On Asrock ITX B350/B450 boards such options is present and works. It had been done due to large request from users/buyers and some other companies do this (keeping silence so it won't become open knowledge among too many, yet you still need to modify BIOS to enable SLI). But even with such options it is horrible life as you need custom impossible to find riser and turning GPU card into vertical state or such.
    SSD performance limits on Ryzen
    Second M.2 slot on almost all boards where it is present will be using PCIe 2.0 x2 or x4 mode (except x570 chipset!).
    PCIe 2.0 per-lane throughput is 5GT/s or 500MB/s of actual data transfer per lane. x2 will be capped at 1GB/sec recording/reading and x4 at 2GB/sec recording/reading, no matter if the limit of SSD you put in it is higher.
    First M.2 slot uses four dedicated v3.0 lines. Single PCIe 3.0 lane at 8GT/s, can send 985MB/s. This limit is close to 4GB/sec.
    For x570 chipset all lines will be PCI 4.0 lines, double the bandwidth of PCI 3.0.
    Network stuff
    Ideally we want 10Gbit adapter, but most probably you will need free x4 slot for one - check https://www.personal-view.com/talks/discussion/21364/making-10gbit-network-using-sfp-adapters-for-cheap#Item_11
    Among 1Gbit always aim for Intel, it is not much difference but saves little CPU load and lot of your nerves.
  • 31 Replies sorted by
  • Temperatures
    Lot of X370 and X370 boards can run hot if you use overclocking on 8 core CPUs or 12-16 new Ryzen 2 CPUs.
    Main reason for this is simpler and cheaper VRM and also bad heatsinks being just slab of aluminium made be designer without any fine fins.
    Heatsink designs
    In present day it is usually designers who make heatsinks even for expensive motherboards.
    They are made for looks, and not to be efficient in their real function.
    Bad small one (ASUS TUF x470-Plus)
    Better one (ASRock Pro4 boards)
    Almost good (Asrock X470 Taichi Ultimate)
    Really nice (Gigabyte Aorus X470 Gaming 7 WiFi)
    Nice construction features to look for
    Armored PCIe x16 slots
    Nice feature, as it makes it impossible to accidently damage slot pulling big card and forgetting the slot lock.
    Armored memory slots
    Not so important, but makes slots much more reliable and prevent damage during some accident during big cooler mounting. Or if you try to pull stick in small full case.
    AMD B350 Chipset Issues on AsRock B350 Pro 4 motherboard sample
    This motherboards is affordable and frequently recommended by people, so let's see that is main issue.
    You installed good powerful GPU with good cooling, it takes x16 slot and also makes really unusable one PCIe x1 slot.
    You also like fast NVMe SSD for your system drive. So, top M.2 Slot will be filled with it.
    But due to this second x16 looking slot having same PCIe 3.0 lines will be disabled.
    Won't be able to install second GPU, or 10Gbit adapter, or second M.2 adapter.
    Second M.2 is ... SATA only (same on all their B350 boards, they made it better on B450).
    Locations of both M.2 slots are good from thermal point of view.
    Board lacks USB 3.1 Gen2 ports, and you also won't have free slot to put suitable adapter if you use NVME SSD.
    Realtek 1Gbit is not at all bad, but Intel is little better with lower CPU load and drivers.
    Finally - VRM, AB350 Pro4 ISL95712 based 3 x 2 phase design, 3 real phases with double of elements in each one, average coolers. Not bad for cheap MB, but not top solution by far.
    Overall - nice cheap board for gamers, but really bad for any editing guys.
    797 x 736 - 163K
    800 x 519 - 89K
    800 x 407 - 47K
    695 x 611 - 84K
    800 x 474 - 66K
    781 x 710 - 109K
    800 x 590 - 85K
  • Example of really bad AMD x370 board - AsRock Fatal1ty X370 Gaming X
    Lacks USB 3.1 Gen 2 still.
    Big difference is that now if you took up top M.2 slot with SSD you can split x16 slot and into two x8 ones.
    If you do not work with raw 6K/8K it won't be noticeable, otherwise it'll hit performance some.
    Now we go into humble low M.2 slot and it's PCIe 2.0 x2 mode.
    PCIe 2.0 per-lane throughput is 5GT/s or 500MB/s of actual data transfer per lane. So, it is capped at 1Gb/sec recording/reading.
    For comparison - top slot uses four v3.0 lines. Single PCIe 3.0 lane at 8GT/s, can send 985MB/s. It is 4 times more maximum possible speed for SSD, good SSD's are close to this numbers in sequential reading speeds.
