Panasonic GX80, GX85, or even GX7 Mark II in Japan
  • 417 Replies sorted by
  • gh1 was first hacked then gh2 .Vitaly obey “ Three Strike you out “ -;)
  • Hi Vitaly! Is it possible to hack the GX80 with features like GH2? Higher bitrate etc.
  • Yes that was the case, you are right - camera is doing autoexposure even in photo M mode, so the picture is different.
  • So you shot a video in photo manual mode? From my understanding if you start a video in any mode other than manual video mode it will do auto exposure.
  • As I understand, mechanical shutter works only for still photo, not for video. And I shot 4K video. This pictures are captured shots from video files I made with VLC.
  • Maybe it has something to do with electronic versus mechanical shutter?
  • Was playing/testing GX80 and found out one thing which can't explain. The same video settings (resolution, shutter, f-stop, iso, all the same), same lens (lumix 12-60 3.5-5.6) but in different modes (used Video Manual and photo Manual) visible difference in exposition and totally different flares from the sun. Do I miss something? Rays are in video M, no rays - photo M.
    3840 x 2160 - 1M
    3840 x 2160 - 1M
  • Panasonic LUMIX GX85 w/ 12-32mm Lens + 64gd card + bag + battery + filter for $497
    https://www.amazon.com/dp/B01GK719H4/
  • Here's a short film I shot with the GX85 + Cine-D:
    Feel free to vote for it here too if you liked it :) https://www.rode.com/myrodereel/watch/entry/4364
  • Remember about good deal
    Panasonic Lumix DMC-GX85 Mirrorles Camera w/12-32mm Lens,Silver w/$100 Gift Card, $597
    https://www.adorama.com/ipcgx85skgc.html
  • Panasonic Lumix DMC-GX85 Mirrorless Camera w/12-32mm + 40-150mm Lenses w/$100 Gift Card, $697
    https://www.adorama.com/ipcgx85bkgc.html
  • Hello. Here is my new music video, shot mainly with Lumix GX80. And also with DJI Phantom 3 and B-Cam Canon 70D.
  • Well, if someone can control the bitrate, I would certainly use it, but I have nothing to add to the web protocol.
  • Added CineD to my GX85 and saved it as C1. Oink!
  • Camera + 12-32mm + 45-150mm for $698 at
    https://www.amazon.com/dp/B01MFI2DK0/
    Camera + 45-150mm for $597 at
    www.adorama.com/ipcgx85b.html?sub=cpd060117gx85
  • Here is a video I did on the GX85 indoors and out shot in 4K Natural setting delivered in 1080. Priority was to the still photographers so I grabbed shots where I could almost all hand held. Indoors there was a skylight and the lighting was changing by the minute so had to use auto WB and even out later. Simply an amazing little camera that being said I changed over to the G85 since to get Mic input and CineD.
  • Inserting Robbino´s code in BTM_Pix´s html file, and after several conections fails (update imgapp message), i get this options available from myG80:
    ?xml version="1.0" encoding="UTF-8"?> camrply> result>ok mainmenu> item value="vga" enable="yes" id="menu_item_id_liveview_quality"/> item enable="yes" id="menu_item_id_liveviewsize_vga"/> item enable="yes" id="menu_item_id_liveviewsize_qvga"/> /mainmenu> photosettings> item enable="no" id="menu_item_id_ph_sty_vlog_l" option="detail"/> item enable="no" id="menu_item_id_v_quality_mp4ed_c24p_200mbps"/> item enable="no" id="menu_item_id_v_quality_mp4ed_24p_200mbps"/> item enable="no" id="menu_item_id_v_quality_mov_c24p_200mbps"/>
    Vlog and 200mbs mov seens very tempting, but im not brave enought to be the first trying.
  • @spectra, I use a Watson charger and a variety of off brand batteries. Wasabi off brands have been ok for me although not always with the same life as the originals. Reliable so far though. The Watson charger is excellent and they make plates for this battery style that clip into any of their chargers so all you need is one charger and a plate for each style of battery you have. I have a dual charger for the desk and a single for the road.
  • @Vitaliy_Kiselev If so, probably new versions of the .html file will appear for other models with new features until panasonic fix it with next update
