Olympus OM-D E-M1 Mark II in DE also dropped to 1499 EUR
https://www.amazon.de/gp/offer-listing/B01M8PAJQ1/ref=as_li_ss_tl?ie=UTF8&condition=new&linkCode=sl2
Free case + card deal
http://www.getolympus.com/us/en/digitalcameras/e-m1-mark-ii.html
Olympus OM-D E-M1 Mark II new for $1499
OM-D E-M1 MARK II BODY ONLY (RECONDITIONED) for $1499
http://www.getolympus.com/us/en/outlet/om-d-e-m1-mark-ii-body-only-reconditioned.html
New firmware - v2.1
Corrected issue of C-AF not operating correctly when using the “LEICA DG ELMARIT 200mm F2.8 / POWER O.I.S. (H-ES200)” interchangeable lens produced by Panasonic.
http://cs.olympus-imaging.jp/en/support/imsg/digicamera/download/software/firm/e1/
OM-D E-M1 MARK II BODY ONLY (RECONDITIONED), $1499
Firmware Version: 2.0
New Features:
- New art filter [Bleach Bypass] has been added.
- Possible to use focus stacking photography with “M.ZUIKO DIGITAL ED 12-100mm F4.0 IS PRO”.
- Small targets have been added to AF target mode.
- Possible to set a maximum of 35 pre-shutter frames for Pro Capture shooting.
- Display has been improved to show that Pro Capture shooting is recording.
- “Flicker Scan” has been added so it is possible to reduce flickering by fine adjustment of shutter speed while looking at the live view when using electronic shutter.
- Fisheye compensation photography has been added for use of M.ZUIKO DIGITAL ED 8mm F1.8 Fisheye PRO. You can view the effects in live view while shooting images.
- Possible to set zoom ratio during playback. Also, added pixel equivalence display to zoom ratio.
- Pro Capture shooting is available for additional lenses.
- Display of remaining battery power has been improved.
- Response when assigning AF to AEL/AFL button has been improved.
- Stability of camera operation when using OLYMPUS Capture has been improved.
- Stability of image stabilizer operation when shooting video has been improved
Olympus OM-D E-M1 Mark II for $1699
Plus $300 discount on 300mm lens if you get it also.
https://www.amazon.com/Olympus-Mirrorless-Camera-Megapixels-5-Axis/dp/B01M4MB3DK/
Olympus OM-D E-M1 Mark II+ Free Battery Grip action
https://www.bhphotovideo.com/c/product/1283565-REG/olympus_om_d_e_m1_mark_ii.html
E-M1.2 F/W code is being optimized/refined much of which will be incorporated into E-M5.3 F/W. New/upgraded features/algorithms/codecs are currently being tested as part of the E-M5.3 alpha/beta cycle and most will be made available to the E-M1.2 once finalized.
New firmware - v1.4
Improved stability of operations when shooting while utilizing the EVF.
OM-D E-M1 Mark II Body Only (Reconditioned), $1500
Use code CYBERSAVINGS
