Olympus OM-D E-M10 Mark III Mirrorless Camera Body, $449
https://www.adorama.com/iomem103b.html
Olympus OM-D E-M10 Mark III Mirrorless Black Camera with 14-42 EZ Lens, Case, 16GB SD Card, $599
E-M10 Mark III Silver with 14-42mm EZ Lens, $479
Olympus OM-D E-M10 Mark III camera body for $584
In Japanese Olympus ships such proper bag with camera :-)
Special kit for $799
Review
The faster processor enables the Mark II to support 4K movie recording, although not at the 'professional' level of the E-M1 Mark II. As mentioned above, you can't select the various movie shooting options via the camera's menu, which is a pity and can lead to confusion if you're a regular OM-D camera user. The top resolution is 3820 x 2160 pixels with a frame rate of 25 fps for PAL system users (30 fps for NTSC users).
The remaining movie options include Full HD at 1920 x 1080 pixels with frame rates of 50p and 25p for PAL system users and HD at 1280 x 720 pixels with a frame rate of 25p. There's also a slow-motion mode at HD resolution with a frame rate of 100p.
Autofocusing remains contrast-based, which means the camera has to re-acquire focus whenever you zoom in or out or change the view of the scene. We found the review camera would take up to a second to re-focus in these situations, particularly if it also had to re-adjust the exposure to changing subject brightness.
