Ikan LCX21 Lyra 1x 2 Soft Panel RGBW Light
  • 3 Replies sorted by
  • Ikan LCX21 Lyra 1x 2 Soft Panel (Tungsten setting), Measurement using CV600, Russian Lab processing
    Focus on TM30 and CIE 224 and look for color distortion and Rf values.
    Ikan LCX21 Lyra 1x 2 Soft Panel is specific light, as it uses primary RGB leds for white light, is nod bad light, but light quality is not best for videos, especially compared to good modern adjustable temperature white led light.
    Color temperature
    CRI color quality
    CQS color quality
    TLCI 2012
    TM30 color quality
    TM30 details
    CIE 224 2017
    794 x 423 - 35K
    800 x 407 - 51K
    741 x 508 - 55K
    703 x 470 - 57K
    800 x 499 - 62K
    800 x 332 - 45K
    459 x 462 - 32K
    800 x 275 - 67K
    800 x 458 - 48K
    509 x 514 - 45K
    795 x 374 - 41K
  • Ikan LCX21 Lyra 1x 2 Soft Panel (Daylight setting), Measurement using CV600, Russian Lab processing
    Color temperature
    CRI color quality
    CQS color quality
    TLCI 2012
    TM30 color quality
    TM30 details
    CIE 224 2017
    800 x 422 - 32K
    800 x 417 - 52K
    747 x 519 - 55K
    717 x 433 - 54K
    800 x 506 - 63K
    800 x 341 - 47K
    458 x 456 - 31K
    800 x 277 - 67K
    800 x 457 - 50K
    510 x 506 - 46K
    791 x 371 - 41K
  • Specs
    • 97 CRI Chip LEDs paired with 1/2 stop soft diffusion panel
    • Full RGB color, Saturation, and HSI control
    • Variable CCT: 2800K-10000K
    • Beam Angle of Soft panel 110 degrees
    • A Clean single shadow without the artifacts
    • 8-bit & 16-bit DMX
    • Hue Shift: +green/-magenta 0-100%
    • Baby 5/8 inch/Junior 1-1/8 Combo Pin adapter with right angle receiver hole
    • Quick set disk locking system for positioning the light
    • Color correction filter gels
    • Special lighting effects
    https://ikancorp.com/shop/lighting/lyra-rgbw-1-x-2-soft-panel-digital-color-light/