    For this board you have to kill a lot of wishes. Can have one high speed NVMe SSD, but forced to use second low speed NVMe SSD, can add 10Gbit network adapter, but forced to use USB 3.1 Gen2 port on your NAS/server.
    Has Intel network adapter, it is little better with lower CPU load and drivers.
    Finally - VRM, AB350 Pro4 ISL95712 based 4 x 2 phase design, 4 real phases with double of elements in each one, below average coolers. Not so good, typical for mainstream x370/x470 boards.
    770 x 620 - 144K
  • Example of almost good affordable board - MSI X370 Gaming Plus / Pro
    It is really affordable board and mostly suit our needs.
    Two USB 3.1 Gen 2 ports are present and it uses good ASMedia ASM2142 x2 PCIe 3.0 controller.
    So, we now need to find place for GPU, pair of NVMe SSDs and 10Gbit controller (as on board we have only 1Gbit Realtek).
    First SSD goes to M.2 slot - and location of this slot is biggest shortcoming of this board, as it is directly under hot GPU. You need either good heatsink for SSD or can use solutions that use M.2 cable and mount in 2.5" place like some Intel Optane drives.
    Second SSD can put into x8 split PCIe second slot and keeps full x4 speed.
    Third PCIe 2.0 x4 slot is good for 10Gbit network adapter.
    Finally - RT8894A based 4 x 2 phase design, 4 real phases with double of elements in each one, average coolers. Typical for mainstream x370/x470 boards.
    And all this for real cheap (price during sales for this is ala $100).
    https://www.amazon.com/MSI-Gaming-Ryzen-X370-Motherboard/dp/B06XQ5V3R4
    799 x 676 - 167K
  • Best affordable board - MSI X470 Gaming Plus
    It is really affordable board and changes made compared to x370 are very good.
    Two USB 3.1 Gen 2 ports are present and it uses ASMedia ASM1143 x2 PCIe 2.0 controller.
    First SSD goes to top M.2 slot - location of this slot is good and it won't be hot as on older board where it is directly under hot GPU.
    You can also use second M.2 slot for SSD - it is x4 PCIe 2.0 one, not fastest but if your drive is slow it can save you little money on PCIe-M.2 card. Note - second M.2 slot use same lines as lowest of cards slots (PCIe 2.0 x4 one).
    And all this for real cheap $129 retail non sales price.
    https://www.amazon.com/MSI-X470GPLUS-Performance-Graphics-Motherboard/dp/B07CF31C1Q/
    722 x 808 - 168K
  • Little hidden secret - aka front USB 3.1 Gen2 connector and USB speed
    If you like to have USB-C Gen2 or USB-A Gen2 connectors you need board with such internal connector.
    Otherwise will need to make some custom good elongation cables and it is easy to mess stuff at 10Gbps.
    Asus for now is best among companies who support such connectors. Usually it is also top and last boards that have it.
    None of board mentioned above has such connector.
    Also around 99% of cases lack build in ports with such connector, so you will need to get separate one.
    https://www.aliexpress.com/item/40cm-USB-3-1-Front-Panel-Header-to-USB-C-Type-C-Female-Extension-Cable-with/32827652345.html
    or for type A
    https://www.aliexpress.com/item/50cm-USB-3-1-type-c-Front-Panel-male-to-USB-3-0-Type-A-Female/32858440937.html
    Note that some or all ports can be also implemented using ASMedia ASM1143/AMS1142 chips
    They can't reach USB 3.1 Gen2 speed limit due to bus constrain.
    for comparison ASM2142 is better and AMS3142 is best
    On some Asus boards you have rear ports using slower ASMedia controller and front header using internal AMD chipset lines.
    495 x 393 - 47K
    491 x 459 - 20K
    596 x 598 - 60K
    595 x 585 - 64K
  • List of all X370 and X470, only ATX sized motherboards
    I do not include Biostar here.
    Red - something not good or missing feature.
    Blue means - ok or average.
    Teal - above average.
    Green - really good for us.
    Boards go from worst to best in the list for each brand and same chipset.
    AsRock
    • X370 Pro4
      • 3x doubled elements phases CPU VCC, ISL95712 PWM controller, 2xSM4337 (or 2xPZ0903BK) and 2xSM4336 (or 2xPK618BA) MOSFETS per phase
      • Two average alu heatsinks without heatpipe, all phases covered.
