Very good sunhood for GH cameras
SmallRig Cages - best quality among affordable Chinese made cages
Aputure M9 alternative (CRI also high!)
Kingspec PCIe 512GB SSD for below $60
512GB and 1TB versions are real four channel (4 chips used) 3D TLC drive with PCIe 3.0 x4. This is nice for good write speed.
Add something to $65 to use select coupons, use $2 seller coupons and one of $5/$50 coupons from this topic. Makes price superb.
Boya affordable small wireless digital system
This is new model, check more details at https://www.personal-view.com/talks/discussion/22204/boya-by-wm4-mark-ii-2.4ghz-wireless-microphone#Item_2
Nice USB lavaliere mike with headphone output
Especially good for latest Mac notes users. Heard really good feedback about it.
Godox 60W LED Light for really low price
Personal recommendation, you can check our big topic on it - https://www.personal-view.com/talks/discussion/17664/cheap-powerful-godox-sl60w-led-fresnel-below-199#Item_70
Use all types of coupons - sellers one from items page, select coupons (can use lot of them here) and also coupons from this topic. All of them will sum.
Carbon fiber monopod with legs and ball head
Kingston A400 SSD
https://www.aliexpress.com/item/32805591095.html
Netac 960GB SSD for $88 + coupons discount
$2 seller discount plus use any of discounts in this topic.
https://www.aliexpress.com/item/32849610825.html?storeId=3194063
Very nice and cheap led light
Has high CRI, no flicker and nice OLED screen.
120cm motorized slider with smartphone control for $225 and lower
Note - price in title includes only seller coupon and $24 of select coupons applied (see early posts in topic!).
If you'll also use other coupon from this topic it'll be even better. They all sum.
Very fast portable 256GB-1TB flash drive
Use seller coupon and coupons above and it'll be price ever for good portable SSD.
Padded tripod/stands bag
AMD Ryzen 5 1600 below $90 with coupon
Very nice overclockable CPU.
Perfect for 1080p and simple 4K editing with good GPU, as well as fast 10Gbit based home NAS/server.
https://www.aliexpress.com/item/32916415126.html?storeId=2855009
Very good Godox led panel with nice discount
You can deduct $6 via select coupons.
Plus $2 getting select coupon.
As well as another $5-$7 using coupons above in this topic.
Famous Scythe Gentle Typhoon fan
Uses Nidec motor.
It won many tests beating famous Noctua fans. No longer made du to high costs, so it is remaining stock.
You will pass it in working state to your children.
If you get multiple of them can use $6/65 select coupons discount.
Use any coupons that work over $25 sum.
GPD Pocket 2 Mini PC for $361 only
Use up to $72 in Select Coupons.
And also $5-7 coupons above in topic.
Smallest among competition and still useful for checking your videos and even do simple 1080p editing.
Two high CRI panels set with stands
Deal for US and Russia.
Get $4 seller coupon.
eVtran really fast flash drive
It is still one of very few options for very fast and steady write speed super portable drives.
As it is effectively SATA MLC drive with fast USB bridge inside little flash drive case.
https://www.aliexpress.com/item/32977697862.html?storeId=2842018
Can I stack coupons for this item? Can't see how to do it.
You need to get select coupons (three will be enough), it is easy
After this look for coupons in this topic posted early.
They will sum up.
Aliexpress frequently now show short order window, look at the bottom of window to show full version, it has all coupons field.
New promocodes $7/$60
Work for Russian delivery address.
https://best.aliexpress.com/?lan=en
General coupons for $5/$50
