8-16mm F2.8 Fujifilm XF wide zoom lens
    PR
    FUJIFILM North America Corporation today announced the new FUJINON XF 8-16mm F2.8 R LM WR Lens, an ultra-wide angle zoom lens with a constant maximum aperture of F2.8 and focal length equivalent to 12-24mm (35mm format). Capable of providing outstanding edge to edge image-resolving performance, this lens is perfect for landscape and architecture photography such as interior and nightscape, and astrophotography.
    FUJINON XF8-16mmF2.8 R LM WR Ultra-Wide Angle Lens
    The new XF 8-16mm F2.8 R LM WR features an optical construction of 20 elements in 13 groups, including 4 aspherical lens elements to control distortion and spherical aberration, and 6 ED lens elements including 3 super ED elements to control lateral chromatic aberration, a lens design that produces advanced image-resolving performances across the entire zoom range. Featuring a floating lens element that adjusts according to the position of the zoom, the XF 8-16mm F2.8 R LM WR achieves edge-to-edge sharpness, and corrects field curvature that is typically found in ultra-wide angle lenses. The lens barrel is lightweight yet robust, sealed at 11 points, designed to be weather and dust-resistant and capable of operating in temperatures as low as 14°F/-10°C.
    FUJINON XF 8-16mm F2.8 R LM WR Key Features:
    • FUJIFILM X Mount is compatible with all FUJIFILM X Series interchangeable system cameras
    • Weather-sealed at 11 points for weather and dust-resistance; operates in temperatures as low as 14°F/-10°C
    • 20 elements in 13 groups including 4 aspherical elements, 3 ED elements and 3 super ED elements
    • Uses linear motors for quiet and ultra-fast AF
    • Nano-GI coating applied to rear surface of two front lens elements to eliminate ghosting and flare caused by oblique light
    Availability and Pricing
    The new FUJINON XF 8-16mm F2.8 R LM WR Lens will be available in late November 2018 in the U.S. and Canada for USD $1,999.95  and CAD $ 2,599.99.
  • 7 Replies sorted by
  • From Japanese presentation
    792 x 521 - 66K
    788 x 421 - 34K
  • Special Marumi filters holder
    650 x 467 - 47K
    650 x 473 - 48K
    800 x 531 - 104K
  • Special 100mm filters holder