      • 2 PCIe 3.0 x16 (x16/x16+x4), 4 PCIe 2.0 x1
      • Second PCIe 3.0 x16 uses same as 1st M.2 lines!
      • 1 M.2 (PCIe 3.0 x4), ), located above GPU slot
      • 1 M.2 (PCIe Gen2 x2 & SATA3)
      • Realtek ALC892 Audio
      • Realtek RTL8111H LAN
      • No USB 3.1 Gen2 ports
      • No USB 3.1 Gen2 internal connector
      • Unsure about "voltage offset" option
      • No BCLK Overclock
      • 128Mb BIOS Chip
    • X370 Killer SLI and WiFi ac version
      • 4x doubled elements phases CPU VCC, IR35201 PWM controller, 2xSM4337 (or 2xPZ0903BK) and 2xSM4336 (or 2xPK618BA) MOSFETS per phase
      • Two designer made alu heatsinks without heatpipe, all phases covered.
      • 2 PCIe 3.0 x16 (x16/x8+x8), 4 PCIe 2.0 x1
      • Intel Gigabit LAN
      • No BCLK Overclock
      • 128Mb BIOS Chip
    • Fatal1ty X370 Gaming X
      • 4x doubled elements phases CPU VCC, ISL95712 PWM controller, 2xSM4337 (or 2xPZ0903BK) and 2xSM4336 (or 2xPK618BA) MOSFETS per phase
      • Realtek ALC1220 Audio
      • Intel Gigabit LAN
      • Has "voltage offset" option, but has some issues
      • No BCLK Overclock
      • 128Mb BIOS Chip
    • Fatal1ty X370 Gaming K4
      • Intel Gigabit LAN
      • Two USB 3.1 Gen2 ports, A and C type, using X370 controller
      • No BCLK Overclock
      • 128Mb BIOS Chip
    • X370 Taichi
      • 6x phases via real IR3598 doublers CPU VCC making it total 12x, IR35201 PWM controller, CSD 87350 Buck NexFET Power Blocks for each phase - total 12x
      • Two bad designer made alu heatsinks with heatpipe being in the middle of heatsinks, all phases covered.
      • 2 PCIe 3.0 x16 (x16/x8+x8), 1 PCIe 2.0 x16 (x4), 2 PCIe 2.0 x1
      • 1 M.2 (PCIe Gen2 x4 & SATA3)
      • Realtek ALC1220 Audio+Amplifier for Front Panel
      • Intel Gigabit LAN
      • Must have "voltage offset" option
      • Has BCLK Overclock
    • Fatal1ty X370 Professional Gaming
      • AQUANTIA AQC108 5G LAN, speed here is limited by PCIe lines
      • Intel Gigabit LAN
    • ------ NEXT ARE X470 BOARDS ---------
    • X470 Master SLI and WiFi version
      • Intel Gigabit LAN
      • Two USB 3.1 Gen2 ports, A and C type, using X470 controller
      • No BCLK Overclock
      • 256Mb BIOS Chip
    • X470 Fatal1ty Gaming K4
      • Intel Gigabit LAN
      • No BCLK Overclock
      • 256Mb BIOS Chip
    • X470 Taichi
      • Intel Gigabit LAN
      • 256Mb BIOS Chip
    • X470 Taichi Ultimate
      • 10G LAN adapter AQUANTIA AQC10
      • 2nd Intel Gigabit LAN
      • USB 3.1 Gen2 front panel connector via ASMedia ASM3142
      • 256Mb BIOS Chip
    • ASUS
      • Prime Prime X370-A
        • 4x phases CPU VCC with doubled low side, ASP1106GGQW PWM controller, 4C09B and 2 x 4C06B MOSFETS per phase
        • Two quite small alu heatsinks but with more fins, without heatpipe, all phases covered.
        • 1 PCIe 3.0 x16, 1 PCIe 2.0 x16 (x4), 2 PCIe 2.0 x1, 2 PCI
        • 1 M.2 (PCIe 3.0 x4 and SATA), located above GPU slot
        • Realtek ALC887 Audio
        • Two USB 3.1 Gen2 ports, Type A, via X370 chipset
        • No "voltage offset" option
        • No BCLK Overclock
        • 128Mb BIOS Chip ?
      • Prime X370-Pro
        • 6x phases CPU VCC, ASP1405I PWM controller, CSD 87350 Buck NexFET Power Blocks for each phase
        • Two designer made alu heatsinks with more fins, without heatpipe, all phases covered.
