I'm sorry you've lost me. My question when I started off with this topic was what cameras can you recommend based on my budget & needs. Learning will come only once I've bought my choice of camera.
The whole point of coming onto forums is to get recommendations based on my budget.
I do not understand idea at all. I mean such budget and idea to buy "on budget". If you are not completely disabled, you slowly learn and ask and at same time work and collect for the thing that is good.
Oic...sorry I misunderstood.
The whole point of coming onto forums is to get recommendations based on my budget and needs as there are hundreds of brands and models to choose from.
I don't want to blindly choose a model that I might regret afterwards.
My advice was different. Advice was to instead of spending time of forums trying to save few pounds go and get some small work to collect for best camera you could.
@Yskunto - I like the idea of a full package if possible. However isn't the GH1 a very old camera now? I mean it was made in 2009 and that almost 7-8yrs ago. If possible, I'd rather go for a bit newer than that and maybe get one of the lens at a later date.
@Vitaliy - Yes I definitely was to save as much as possible. I'm getting pulled towards the Samsung NX range, although there are many other manufacturers that are good too.
Guys what if I didn't bother with cameras with interchangeable lens and instead went for a superzoom/bridge camera? Could I get good bokeh/shallow DOF from these cameras?
200 GBP for the camera only or you do want a full functioning package? If only for the camera, then you cannot go wrong with GH2. If you want full functional package, then:
GH1 + any good 28mm f2.8 manual lens + adapter to m43 for the lens + 2 x 8/16GB class 10 SD card + Mieke viewfinder loupe + good pistol grip install the latest GH1 hack from @humpman or from @lpowell The rest small amount of money is to buy bread and coffee to keep your body healthy when shooting in the cold winter.I understand that you want to save maximally, just sit and think. It is always best to find small work, add savings and get best you can get, if you really into it.
I understand. The thing is vitaley you sometimes need a bit of speed to get that shot in quickly. As long as the nx1000 is as fast as the old Panasonic FZ35/FZ38 that my dad has, then it should be fine.
I'm not too fussed about WIFI, but how do I work out exactly how slow the NX1000 is compared to the NX300? Is there a number to look out for?
I have no idea.
Instead of focusing on it, best idea can be find some small work around, but NX300 or NX500 and go shooting.
Right I see. I've been looking into both models and it seems the NX300 is much faster at taking photos and also has features such as WIFI.
No, I am not.
Other than angle of monitor tilt, are there any other features or large differences that the NX1000 doesn't have?
NX1000 is old entry level camera, NX300 was compact flagman.
Thank you Vitaliy. If I may ask, are you from UK?
Well, if you can go for NX300 / 300M (their main difference is angle of monitor tilt).
Do not rush, check sold items prices, and get good used kit using buy it now on ebay.
Thanks you Vitaliy. I really like your suggestions as the NX looks modern and takes good photos too. Other than the NX500 which is out of my range, which one would you go for? NX300, NX300M or NX1000?
From looking at ebay, I can pick the:-
I'm steering towards the NX1000, but can't make my mind up - From these three which has the best/latest features for the money?
Thanks JanH. What about the Lens the seller is including? Are they any good or worth a lot of money?
I also suggest to look at Samsung NX bodies, even may be NX1000.
Samsung NX300 and NX300M kits are in your range, they make superb photos better than m43 cameras, can do 1080p60 movies and has peaking and such, has Wi-Fi. Only drawback is that some high detailed parts in video can be blurry due to encoder.
Samsung NX500 is outside your range, but if you can - get this as kit with 16-50mm lens , it still has best APS-C sensor, has 4K video capability also has hacks for it.
That looks to be a very good price. You can't really go wrong with a GH2.
Thanks guys for your help.
Features wise what's the difference between these two models?
What lens can you recommend to get a shallow DOF and BOKEH effects for portraits?
Here is a GH2 with lens... Is this any good for the price?
yeah I see no alternative to GH2 or maybe GH1. :)
I think that used GH2 bodies are going for right around $250 right now. You'd still need to get a lens, but that should be right around your budget. You're on your own to determine if the photo quality is sufficient for you, but after it's hacked, the video quality is great - and if you choose your lens right, you'll get nice bokeh. It should fulfill, basically, all of your main features and just about all of your bonus features except for wireless and "modern" is up for debate. :)
