Panasonic L mount teleconverters
  • 1.4x converter
    • 7 in 4 groups (including 2 UHR lenses)
    • Dustproof, dripproof, -10 degrees low temperature resistance
    • Correspondence lens: LUMIX S PRO 70-200mm F4 O.I., 70-200mm F 2.8 (scheduled release in 2019)
    2.0x converter
    • 8 in 4 groups (including 2 UHR lenses)
  • 2 Replies sorted by
    800 x 727 - 63K
    800 x 496 - 35K
  • Panasonic LUMIX announces new 1.4x and 2x teleconverters for LUMIX S telephoto zoom lenses
    They can be attached to the LUMIX S PRO 70-200mm F4 O.I.S. (S-R70200)1 enabling use as a super telephoto lens with its extended zoom range up to a maximum of 400mm with high-speed, high-precision AF. The rugged dust/splash-resistant2 design withstands use under harsh conditions even in 10 degrees below zero for high mobility.
    Both teleconverters DMW-STC14 and DMW-STC20 will also be compatible with the upcoming 70-200mm F2.8 S Series lens, which will be available later this year.
    Available from June 2019, recommended retail prices are £489.99 (Ireland €569.99) for the 1.4x teleconverter DMW-STC14 and £579.99 (Ireland €669.99) for the 2.0x teleconverter DMW-STC20.
    Specifications:
    DMW-STC14
    Lens Composition of 7 lenses including 2 UHR (Ultra High Refractive Index Lens) lenses in 4 groups.
    DMW-STC20
    Lens Composition of 8 lenses including 2 UHR (Ultra High Refractive Index Lens) lenses in 4 groups.
