10th and 11th reports
F&V R300S ring led light
https://www.personal-view.com/talks/discussion/17550/fv-r300s-ring-led-light
12 and 13th reports
Fotodiox Pro FACTOR Jupiter12
https://www.personal-view.com/talks/discussion/17584/fotodiox-pro-factor-jupiter12-led-light
Spectrum of usual consumer warm led cheap lamp (same that you see above on screen)
                  Big progress. Donated small amount again.
14th report
Godox SL60W (daylight version), Measurement
And note - it is cheap as hell!
CRI color quality
15th report, second Aputure M9 measurement
CRI color quality
https://www.personal-view.com/talks/discussion/15375/aputure-m9-small-light#Item_15
16th report, Aputure Tri-8 (daylight)
TLCI 2012
https://www.personal-view.com/talks/discussion/15860/aputure-ls-mini20-and-tri-8s-lights#Item_18
17th and 19th reports, CAME 55W Bi-Color Fresnel
Wow, the CAME-TV Boltzen F-150W LED looks like a beast light. Will this compare favorably to the Aputure 300d ($1000 US)? I was also comparing it to the Also 3200 Low Noise LED. They put out a LOT of light.
17th and 19th reports, F&V Z720S UltraColor ring light
CRI color quality
https://www.personal-view.com/talks/discussion/17835/fv-z720s-ultracolor-bi-color-led-ring-light
20th report, Aputure 300d
TLCI 2012
http://www.personal-view.com/talks/discussion/17424/aputure-cob-300d-led-fresnel-light#Item_3
21th Lishuai LS J-500 50W Led Fresnel Light (daylight version)
CQS color quality
22th Lishuai VictorSoft 1x1 LS V-2000ASVL (daylight mode)
Color temperature
TLCI 2012
Battery test sample N1, V-Mount battery
Check at
https://www.personal-view.com/talks/discussion/18185/pv-lab-v-mount-battery-test
Used our measurement mike in follow focus review
So you can actually not only hear, but see why so important to have bumpers on hard stops
                  Battery test finished - IDX Endura Cue V-Mount battery test
Check at
Lulliput A12 and Lilliput A7S Monitors DC Consumption tests
https://www.personal-view.com/talks/discussion/17678/lilliput-a7s-fullhd-ips-on-camera-monitor
Illuminance measurements for Godox light
Godox SL60W Noise measurement at 1 meter
More Light stuff