        • 2 PCIe 3.0 x16 (x16/x8+x8), 1 PCIe 2.0 x16 (x4), 3 PCIe 2.0 x1
        • 1 M.2 (PCIe 3.0 x4 and SATA), located low at MB
        • Realtek ALC1220A Audio
        • Intel Gigabit LAN
        • Two USB 3.1 Gen2 ports, Type A, via ASMedia controller
        • One USB 3.1 Gen2 internal connector for Type C port via X370 chipset
        • No BCLK Overclock
        • 128Mb BIOS Chip ?
      • Strix X370-F Gaming
        • 6x phases CPU VCC, ASP1405I PWM controller, IR3555 integrated PowIRstage for each phase
        • Two bad designer made alu heatsinks, without heatpipe, all phases covered.
        • Realtek ALC1220A Audio with dual amplifiers
        • Intel Gigabit LAN
        • Two USB 3.1 Gen2 ports, Type A and Type C, via ASMedia 1142 controller
        • 128Mb BIOS Chip ?
      • X370 ROG Crosshair VI Hero and WiFi Version
        • 4x phases via real IR3598 doublers CPU VCC making it total 8x phases, ASP1405I PWM controller, CSD 87350 Buck NexFET Power Blocks for each phase
        • Two bad designer made alu heatsinks with heatpipe, all phases covered.
        • Realtek ALC1220A + ES9023P DAC, with dual amplifiers
        • Intel Gigabit LAN
        • 128Mb BIOS Chip ?
      • X370 ROG Crosshair VI Extreme
        • 4x phases via real IR3598 doublers CPU VCC making it total 8x phases, ASP1405I PWM controller, IR3555 integrated PowIRstage for each phase
        • 1 M.2 (PCIe 3.0 x4), located near SATA ports, shared bandwidth with second PCIe x16 slot
        • Intel Gigabit LAN
        • One USB 3.1 Gen2 internal connector for Type C port via ASMedia chipset
        • 128Mb BIOS Chip ?
      • X470 TUF Plus Gaming
        • 4x phases CPU VCC with doubled low side, ASP1106GGQW PWM controller, 4C10B and 2 x 4C06B MOSFETS per phase
        • Two quite small designed made alu heatsinks, without heatpipe, all phases covered.
        • 1 PCIe 3.0 x16, 1 PCIe 2.0 x16 (x4), 4 PCIe 2.0 x1
        • 1 M.2 (PCIe 3.0 x2 and SATA), located in low part of the board
        • Two USB 3.1 Gen2 ports, Type A, via X470 chipset
        • No BCLK Overclock
        • 128Mb BIOS Chip ?
      • X470 Prime Pro
        • Intel Gigabit LAN
        • One USB 3.1 Gen2 internal connector for Type C port via x470 chipset
        • No BCLK Overclock
        • 128Mb BIOS Chip ?
      • X470-F ROG Strix Gaming
        • Two designer made alu heatsinks, without heatpipe, all phases covered.
        • Intel Gigabit LAN
        • One USB 3.1 Gen2 internal connector for Type C port via X470 chipset
        • 128Mb BIOS Chip ?
      • X470 ROG Crosshair VII Hero and WiFi/ac version
        • 5x phases via real IR3599 doublers CPU VCC making it total 10x phases, ASP1405I PWM controller, IR3555 integrated PowIRstage for each phase
        • 1 M.2 (PCIe 3.0 x4), located in low part of the board
        • Intel Gigabit LAN
        • 128Mb BIOS Chip ?
  • Gigabyte
    • Aorus GA-AX370-Gaming 5
      • 6x phases CPU VCC, IR35201 PWM controller, IR3555 integrated PowIRstage for each phase
      • 1 M.2 (PCIe 3.0 x4 and SATA), located in hot area under GPU slot
      • Realtek ALC1220A
      • Intel Gigabit LAN
      • Killer E2500 LAN
      • 2x128Mb BIOS Chips
    • Aorus GA-AX370-Gaming K3
      • 4x phases CPU VCC with doubled low side MOSFETs, ISL95712 PWM controller, 4C10N and 2x4C06N MOSFETS per phase
      • 1 PCIe 3.0 x16, 1 PCIe 2.0 x16 (x4), 3 PCIe 2.0 x1
      • Realtek ALC1220A
      • Killer E2500 LAN
    • Aorus GA-AX370-Gaming K5
      • Realtek ALC1220A
      • Intel Gigabit LAN
      • Two USB 3.1 Gen2 ports, Type A, and C, via ASMedia controller
    • Aorus GA-AX370-Gaming K7
      • Realtek ALC1220A
      • Intel Gigabit LAN
      • Killer E2500 LAN
    • Aorus X470 Ultra Gaming
      • 4x phases CPU VCC with doubled elements, ISL95712 PWM controller, 2x4C10N and 2x4C06N MOSFETS per phase
      • 1 M.2 (PCIe 2.0 x4 without SATA support), located low on the board
      • Realtek ALC1220A
      • Intel Gigabit LAN
      • Two USB 3.1 Gen2 ports, Type A and C, via ASMedia controller
    • X470 Aorus Gaming 5 WiFi
      • Two designer made alu heatsinks with heatpipe, all phases covered.
