New firmware v1.3
Corrected issue of AF Targeting Pad not functioning.
http://cs.olympus-imaging.jp/en/support/imsg/digicamera/download/software/firm/e1/
Reconditioned bodies for $1699
http://www.getolympus.com/us/en/outlet/om-d-e-m1-mark-ii-body-only-reconditioned.html
Thom Hogan already posted his review:
I try to never post his stuff, as it is usually no more than smart Nikon marketing material.
Got it - at least he liked the camera.
OM-D E-M1 Mark II Body, Reconditioned, $1699
Review
You need to be sitting while looking at latest Olympus prices.
Complete guide book
https://www.amazon.com/Complete-Guide-Olympus-MD-M1/dp/1387230565/
The Olympus E-M1 MkII Menu System Simplified
https://www.amazon.com/Olympus-MkII-Menu-System-Simplified/dp/1520997787/
OM-D E-M1 Mark II Body Only (Reconditioned), $1500
Use code CYBERSAVINGS
New firmware - v1.4
Improved stability of operations when shooting while utilizing the EVF.
E-M1.2 F/W code is being optimized/refined much of which will be incorporated into E-M5.3 F/W. New/upgraded features/algorithms/codecs are currently being tested as part of the E-M5.3 alpha/beta cycle and most will be made available to the E-M1.2 once finalized.
Olympus OM-D E-M1 Mark II+ Free Battery Grip action
https://www.bhphotovideo.com/c/product/1283565-REG/olympus_om_d_e_m1_mark_ii.html
Olympus OM-D E-M1 Mark II for $1699
Plus $300 discount on 300mm lens if you get it also.
https://www.amazon.com/Olympus-Mirrorless-Camera-Megapixels-5-Axis/dp/B01M4MB3DK/
Firmware Version: 2.0
New Features:
- New art filter [Bleach Bypass] has been added.
- Possible to use focus stacking photography with “M.ZUIKO DIGITAL ED 12-100mm F4.0 IS PRO”.
- Small targets have been added to AF target mode.
- Possible to set a maximum of 35 pre-shutter frames for Pro Capture shooting.
- Display has been improved to show that Pro Capture shooting is recording.
- “Flicker Scan” has been added so it is possible to reduce flickering by fine adjustment of shutter speed while looking at the live view when using electronic shutter.
- Fisheye compensation photography has been added for use of M.ZUIKO DIGITAL ED 8mm F1.8 Fisheye PRO. You can view the effects in live view while shooting images.
- Possible to set zoom ratio during playback. Also, added pixel equivalence display to zoom ratio.
- Pro Capture shooting is available for additional lenses.
- Display of remaining battery power has been improved.
- Response when assigning AF to AEL/AFL button has been improved.
- Stability of camera operation when using OLYMPUS Capture has been improved.
- Stability of image stabilizer operation when shooting video has been improved
