With 1.4x tele converter:
Panasonic Leica DG Elmarit 200mm f/2.8 POWER O.I.S. Lens , $2496
https://www.bhphotovideo.com/c/product/1367105-REG/panasonic_h_es200_leica_dg_elmarit_200mm.html
Tele converter review
Review
Panasonic 200mm f/2.8 is very sharp, tack sharp, even at f/2.8. For the entire frame, the sharpness graph is almost completely flat, indicating tack-sharp performance from center to corner, even when shot wide open. According to our measurements, there's an extremely minimal amount of corner softness at f/2.8, which gets sharpened if you stop down some, between f/4-f/5.6. However, despite the graphs, the difference in sharpness from the center to the corners at f/2.8 is insignificant.
Wide-open down to f/5.6, we observed optimal sharpness from the 200mm f/2.8, with tack-sharp quality across the entire frame. Once you stop down to f/8, however, slight diffraction-related softening begins to appear. It's still incredibly minor at f/8 and even still minimal at f/11. It's more pronounced once you hit f/16, which isn't surprising, though it's not terrible. At f/22, though, we definitely notice some softening.
https://www.imaging-resource.com/lenses/panasonic/200mm-f2.8-power-ois-leica-dg-elmarit/review/
Canon management during feeding
https://diglloyd.com/blog/2018/20180429_1320-Panasonic200f2_8-BighornSheep.html
Panasonic 200mm f/2.8 is incredibly sharp, tack sharp, even at f/2.8. Across the entire frame, the sharpness graph is almost completely flat, indicating tack-sharp performance from center to corner, even when shot wide open. According to our measurements, there's an extremely minimal amount of corner softness at f/2.8, which gets sharpened if you stop down some, between f/4-f/5.6. However, despite the graphs, the difference in sharpness from the center to the corners at f/2.8 is insignificant.
From wide-open down to f/5.6, we observed optimal sharpness from the 200mm f/2.8, with tack-sharp quality across the entire frame. Once you stop down to f/8, however, slight diffraction-related softening begins to appear. It's still incredibly minor at f/8 and even still minimal at f/11. It's more pronounced once you hit f/16, which isn't surprising, though it's not terrible. At f/22, though, we definitely notice some softening.
The performance of the tested lens is simply sensational. We officially get a new resolution record, amounting to 91.2 lpmm.
I haven’t tested such an excellently corrected lens for a very long time, a lens which can provide resolution records already from the maximum relative aperture and had not even one small optical slip-up in our test. I wish there were more such instruments on the market.
Review
MTF of lens
MTF of lens+1.4x TC
https://www.ephotozine.com/article/panasonic-leica-dg-elmarit-200mm-f-2-8-power-o-i-s-review-31799
Panasonic management self portraits (full size on 200mm)
Olympus will later make firmware update for their cameras to better support this lens
http://cs.olympus-imaging.jp/jp/support/cs/info/2017/11/005/index.html
Panasonic Japan announced the shipment start date (in Japan?) of this lens- it'll ship from December 14.
Hungry squirrel, no food for month due to Leica prices
Panasonic Leica.