      • Realtek ALC1220A
      • Intel Gigabit LAN
    • Aorus X470 Gaming 7 WiFi
      • 5x phases via real IR3599 doublers CPU VCC making it total 10x phases, IR35201 PWM controller, IR3555 integrated PowIRstage for each phase
      • Two nice heatsinks with lot of fins and heatpipe, all phases covered.
      • Realtek ALC1220A+ES9118 DAC
      • Intel Gigabit LAN
  • MSI
    • X370 Gaming Plus
      • 4x phases CPU VCC with doubled elements, RT8894A PWM controller, 2xPK616BA and 2xPK632BA MOSFETS per phase
      • Two designer made alu heatsinks with slightly more fins, without heatpipe, all phases covered.
      • 2x PCIe 3.0 x16 (x16/x8+x8), 1x PCIe 2.0 x16 (x4 mode), 3x PCIe 2.0 x1
      • 1x M.2 (PCIe 3.0 x4 and SATA3), located in hot area under GPU slot
      • Realtek 8111HLAN
      • Two USB 3.1 Gen2 ports, A and C Type, using ASM2142
      • No BCLK Overclock
      • 128Mb BIOS Chip
    • X370 Gaming Pro
      • 1x M.2 (PCIe 3.0 x4 and SATA), located in hot area under GPU slot
      • Realtek 8111HLAN
      • No BCLK Overclock
      • 128Mb BIOS Chip
    • X370 SLI Plus
      • Realtek 8111HLAN
      • No BCLK Overclock
      • 128Mb BIOS Chip
    • X370 Krait Gaming
      • 2x PCIe 3.0 x16 (x16/x8+x8), 1x PCIe 2.0 x16 (x4 mode), 3 PCIe 2.0 x1
      • Realtek 8111HLAN
      • No BCLK Overclock
      • 128Mb BIOS Chip
    • X370 Gaming Pro Carbon and X370 Gaming Pro Carbon AC
      • Two horrible designer made alu heatsinks, without heatpipe, all phases covered.
      • 2x PCIe 3.0 x16 (x16/x8+x8), 1x PCIe 2.0 x16 (x4 mode)[shared], 3x PCIe 2.0 x1
      • 1x M.2 (PCIe 2.0 x4 and SATA), located lower on the board. Uses same lines with PCIe 2.0 x16 slot
      • Realtek ALC1220Audio
      • Intel I211AT Gigabit Lan
      • No BCLK Overclock
      • 128Mb BIOS Chip
    • X370 XPower Gaming Titanium
      • 6x phases CPU VCC with doubled low side MOSFETs, IR35201 PWM controller, PK616BA and 2xPK632BA MOSFETS per phase
      • Two average alu heatsinks with more fins and heatpipe, all phases covered. Covered partially by designers shit.
      • 2x PCIe 3.0 x16 (x16/x8+x8), 1x PCIe 2.0 x16 (x4 mode)[?shared], 3x PCIe 2.0 x1
      • 1x M.2 (PCIe 2.0 x4 and SATA), located lower on the board. Can use same lines with PCIe 2.0 x16 slot
      • 1x U2 (PCIe 3.0 x4) port
      • One USB 3.1 Gen2 Type C port via internal connector
      • No BCLK Overclock
      • 128Mb BIOS Chip
    • X370 Gaming M7 ACK
      • 5x phases via real IR3598 doublers CPU VCC making it total 10x phases, IR35201 PWM controller, PK616BA and 2xPK632BA MOSFETS per phase
      • Two designer made alu heatsinks with some fins and heatpipe, all phases covered. Covered fully by designers shit.
