Specifications
More info at http://www.getolympus.com/digitalcameras/omd/e-m1-mark-ii.html
Olympus OM-D E-M1 Mark II for $899
Here's a video I did a while ago with the E-M1 MK2 and the PRO primes, shooting to the internal 4K codec. I left an ungraded window so you can see how it looks in the FLAT setting out of camera. (this evolves into the LOG 400)
Olympus is pleased to announce availability of the latest firmware upgrade for two interchangeable lens cameras, Version 3.0 for the Olympus OM-D E-M1 Mark II and Version 1.1 for the Olympus OM-D E-M1X. Additionally, Firmware Version 1.1 is now available for Olympus Workspace. OM-D E-M1 Mark II firmware Version 3.0 adds high-precision autofocus (AF) performance and the high image quality currently available on Olympus' newest OM-D, the E-M1X. Specifically designed for the professional models in the OM-D series, the OM-D E-M1 Mark II and OM-D E-M1X, this new firmware provides feature enhancements for photographers who require portability and smooth operation of the camera when shooting.
OM-D E-M1 Mark II Firmware Version 3.0: Main Features
Advanced AF Performance
This upgrade utilizes the OM-D E-M1X algorithm, which was developed based on the shooting needs of the professional photographer. With the goal of achieving performance that responds to demanding shooting conditions, such as fast movement in sports, etc., C-AF Center Priority delivers high-precision tracking of moving subjects and sudden subject movement. AF precision for still subjects when using S-AF is improved for various subjects compared to OM-D E-M1 Mark II firmware Version 2.3. Active use of information from the On-chip Phase Detection AF sensor also improves AF performance while shooting video.
Newest AutoFocus Features
Group 25-point has been added to AF Target, and is effective for photographing birds and other small subjects. C-AF Center Priority is now available, and repeatedly autofocuses with priority on the center point in Group 5-point, Group 9-point, and Group 25-point. If AF is not possible in the center point, the peripheral points in the group area assists, which is effective for subjects that move around quickly. In addition, C-AF+MF^1^ is included which allows users to instantly switch to MF by turning the focus ring while in C-AF for fine tuning the focus.
Low Light Limit Update
The AF low light limit when an f/1.2 lens is attached is -6.0 EV (ISO 100 equivalent for S-AF), enabling high precision focusing in both dark scenes and for low-contrast subjects.
Improved Image Quality
Low ISO Processing (Detail Priority) has been added for higher resolution when shooting at low ISO sensitivity , making it possible to reduce noise while shooting with low ISO settings. Compared with OM-D E-M1 Mark II firmware Version 2.3, noise that occurs when shooting at high ISO sensitivity is improved approximately 1/3 of a step.
Support for New Functions in Olympus Workspace
USB RAW Data Edit is now supported for much faster RAW processing in Olympus Workspace by connecting the camera to a computer to use the power of the OM-D E-M1 Mark II TruePic™ VIII image processor.
Enhanced Operability
- Anti-flicker shooting added to prevent unstable exposure, particularly when sequential shooting indoors.
- OM-Log400 movie-exclusive picture mode added, allowing the user to shoot movies without loss of details in shadows or highlight blowouts, delivery greater freedom over video creativity through color grading.
- Frame Rate Priority added to Live View Boost/On2 display, displaying images at a comfortable brightness, even in especially dark locations, such as under a starlit sky without lowering the frame rate.
- From 3 to 15 shots can be selected in Focus Stacking and guide lines have been added to the shooting area
- Quick image selection added
- Setting changes and playback display while writing to card now possible, facilitating quick operation.
- Instant Film added to Art Filter
- ISO L100 (ISO 100 equivalent) added
12-200mm kit available now in US
https://www.bhphotovideo.com/c/product/1479105-REG/olympus_v207062bu000_om_d_e_m1_mark_ii.html
Limited edition OM-D E-M1 Mark II camera
Horrible way to celebrate 100th anniversary.
Olympus is pleased to announce a special edition of the OM-D E-M1 Mark II, the OM-D E-M1 Mark II Silver. This limited edition model, of which only 2,000 units will be available worldwide, will be available at the end of February 2019, in commemoration of Olympus' 100th anniversary.
From Olympus President Hiroyuki Sasa:
We are sincerely grateful to all customers and other stakeholders who have supported Olympus since its founding 100 years ago. Being true to our purpose of "making people's lives healthier, safer, and more fulfilling," we shall continue to contribute to photographic culture and deliver the joy of capturing and expressing special moments to photography lovers worldwide.
TruePic VIII Image Processor and 20.4 Megapixel Live MOS Sensor
The OM-D E-M1 Mark II features the TruePic VIII Image Processor, which makes it possible to capture images with minimal noise while retaining details. Furthermore, the 20.4 Megapixel Live MOS sensor with 121 points of cross-type on-chip phase detection improves resolution without the need for a low-pass filter. This synergy maintains the full 20.4 Megapixel image while offering up to 18 fps high-speed sequential shooting performance in AF/AE tracking. It also enhances gradation through pixel characteristic improvement for a wide dynamic range that rivals that of cameras with larger sized APS-C sensors. Pro Capture Mode is also included and allows lag-free shooting of split-second moments as full resolution images, attaining both high-speed and excellent image quality.
In-Body 5-Axis Image Stabilization
The OM-D E-M1 Mark II is equipped with built-in 5-Axis Image Stabilization to compensate for camera shake. Through an optimized correction algorithm, this model boasts 5.5 shutter speed steps of compensation performance. Furthermore, when combined with an M.Zuiko lens containing in-lens image stabilization2, 5-Axis Sync IS provides up to 6.5 shutter speed steps of compensation performance for hand-held shooting capabilities.
A Compact, Lightweight, Durable System Offering Unparalleled Reliability
The OM-D E-M1 Mark II features sealing throughout the camera for a highly reliable dustproof, splashproof and freezeproof (14°F / -10°C) design so that the camera performs even in the harshest outdoor conditions, such as snow or rain.
Premium Silver Body
The OM-D E-M1 Mark II is a dependable camera that meets the needs of the professional photographer and is capable of shooting in the harshest of environments. The black body embraces functional beauty while the new silver body provides a classic, quality camera look.
New firmware v2.3
- Wireless radiowave commander FC-WR is now supported.
- Stability of operation when using SD card (UHS-II) has been improved.
https://cs.olympus-imaging.jp/en/support/imsg/digicamera/download/software/firm/e1/
Cashback
Olympus launches OM-D E-M1 Mark II promotion: Cashback offer including M.Zuiko PRO lenses
Hamburg, 01. September 2018 - Under the motto "Your trip, our contribution", Olympus today launches a cashback promotion on its flagship system camera model OM-D E-M1 Mark II and most M.Zuiko PRO lenses*: All E-M1 Mark II purchases made between 01.09.2018 and 15.01.2019 are entitled to a cashback reward of 200 EUR. Additionally, customers may add up to three M.Zuiko PRO lenses* to their purchase and save 150 EUR per lens totalling the cashback reward up to 650 EUR.
This limited promotion is the ideal offer for photography professionals and enthusiasts looking to switch or step up to the most mobile interchangeable lens camera system on the market.
Participating countries, registration and terms & conditions at https://bonus.olympus.eu
Olympus OM-D E-M1 Mark II + 32Gb card and other stuff for $1599
