NVIDIA TITAN X for $1200
  • GPU Engine Specs:
             -3584NVIDIA CUDA® Cores
             -1417Base Clock (MHz)
             -1531Boost Clock (MHz)
    Memory Specs:
             -10 GbpsMemory Speed
             -12 GB GDDR5XStandard Memory Config
             -384-bitMemory Interface Width
             -480Memory Bandwidth (GB/sec)
    Technology Support:
            -Simultaneous Multi-Projection
            -VR Ready
            -NVIDIA Ansel
            -SLI HB Bridge SupportedNVIDIA SLI® Ready
            -NVIDIA G-SYNC™-Ready
            -NVIDIA GameStream™-Ready
            -NVIDIA GPU Boost™ 3.0
            -12 API with feature level 12_1
            -Microsoft DirectX
            -4.5OpenGL
            -PCIe 3.0Bus
    Support
    Windows 7-10, Linux, FreeBSDx86
    Display Support:
              -7680x4320@60Hz Maximum Digital Resolution
              -DP 1.43, HDMI 2.0b, Dual Link-DVIStandard Display Connectors
              -Multi Monitor
              -2.2HDCP
    Graphics Card Dimensions:
                  -4.376"Height
                  -10.5"Length
                  -2 SlotWidth
    Thermal and Power Specs:
                   -94Maximum GPU Temperature (in C)
                   -250 WGraphics Card Power (W)
                   -600 WRecommended System Power (W)4
                   -1 8-pin and 1 6-pinSupplementary Power Connectors
    1 - Windows 10 requires November 2015 update or newer.
    2 - 7680x4320 at 60Hz RGB 8-bit with dual DisplayPort connectors or 7680x4320 at 60Hz YUV420 8-bit with one DisplayPort 1.3 connector.
    3 - DisplayPort 1.2 Certified, DisplayPort 1.3/1.4 Ready.
    4 - Recommendation is made based on PC configured with an Intel Core i7 3.2 GHz processor. Pre-built system may require less power depending on system configuration.
  • 2 Replies sorted by
  • Nvidia price comparable to EVGA, Asus and other vendors.
  • There are no other vendors.