      • Realtek ALC1220 Audio, Dual
      • Killer E2500 Gigabit Lan
      • 128Mb BIOS Chip
    • X470 Gaming Plus
      • 4x phases CPU VCC with doubled elements, RT8894A PWM controller, 2x4C029N and 2x4C024N MOSFETS per phase
      • 1x M.2 (PCIe 3.0 x4 and SATA3), located above GPU slot
      • Realtek 8111HLAN
      • Two USB 3.1 Gen2 ports, 2x A Type, using ASM1143
      • No BCLK Overclock
      • 128Mb BIOS Chip
    • X470 Gaming Pro
      • Realtek 8111HLAN
      • No BCLK Overclock
      • 128Mb BIOS Chip
    • X470 Gaming Pro Carbon AC
      • 5x phases CPU VCC with doubled elements, IR35201 PWM controller, 2x4C029N and 2x4C024N MOSFETS per phase
      • 2x PCIe 3.0 x16 (x16/x8+x8), 1x PCIe 2.0 x16 (x4 mode), 2x PCIe 2.0 x1
      • 1x M.2 (PCIe 3.0 x4 and SATA3), located in hot area below GPU slot
      • Two USB 3.1 Gen2 ports, A and C Type, using x470 chipset
      • No BCLK Overclock
      • 128Mb BIOS Chip
    • X470 Gaming M7 AC
      • 6x phases via real IR3598 doublers CPU VCC making it total 12x phases, IR35201 PWM controller, 4C029N and 4C024N MOSFETS per phase
      • One USB 3.1 Gen2 Type C ports via internal connector using ASM1143
      • 128Mb BIOS Chip
  • Asrock and Asus completed two last to follow soon.
  • GREAT. THANKS FOR THIS
  • All heatsinks info added.
  • Useful video on thermals (include actually multiple x470 boards results)
  • Offset voltage and its usage
  • X470 Aorus Gaming Wi-Fi 7 motherboard is first that officially got Gen 4 PCI support if you use Ryzen 2.
    Update (AMD decided to disable such features to sell more very profitable X570 boards):
    800 x 554 - 45K
  • Almost all MB with 128Mb BIOS chips will have old Bristol Ridge CPUs excluded to make room for new Ryzen 3000 models.
  • How to use list above to select MB that will also work nice with 12-16 core Ryzens
    It is all simple, just look for boards where VRM part is colored green, like
    And after this check for BIOS update, as far as I know all 100% green boards will get proper support, and many will get even PCIe 4.0.
    835 x 246 - 58K
  • X570 boards
    ASRock
    • X570 Pro4, $169 at https://www.newegg.com/p/N82E16813157886
      • 4x phases via real UP1961SQ doublers CPU VCC making it total 8x phases, UP9505PQGW PWM controller, SM4337 and SM4336 MOSFETS per phase
      • Large designer made alu heatsink, without heatpipe, SOC phases not covered.
      • 2 PCIe 4.0 x16 (x16/x16+x4), second slot via chipset
      • 2 PCIe 4.0 x1 slots
      • 1 M.2 (PCIe 4.0 x4 and SATA), located in hot area under GPU slot
      • 1 M.2 (PCIe 4.0 x4 and SATA), located lower on the board
      • Realtek ALC1200
      • Intel I211AT Gigabit LAN
      • Two USB 3.1 Gen2 ports, Type A + Type C, via ASMedia controller
      • Thunderbolt AIC Connector
      • 8 SATA ports
      • 256Mb BIOS Chip
    • X570 Extreme4 and wifi, $239 at https://www.newegg.com/p/N82E16813157888
      • 4x phases via real ISL6617A doublers CPU VCC making it total 8x phases, ISL69147 PWM controller, SiC634 integrated power stage for each phase
      • Two small designer made alu heatsinks, without heatpipe, all phases covered.
      • 3 PCIe 4.0 x1 slots
      • Realtek ALC1220
      • USB-C USB 3.1 Gen1 internal connector
      • 8 SATA ports
      • 256Mb BIOS Chip
    • X570 Phantom Gaming 4, $154 at https://www.newegg.com/p/N82E16813157884
      • Realtek ALC1220
      • 8 SATA ports
      • 256Mb BIOS Chip
    • X570 Steel Legend and WiFI, $199 at https://www.newegg.com/p/N82E16813157885
      • Realtek ALC1220+NE5532 Premium Headset Amplifier
      • 8 SATA ports
      • 256Mb BIOS Chip
    • X570 Taichi, $199 at https://www.newegg.com/p/N82E16813157883
      • 6x phases via real ISL6617A doublers CPU VCC making it total 12x phases, ISL69147 PWM controller, SiC634 integrated power stage for each phase
      • Two designer made alu heatsinks, with heatpipe, all phases covered.
