Available at https://www.amazon.com/Sigma-693954-50-100mm-Standard-Canon/dp/B01C3SCKHW/
New firmware
Corrected the phenomenon that the AF performance occasionally becomes unstable when used via SIGMA MOUNT CONVERTER MC-11.
https://www.sigma-global.com/jp/download/lenses/sigma-optimization-pro/
New lens firmware
This firmware allows compatibility with Canon’s in-camera Lens Aberration Correction function to enable correction matching the optical characteristics of each lens. It also corrects the phenomenon that abnormal images appear or operation errors occur when the function is enabled. This firmware also corrects the phenomenon whereby the continuous shooting speed decreases in certain combinations with some cameras when used with the 14-24mm F2.8 DG HSM | Art for Canon, and the phenomenon whereby the AF speed occasionally becomes unstable when used with the 100-400mm F5-6.3 DG OS HSM | Contemporary for Canon.
For customers who own the SIGMA USB DOCK and applicable products listed below, please update the firmware via SIGMA Optimization Pro. Before updating the firmware using the SIGMA USB DOCK, please ensure to update SIGMA Optimization Pro to Ver. 1.4.1 or later for Windows, and Ver. 1.4.0 or later for Macintosh.
Applicable Products
- SIGMA 14mm F1.8 DG HSM | Art for CANON
- SIGMA 20mm F1.4 DG HSM | Art for CANON
- SIGMA 24mm F1.4 DG HSM | Art for CANON
- SIGMA 12-24mm F4 DG HSM | Art for CANON
- SIGMA 50-100mm F1.8 DC HSM | Art for CANON
Benefits of the Update
It has ensured compatibility with Canon’s in-camera Lens Aberration Correction function, which enables correction matching the optical characteristics of the attached lens.* It has corrected the phenomenon that abnormal images appear or operation errors occur when Canon’s in-camera Lens Aberration Correction function is enabled.
- Compatible Canon camera models:EOS-1DX mark II, EOS 5Ds, EOS 5Ds R, EOS 5D mark IV, EOS 6D mark II, EOS 80D, EOS 8000D(EOS Rebel T6s, EOS 760D), EOS 9000D(EOS 77D) , EOS Kiss x8i(EOS Rebel T6i, EOS 750D), EOS Kiss x9i(EOS Rebel T7i, EOS 800D), EOS Kiss x9(EOS Rebel SL2, EOS 200D)
Sharpness is good throughout the focal range and across apertures, and although you can see light fall-off at very wide apertures, it’s impressive at f/2.8 and narrower. Out of focus areas are rendered beautifully, while focusing is quick and accurate - and if you’re using manual focus very easy and swift too.
http://www.photographyblog.com/reviews/sigma_50_100mm_f1_8_dc_hsm_a_review/
That is the strangest test chart, I have ever seen!
GL Optics Conversion
We just got these lenses in where I work. Sigma have knocked it out of the park with the build quality. Is an absolute beast of a lens. Looking forward to buying myself one and testing out the optical quality of them
@Vitaliy_Kiselev Sorry, missed your update and edited my post :)
Check first post :-)
Wow, street price is coming in at $1,099.00... not bad at all.
Wow, just wow.
And it is affordable!
