BTW - I live in Shanghai, the cheap gear available is quite overwhelming - but I chose not to go too cheap and went for some better quality stuff more in the lines of Tilta or Trustmt.
Can you give some examples? It is very interested to get in contact with manufacturers.
And this guy sold 80 FF in few days. Without any paid advertising (I am not very correct here, as one site who wrote about this live on affilate money, so glad to write about anything).
Are you sure about them using high volume methods? Getting supply issue at only 80 units doesn't sound like it. The seller is gonna add more workers though.
I like the gear "box", the lens gear style, and the reversible feature. $126.50 including shipping. Plus the lens gear special. So cheap. What can go wrong? If things don't work out, just sell'em at little loss.
You must understand that no FF on ebay ever had been sold in such amounts in such time. So, producer only recently started making them, as I understand. And order had been limited. As for high volume methods, it is easy to spot. Such approach is used in production on large volume factories (no CNC and such stuff).
I have big doubts about little loss, sounds more like big gain. :-)
Read item description carefully :-) the included flexible gearbelt can be used with any zoom or prime lenses with a wide range of lens diameters (any size from 52mm to 86mm)
Look at ebay and buy separate gear, they are quite cheap.
@stefanos I think the price will stick... or it might go up more. Did you see the white plastic gear can be front or back of the gear box? This will work w/ 20mm or 14mm pancakes. I ordered 10 lens gears at $100.
Price won't be lower, I think. As for Chinese inflation role in all this... It is total bullshit. Wanting more money, better profit is real reason behind new price :-) He also want to reduce number of negative feedbacks and cancelled orders (price increase helps with it quite good).
Looking forward to reviews once anyone receives theirs.
It at least looks better than the DFocus, but the reason I'm not going to get it is because the accessory port is not industry standard. This means that tools like whips or speed cranks won't work with this FF.
