I am making various safe and economical 3GOP settings now, and I stick one of them. With this patch, in using of EX-TELECON there is no problem. However, the use in 30p may become sometimes unstable.
As a result of moving a camera to right and left and testing it, it is shown in this screen shot. If it is a stress of this level, also in 30p, it will be very stable. However, when a camera was moved up and down continuously in stress test with Stray's chart, recording did not stop, but the frame might fall.
NOTE: The setting of Chris is borrowed except 24p.
Been away from the GH2 for a bit. I was lucky to get an awesome deal on a 2nd hand 5DM2 so have been playing with that. Anyhow, loaded up your 'beautiful buffers' patch and what can I say? I'm totally floored, came such a long way in such a short time. Also took this downtime to improve my color grading skills - this new stuff grades so beautifully. Thanks for the hard work and tireless effort! Damn the 5DM2 looks 'soft' ;-)
@bkmcwd The average bit rate on the stress test is breaking the max you've set of 88M by about 20M (avg of 107M), are you sure its frame rate is ok ? I'd love to see a sub 100M GOP3, but I figure Iframes are going to be around the 600,000 mark to keep within the 88M bitrate.
@Stray It is the affair which became a problem before? ;-) The frame rate is OK, I think and "actual framerate is" is not desplayed in Streamparser.
I think that frame size is not compressed as long as shooting ordinarily with "24p" since this is Q18. I will shoot green in a usual park tomorrow. Although I also made the patches of higher Q value, I think that the balance of this is the best. If a problem occurs, I am going to raise Q value.
*** NEW **** Driftwood INTRA Patch: 'AQuarius' 1080p24 AQ3 with 720p50 AQ3.
50p lookin' good at AQ3 with a few other adjustments. 1080i/50 is a tad improved too under INTRA.
60p at INTRA is a complete NO NO. Therefore, 60p and 1080/60i is left untouched for your own setting.
Note: We can get 1080/60i to INTRA but 720p is then useable - so we left them both unchecked for your own settings.
Ive also dropped 6M off the 176M H setting from the 'reAQuainted' patch which brings the cpb_delay timing in slightly better but with a very weeny drop in bitrate. Please test away :-)
Nick
Driftwood 'AQuarius' INTRA - 1080p24 AQ3 and 720p50 AQ3 - sete.zip
In the mean time... at the risk of embarrassing myself, here is a youtube vlog I did yesterday using the one before ReAQuanted. QuantMeBaby i believe it was called. I love how well it works with Neat video NR. Which is used on all shots sans the first shot which I forgot to do.
Eh.. alright, since I can't figure out how to embed a video on this forum (face palm, such a n00b) here is the link.
@bkmcwd yes its the same problem, if the average data rate goes higher than the streams max speed something will be wrong on playback. Record for a minute exactly in camera and then check the time the file plays back for.
@driftwood I am looking forward to trying your new great patch! :-) My work fills the niche between your great works, I hope.
@someone I stick the sample of 24p and 30p with my latest 88M 3GOP. Since 30p was used satisfactorily, there seems to be no problem also at a little lower Q value. 24p
@Stray Thanks mate! ;-) I have shot the tree today, moving a camera in the up-and-down direction. The camera just stopped at the top and the bottom for a moment the place where the slot is made into the wave of Streamparser. This is not cadence problem. Although I think that it is still generous, since it is my purpose to make this patch economical, I think how to adjust.
You are right in being concerned about the video bitrate exceeding the max bitrate. The max bitrate is calculated from TS packet timer stamps. When video bitrate exceeds the maximum there are packets that end up with identical time stamps (they are supposed to all be different and ascending). I'm not sure how all codecs deal with this, but I would assume that with many, if not all, packets will end up being dropped. These are 192 byte packets - so when they are dropped only a small portion of a frame will be affected - it might be hard to see.
yet only 6 of you have so far submitted 10 seconds of video. Deadline cutoff is the 10th November. If you want to be part of it - please send me a link to your upload site together with info on how you recorded it, using which INTRA setting. Thnks! :-)
@cbrandin Thank you for your great work and relevant description always.
In my strange English, it may not get across to you, and I have a question. For example, if this arrangement of mine does not apply stress forcibly, either, the video bit rate does not almost exceed the maximum video bit rate, but is there any problem still?
I'm not sure what you are asking. Actually, it's the "Average Total Bitrate" that should not exceed the "Max Speed" (sorry for not having been more specific in my previous post). If it does, I think there might be problems - like cadence issues and packets dropped by the decoder.
Indeed, I understood that it was not "should not exceeding" but "better not to exceed". :-( O.K, I think that I will improve this patch as you say.
BTW, "I'm not sure what you are asking" My question is as follows. With the patch in which the video bit rate exceeds the maximum video bit rate when an extreme stress test is done, when shooting an ordinary situation, do not exceed, either, but. Do any problems occur by using so that the patch of such character may not be exceeded in an ordinary situation?
OK, I think I understand. If the max speed is not exceeded you should be OK. The problem I have with your suggestion is that it means you will rely on being lucky when you shoot. It's better to try to avoid the situation with stress tests - that way no matter what you shoot, you should be OK.
