The never ending pursuit……………
The goal of this post is to build a custom PC solution that renders 4k+ footage with ease.
I want to determine if this solution is more suitable than getting HP Z840 workstation.
In my own experience it is always better to go thru the process of building your own workstation to educate yourself on the latest best practices.
Hence my questions to be asked:
I know a lot of these things will depend on the amount of money one can spend. However, I’m trying to find the middle ground between the two and see what can get me thru the next 4 years.
Things that I know and want:
I’m going thru the research phase at this time hence this post to gather all valid points for the next workstation for video editing. If anyone is going thru an upgrade process at this time please share your thought and experience.
@davjd Thank you but I'm not using Premiere CC. This project is a simple re-render of 30+ gigs of 4k action camera only (60 Mbps) footage, no special effects what's so ever for final 14 min video. I also did a test exporting it to 1080p 20Mbps bitrate resulting in 3+ hrs to complete on the new machine.
I am using a hp z840 workstation (rented - paying per month, in a couple of years it will be mine, or I can change it (most likely)), one xeon e5-2620 v3 @2.4 GHz, 32GB ram, Nvidia Titanx, and one pci-express ssd by hp. Editing 4K with Premiere CC? I was expecting a better performance. I was going to rent a Mac pro workstation, then somebody convinced me to use this workstation. I think I did a mistake. I don't think it is worthed to upgrade to a second processor to have better performance in video editing (actually around $600), while the pci-express ssd made a difference. Titanx is a gaming board. Looking at its real usage while editing (with GPUShark) I never get more than a 20 - 25 % of Gpu involved. I can't be more precise at the moment, because if I look at performance I don't work, but If you want some particular benchmark I can test it for you.
Were none of the effects you were using GPU accelerated? If not, it isn't completely crazy that 19.2ghz rendered faster than 16ghz.
So I went thru a 4k project render on two, old (2013) and new (2016) cpu/gpu platforms.
Processor Intel(R) Core(TM) i7-3930K CPU @ 3.20GHz, 3201 Mhz, 6 Core(s), 12 Logical Processor(s) Adapter : NVIDIA GeForce GTX 680 Processor Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz, 4001 Mhz, 4 Core(s), 8 Logical Processor(s) Adapter : NVIDIA Quadro M5000M
Just to be surprised that it actually takes 16hrs to re-render my 4K project on the older 3+ year old machine vs the 20hrs on 2016 Skylake laptop with m.2 drives only.
I was re-rendering to 29.970 QFHD 2160P 35-50mbs bitrate on both machines.
Here is a newer one: Xeon E3-1585 v5 that uses BGA 1440 socket (soldered down models) I guess Intel doesn't have E5v5 Xeons (Skylake-H) on the market yet.
Why are those Intel Xeon Processor E3-1275 v5 cheaper from Broadwell (E3 v4/E5) Xeons CPUs?
Specifications Processor Number E3-1275V5 Lithography 14 nm -Performance # of Cores 4 # of Threads 8 Processor Base Frequency 3.6 GHz Max Turbo Frequency 4 GHz Cache 8 MB SmartCache Bus Speed 8 GT/s DMI3 TDP 80 W VID Voltage Range 0.55V-1.52V -Supplemental Information Embedded Options Available Yes Conflict Free Yes Datasheet Link -Memory Specifications Max Memory Size (dependent on memory type) 64 GB Memory Types DDR4-1866/2133, DDR3L-1333/1600 @ 1.35V Max # of Memory Channels 2 Max Memory Bandwidth 34.1 GB/s ECC Memory Supported ‡ Yes
Interesting. The only hard drive failures I have had are from the traditional mechanical platters, and they fail especially after being stored for a few years, but I guess I have one more thing to worry about.
(NB the boot drive won’t hold any real data, but it needs to be 500gb. You can get away with 250 but sometimes the temporary files clog it up when running video editing)
I strongly recommend to move all big temporary files from any modern cheap TLC system drive. Such drive use chips rated from 50 up to around 300 rewrites.
I would not go with dual Xeons, either overclock the low end six core or get the fastest multicore you can find. It could be the whole landscape will change after the AMD chips are introduced. I also note you can get an HP workstation for ~$1000 with a six core i7 and proprietary water cooling. You could then use that as a base, just a thought. Swap out the card and upgrade the drives and ram as need be.
The last one I built
CPU
Intel Core i7-5930K (Note: the E5-1680 V3 is slightly better but it is 4x price) 6 core HT minimum.
GPU—must be Nvidia with a good number of CUDA cores
GTX 780 (very good)
GTX 680 (only slight difference)....or use whatever graphics card you want.
Case with room for 8 drives and minimum 2x 5” bays for drive cages
ORICO CD-ROM Space internal 3.5 inch SATA HDD Frame/Mobile Rack
Internal HDD Case - Black (1106SS) Available for $17 on amazon here:
https://goo.gl/g4Omz7
Boot Drive Samsung SSD 500gb 850 EVO or equivalent
RAM 64 gigs, can get by with 32, if using 32, use chips that allow for expansion later on
Motherboard: minimum 8 sata ports
Point taken.
If that's the case maybe I should look into upgrading my
• Asus Rampage IV Extreme motherboard
to
• Intel Xeon E5-2697 v2 (30M Cache, 2.70 GHz)
And? They are like 10% slower, and much much cheaper.
They work on quite modern boards, so no issue.
It looks like these are the Haswell Xeons, two generations behind the current Skylake-DT.
Thank you VK! I'll check it out.
Reformatted :-)
Just pulled trigger on dual xeon 2670 with 64gb ram , let you know how it goes..most expensive part was the dual xeon motherboard about $315 , the chips were 150$ for both . 64gb ddr3 ram was 90$ , also got the new gtx 1060 6gb mini ..let you know how things go
Otherwise you can just get good SSD, including PCI-E versions
Video card NVIDIA Quadro M6000 or NVIDIA TITAN X?
Just get 1070 or 1080, can be two, check Davinci recommendations