      • 3 PCIe 4.0 x16 (x16/x8+x8 and x4 from chipset)
      • 8 SATA ports
      • 256Mb BIOS Chip
    • X570 Phantom Gaming X, $349 at https://www.newegg.com/p/N82E16813157882
      • Realtek RTL8125AG 2.5 Gigabit LAN
      • 8 SATA ports
      • 256Mb BIOS Chip
    • X570 Creator
      • 6x phases via real IR3599 doublers CPU VCC making it total 12x phases, IR35201PWM controller, IR3555 integrated PowIRstage for each phase
      • 2xThunderbolt 3 interfaces
      • Realtek ALC1220
      • Aquantia ACQ107 10 Gigabit LAN
      • Nine USB 3.1 Gen2 ports, 7 x Type A, 2x Type C, via chipset and ASMedia controller
      • 8 SATA ports
      • 256Mb BIOS Chip
    • X570 Aqua
      • Water cooling.
      • Realtek ALC1220
      • Six USB 3.1 Gen2 ports, 4 x Type A, 2x Type C, via chipset and ASMedia controller
      • 8 SATA ports
      • 256Mb BIOS Chip
  • ASUS
    • TUF Gaming X570-Plus and WiFi, $189 at https://www.newegg.com/p/N82E16813119198
      • 6x phases CPU VCC, ASP1106GGQW PWM controller, 2xSiC639 integrated power stage for each phase
      • 1 M.2 (PCIe 4.0 x4 and SATA), located in above top GPU slot
      • Realtek ALC1200 Audio
      • Realtek L8200A LAN
      • Three USB 3.1 Gen2 ports, 2xType A + Type C, via ASMedia controller
      • 6 SATA ports
      • 256Mb BIOS Chip
    • Prime X570-P, $169 at https://www.newegg.com/p/N82E16813119199
      • 4x phases CPU VCC, ASP1106GGQW PWM controller, 2xSiC639 integrated power stage for each phase
      • Four USB 3.1 Gen2 ports, 4xType A, via ASMedia controller
      • 6 SATA ports
      • 256Mb BIOS Chip
    • Prime X570-Pro, $249 at https://www.newegg.com/p/N82E16813119196
      • 3 PCIe 4.0 x16 (x16/x8+x8) and x4 from chipset
      • Four USB 3.1 Gen2 ports, 3xType A + Type C, via ASMedia controller
      • 6 SATA ports
      • 256Mb BIOS Chip
    • ROG STRIX X570-F GAMING, $299 at https://www.newegg.com/asus-rog-strix-x570-f-gaming/p/N82E16813119195
      • 8 SATA ports
      • 256Mb BIOS Chip
    • ROG STRIX X570-E GAMING, $329 at https://www.newegg.com/asus-rog-strix-x570-e-gaming/p/N82E16813119111
      • 6x phases via real IR3599 doublers CPU VCC making it total 12x phases, ASP1405I controller, IR3555 integrated PowIRstage for each phase
      • Realtek ALC1220 Audio with amplifiers
      • 8 USB 3.1 Gen2 ports, 7xType A + Type C, via ASMedia controller
      • One USB 3.1 Gen2 Type C port via internal connector using ASM1143
      • 8 SATA ports
      • 256Mb BIOS Chip
    • ROG CROSSHAIR VIII HERO, $359 at https://www.newegg.com/asus-rog-crosshair-viii-hero/p/N82E16813119110
      • 7x phases via real IR3599 doublers CPU VCC making it total 14x phases, ASP1405I controller, IR3555 integrated PowIRstage for each phase
      • 1 PCIe 4.0 x1 slot
      • Realtek ALC1220 Audio+ESS® ES9023P
      • 8 SATA ports
      • 256Mb BIOS Chip
    • Pro WS X570-ACE , $379 at https://www.newegg.com/p/N82E16813119194
      • 1 U2 (PCIe 3.0 x4), located lower on the board
      • One U.2 PCI 3.0 x4 Connector
      • Realtek RTL8117 LAN
      • Five USB 3.1 Gen2 ports, 4xType A + Type C, via ASMedia controller
      • 4 SATA ports
      • 256Mb BIOS Chip
    • ROG CROSSHAIR VIII HERO WiFi, $453 at https://www.newegg.com/asus-rog-crosshair-viii-hero/p/N82E16813119109
      • 8 SATA ports
      • 256Mb BIOS Chip
    • ROG CROSSHAIR VIII FORMULA, $699 at https://www.newegg.com/asus-rog-crosshair-viii-formula/p/N82E16813119104
      • Aquantia AQC111C 5 Gigabit LAN
      • 8 SATA ports
      • 256Mb BIOS Chip
  • Great thread, thanks a lot VK!
