Panasonic GX8 and 30p mode
  • Got a question for fellow GX8 owners. For some reason the 30p video mode is showing combing/interlacing artifacts. I have attached a still frame from a test video and you can clearly see the combing artifacts around my fingers. I know the 30p is shot in PsF in Panasonic cameras, but I've never had a problem, with the G6, GH2, and GX7. Footage from those cameras all come out looking progressive. Anybody else has the same issue?
  • 3 Replies sorted by
  • You should be able to shoot in mp4 directly and avoid this step. The only reason to shoot in AVCHD at this point is if it gives a different bitrate, or allows for longer continuous shooting. I almost never use it on my G7.
  • Just figured it out. For other GX8 owners, using Photofunstudio to convert the mts files into MP4 files fixed the problem. Kind of a bummer since it's adds another step to the workflow.
  • Interesting discovery: the files play fine with Windows Media Player and MPC-HC, but in VLC and Sony Vegas, they show up as interlaced.
