Absolutely made my day!!!
Why is there no in-body image stabilization (IBIS) in the EOS R?
Shoji Kaihara: We had to look at the balance of the entire camera, like the size and other aspects. Based on that, it’s not something we are able to include in the EOS R at this time. We are quite aware that there are pros and cons to that.
That’s why we have image stabilization built into the lenses. We believe the lens will do the job of stabilizing at the moment. As we look into the future, we think about how we can build IBIS into the body as well.
But it’s not something we were able to achieve at the time of the EOS R’s launch. We know that there are pros that IBIS can provide, so we are looking into that. But not now.
Why does the EOS R shoot 4k video with a 1.7x crop?
Shoji Kaihara: When developing the EOS R, we looked at all the hardware we had in the pipeline. When we look at the image processor and CMOS sensors that we have — we have restrictions, unfortunately, and that’s why we ended up with the 1.7x crop.
We could have tried to pursue full-frame (4K video capture), but it would bring more instability into the video shooting. For example, heat issues might have arisen. We didn’t want to risk that. That’s the reason we decided, in terms of the best balance we can achieve at this time, to come out with 4K at 1.7.
Canon EOS R Mirrorless Digital Camera with 24-105mm Lens has $200 discount now
https://www.bhphotovideo.com/c/product/1433711-REG/canon_eos_r_mirrorless_digital.html
Not long ago such box and contents had been typical for most budget cameras
AF tests
*Inside - quite usual dated design
https://www.lensrentals.com/blog/2018/10/teardown-of-the-canon-eos-r-mirrorless-camera/
I've been catching up on the latest reports of the new Canon EOS R mirrorless camera.
And it truly is amazing the inventive ways that Canon can come up with to cripple their cameras. As well as the obvious downsides of the EOS R we know about such as its MASSIVE crop in 4K (same as a GH5S basically....), and its MASSIVE amount of rolling shutter, the EOS R also has:
1) no 60fps if you put an EF-S lens on it
2) no zebras once you press record
3) no histogram once you press record
4) C-Log doesn't exist in any mode whatsoever other than fully manual
