Make correction that leak is on big AMD fan channel :-) So, some stuff is not fully correct :-) Use logic that guess that.
Radeon RX 5500
RX5500 price is expected to be from $120 to $150 (top one for 8GB version).
Deal - XFX - AMD Radeon RX 5700 8GB GDDR6 PCI Express 4.0 Graphics Card for $289
I went with a used 1080ti for 430$,been using 1060 mini 6gb for a couple years now
May be, may be not.
Note that 1080 Ti used can outperform it sometimes and is much more future proof due to more memory.
Radeon VII is no longer made, actually.
I wonder why they started marketing Navi with GPUs that are less performant than their older "Radeon VII" product. Sure, the Navi chipset is more power efficient - but still not as power efficient as their competitors, so I really would have expected them trying to best their older generation with a new high-end model in absolute performance.
Video encoders, fps, performance using fast preset
Video decoders, fps, performance
Two parts define GPU performance in video editing - calculation speed and video encoders/decoders.
Shaders calc speed
Reviews are up
On architecture
On display engine
Updated DisplayPort 1.4 HDR is now capable of handling 8K displays at 60 Hz with a single cable. It can also handle 4K UHD at 240 Hz with a single cable. Support of HDR and 10-bit color is included. But only using DSC 1.2a (Display Stream Compression). The display controller also supports 30 bpp internal color-depth. The HDMI implementation remains old HDMI 2.0 without any real progress.
On video decoders and encoders
GPU provides hardware-acceleration for decoding VP9 video at formats of up to 4K @ 90 fps and 8K @ 24 fps. H.265 HEVC hardware-accelerated encoding of 4K at frame-rates of up to 60 fps is supported. H.265 HEVC decoding is accelerated at 8K @ 24 fps, and 4K @ 90 fps or 1080p at up to 360 fps. H.264 MPEG4 supports 4K @ 150 fps, and 1080p @ 600 fps decoding; and 4K @ 90 fps and 1080p @ 150 fps encoding.
Progress is really small and do not see any AV1 implementation here.
RX 5700 XT is priced at $449, and RX 5700 at $379.
Note that AMD wants to tie you to proprietary subscription cloud for ray tracing in the future
Navi also boasts an improved video engine. It can now accelerate VP9 decode at up to 4K90 and 8K24; H.264 decode at 1080p600 and 4K150; encode at 1080p360 and 4K90; H.265 decode at 1080p360, 4K90, and 8K24; and encode at 1080p360 and 4K60. Encoder speed-ups are reportedly as high as 40%.
Radeon RX 5700 XT Specs
Asrock prototype cards
Power consumption will be 225W for better and cheaper one will eat 180W.
But even best seems to be only RTX 2070 competitor.
