Available at
PR
Kenko Tokina USA, Inc. is excited to announce the new Tokina AT-X 24-70mm F/2.8 PRO FX lens designed for use with Canon and Nikon full-frame sensor DSLR cameras.
Tokina’s latest addition to its family gives full-frame photographers a 24mm wide-angle to 70mm moderate telephoto lens with a fast F/2.8 aperture at an affordable price.
The new groundbreaking proprietary optical design uses three precision molded all-glass aspherical lens elements to achieve excellent contrast, sharpness, and corrects for spherical aberrations. One of these elements is very special and difficult to manufacture. G09, is made from Super-Low Dispersion (SD) glass and is a large sized aspherical element.
These lens elements also yield even illumination across the whole image sensor.
The Tokina 24-70MM lens also uses three SD (super-low Dispersion, “FK01” and FK03”) glass elements in the rear groups to control chromatic aberrations. All these specialized lens elements work in consort to yield maximum resolution to match the 50-megapixel DSLR cameras entering the market.
The fast constant F/2.8 aperture makes viewing and auto focusing possible in very low light situations while keeping some flexibility for setting the shutter speed. In addition to excellent optics, the lens incorporates a fast moving SDM (Silent Drive-Module) motor to greatly reduce AF noise making it one of Tokina’s quickest and quietest auto-focusing lenses to date.
Tokina’s exclusive One-touch Focus Clutch Mechanism allows the photographer to switch between AF and MF simply by snapping the focus ring forward for AF and back toward the lens mount for manual focusing. The lens is also designed to stand up to the rigors of daily use by photographers in a wide variety of shooting conditions and environments.
Tokina AT-X 24-70mm f/2.8 PRO FX Lens for Canon EF, $569
https://www.bhphotovideo.com/c/product/1084636-REG/tokina_at_x_24_70mm_f_2_8_pro.html
Its headline score of 32 points puts the Tokina 24-70mm f/2.8 in first place for all fast-aperture standard zooms that we’ve tested on the D800E, ahead of the Tamron SP 24-70mm f/2.8 at 31 points and Nikon’s own 24-70mm f/2.8G at 30 points. While all three boast comparable scores for distortion, vignetting, and transmission, the Tokina is ahead for sharpness, with a superior score of 27 P-Mpix, compared to 23 P-Mpix for the Tamron, and 21 P-Mpix for the Nikon G.
http://www.dxomark.com/Reviews/Tokina-AT-X-24-70mm-f-2.8-PRO-FX-Nikon-lens-review-Top-performer
Even when you use this lens without a flash you’ll still be able to render some absolutely crazy sharpness that I’ve only ever seen from Sigma, Zeiss, and Sony if we’re talking about optics designed for full frame 35mm sensors. It’s astonishing and incredibly deceiving.
No, really, other manufacturers should make full frame zoom lenses like this.
http://www.thephoblographer.com/2015/11/17/review-tokina-24-70mm-f2-8-canon-ef/
I dont understand why they still are using that clumsy AF/MF pull switch. So difficult to use quickly.
If they will, it'll be very pricey :-) But I think they will do finally.
Anybody heard any news on if they'll be making a PL mount version of this lens? Like they have done with their 11-16mm, 16-28mm, and 50-135mm? If so, it will fill in their empty hole in the range. Perfect for moderate wide to normal to short portrait lengths (i.e. the bulk of most shots on many shoots), all on a single lens on my PL mount camera.
Hoping they also create a cine version of their new 11-20mm as well.
