Available for now coupons
Main page - https://sale.aliexpress.com/__pc/2019Mid_YearSale.htm
Coupons center - https://sale.aliexpress.com/__pc/618_coupon_center.htm
Sale is over, but new $5/50 work
Note that may need to have Russian delivery address.
Game where you can win coupons
Kllisre X9A LGA 1356 motherboard for cheap used Xeon CPUs
Nice, 7 phase VRM. But make sure to put some heatsink on VRM if you run top Xeons on it.
Make sure to use $5-7 coupons from topic.
https://www.aliexpress.com/item/32997047877.html
Kllisre X79 motherboard LGA2011 ATX
Very popular board with nice proper VRM and heatsink.
FeiyuTech G6 Plus 3-Axis G6P Handheld Gimbal for very good price
Use $18 of Select coupons, $15 seller discount, and $5/50 coupons in topic above.
FeiyuTech Vimble 2 Smartphone Gimbal for below $70
Use $6 of select coupons, $2 seller coupon and $5/50 coupons in topic above.
BOYA BY-WFM12 VHF Wireless Lavalier Microphone
Use $6 of select coupons, $1 seller discount and $5/50 coupons in topic above.
Very nice price overall.
As far as I know it is really reliable thing, not high end, but works good.
ZHIYUN Official Smooth 4 below $100
First, use $6/65 select coupons.
Add to this $2 seller coupon.
And add to this $5-7 coupons from topic.
Top DAC/Preamp
Very good product made by good engineers.
$6/65 select coupons work, $2 store coupon, as well as any universal coupons from this topic.
https://www.aliexpress.com/item/32956563439.html
Some measurements can be checked at https://www.personal-view.com/talks/discussion/20885/topping-dx3-pro-dac-and-headhone-amp-recommend/p1
New promocodes $7/$60
Work for Russian delivery address.
https://best.aliexpress.com/?lan=en
General coupons for $5/$50
You need to get select coupons (three will be enough), it is easy
After this look for coupons in this topic posted early.
They will sum up.
Aliexpress frequently now show short order window, look at the bottom of window to show full version, it has all coupons field.
Can I stack coupons for this item? Can't see how to do it.
eVtran really fast flash drive
It is still one of very few options for very fast and steady write speed super portable drives.
As it is effectively SATA MLC drive with fast USB bridge inside little flash drive case.
https://www.aliexpress.com/item/32977697862.html?storeId=2842018
Two high CRI panels set with stands
Deal for US and Russia.
Get $4 seller coupon.
And also $5-7 coupons above in topic.
GPD Pocket 2 Mini PC for $361 only
Use up to $72 in Select Coupons.
Smallest among competition and still useful for checking your videos and even do simple 1080p editing.
Famous Scythe Gentle Typhoon fan
Uses Nidec motor.
It won many tests beating famous Noctua fans. No longer made du to high costs, so it is remaining stock.
You will pass it in working state to your children.
If you get multiple of them can use $6/65 select coupons discount.
Use any coupons that work over $25 sum.
Very good Godox led panel with nice discount
You can deduct $6 via select coupons.
Plus $2 getting select coupon.
As well as another $5-$7 using coupons above in this topic.
AMD Ryzen 5 1600 below $90 with coupon
Very nice overclockable CPU.
Perfect for 1080p and simple 4K editing with good GPU, as well as fast 10Gbit based home NAS/server.
https://www.aliexpress.com/item/32916415126.html?storeId=2855009
Padded tripod/stands bag
Very fast portable 256GB-1TB flash drive
Use seller coupon and coupons above and it'll be price ever for good portable SSD.
120cm motorized slider with smartphone control for $225 and lower
Note - price in title includes only seller coupon and $24 of select coupons applied (see early posts in topic!).
If you'll also use other coupon from this topic it'll be even better. They all sum.
Very nice and cheap led light
Has high CRI, no flicker and nice OLED screen.
Kingston A400 SSD
https://www.aliexpress.com/item/32805591095.html
Netac 960GB SSD for $88 + coupons discount
$2 seller discount plus use any of discounts in this topic.
https://www.aliexpress.com/item/32849610825.html?storeId=3194063
