All I can find in the manual is that the LCD has 460,000 dots, and the Viewfinder has 1,530,000 dots. No info about the actual resolution in pixels. Thanks, Jon
Ah thanks. I wanted to know if the Cineroid/Zacuto/SmallHD EVF (at approximately 800x480) have similar resolution to the GH2 EVF...? Whats the x*y of both the EVF and LCD, as I don't know their aspect ratios? Many thanks
Guess its more like 480*360 or something like that. So Zocuto EVF gives indeed better res (+plus peaking), but the question really is... is it 1K$ better.. ?
I must admit after reading that small 720p panels might show up in closer future i delayed all EVF plans. These will last much longer.
But hey.. wait a second! Did you also recognize the DLP like rainbow effect in viewfinder on fast eye movement? It looks pretty much as if this was a greyscale screen with fast changing RGB backlight. This would mean its 3 times higher in resolution then I thought.
I must admit that from looking onto it, its seems to more than 480*360, icons are quite small and still sharp.