  • Some ASUS boards support PCI-Express 4.0, as manufacturer did not followed AMD recommendations for now
    After it had become known that PCI-Express 4.0 work fine on most boards for two important slots - top PCIe x16 and M2 one (even x370) AMD and leading vendors went into marketing panic mode.
    As they made special cartel agreement to keep X570 board margins around 5x (yes target point had been 5 times more profits for both AMD and companies) compared to X470 ones.
    So having 4.0 working could impact x570 sales a lot, as around 5% of people use second GPU now. And only around 0.2-0.5% will use two of them that support 4.0 version.
    Also note that B450 boards actually have better x16 version working as all lines go direct, while on X470 boards half of signals go via Asmedia switchers, hence you can't have 4.0 working, as switchers can work only in 3.0 mode.
    734 x 669 - 94K
  • Updated VRM info to actual state for ASUS and Asrock X570 boards.
    MSI and Gigabyte will be posted soon.
  • Updated all slots, audio and minor things with official specs for ASUS and Asrock X570 boards.
  • MSI X570
    • X570-A PRO, $159 at https://www.newegg.com/p/N82E16813144263
      • 4x phases via real IR3598 doublers CPU VCC making it total 8x phases, IR35201 controller, 4C029N and 4C024N MOSFETS per phase
      • Two medium designer made alu heatsinks, without heatpipe, all phases covered.
      • 1 M.2 (PCIe 4.0 x4 and SATA), located above top GPU slot
      • Realtek 8111H Gigabit LAN
      • 6 SATA ports
      • 256Mb BIOS Chip
    • MPG X570 GAMING PLUS , $169 at https://www.newegg.com/p/N82E16813144262
      • 6 SATA ports
      • 256Mb BIOS Chip
    • MPG X570 GAMING EDGE WIFI , $209 at https://www.newegg.com/p/N82E16813144261
      • 6 SATA ports
      • 256Mb BIOS Chip
    • MPG X570 GAMING PRO CARBON WIFI, $259 at https://www.newegg.com/p/N82E16813144260
      • 5x phases via real IR3598 doublers CPU VCC making it total 10x phases, IR35201 controller, QA3111N6N dual N MOSFET per phase
      • Four USB 3.1 Gen2 ports, 3xType A + Type C, via CPU and x570 chipset
      • 6 SATA ports
      • 256Mb BIOS Chip
    • MEG X570 ACE Gaming, $369 at https://www.newegg.com/p/N82E16813144259
      • 6x phases via real IR3599 doublers CPU VCC making it total 12x phases, IR35201 controller, IR3555 integrated PowIRstage for each phase
      • Two medium designer made alu heatsinks, with heatpipe, all phases covered.
      • 1 M.2 (PCIe 4.0 x4), located above top GPU slot
      • Realtek RTL8125 2.5 Gbps LAN
      • 4 SATA ports
      • 256Mb BIOS Chip
    • PRESTIGE X570 CREATION, $499 at https://www.newegg.com/p/N82E16813144258
      • 4 PCIe 4.0 x1 slots
      • 1 M.2 (PCIe 4.0 x4), located below hot GPU slot area
      • Aquantia AQC107 10-Gigabit LAN
      • Two USB 3.1 Gen2 ports, Type A + Type C, via Ryzen processor
      • 6 SATA ports
      • 256Mb BIOS Chip
    • MEG X570 GODLIKE Gaming, $699 at https://www.newegg.com/p/N82E16813144257
      • 7x phases via real IR3599 doublers CPU VCC making it total 14x phases, IR35201 controller, TDA21472 integrated 70A power stage for each phase
      • 3 PCIe 4.0 x16 (x16/x8+x8/x8/x4/x4)
      • 1 PCIe 4.0 x16 in x4 mode slot, from chipset
      • Realtek ALC1220 + E9018 DAC Audio
      • Killer E2600 Gigabit LAN
      • Killer E3000 2.5 Gbps LAN
      • Four USB 3.1 Gen2 ports, 3xType A + Type C, via chipset and Ryzen processor
      • 6 SATA ports
      • 256Mb BIOS Chip
