Anybody used their XLR plugin with the Rode Reporter? I have found only 1 review/post about this combo and it says it doesn't work all that good
"The first mic I used for this test was the RØDE Reporter, a dynamic ENG (omnidirectional) mic, with phantom power deactivated on both transmitters. Both transmitters were set to 0dB attenuation. The Sennheiser G3 had a very strong output and no adjustment was necessary from use with the lav and beltpack transmitter. The Sony, however, was weak and noisy and thin. I had to crank the input gain on the MixPre-D to almost-wide-open, about 95%, to get the signal to meter at 0dB and this resulted in a greater noise floor. Just to be sure, I made the same comparison with a couple other dynamic mics and got the same results. The Sony plug-on transmitter is, essentially, useless with dynamic mics."
I can't test it out before buying (and can't return it when I buy it) so I'd like to hear some more opinions about this combo...
anybody? :)
Sony XLR plugin is shit according to reviews. I mean its analog part.
May be it will work ok with some very sensitive mike.
So, is it really good system?
It is good enough.
Also note that it has unique option to eliminate cables for Sony cameras
http://www.amazon.com/Sony-SMADP3-MI-Shoe-Adapter/dp/B013WW8ANQ
Saramonic UwMic10 is an impressively similar clone, if you squint they look identical! :-o
https://www.cinema5d.com/new-saramonic-uwmic10-wireless-microphone-range/ http://www.amazon.com/Saramonic-96-Channel-Wireless-Microphone-Transmitter/dp/B01AYDN004
Except it costs only a mere $270!
New stereo receiver
The URX-P03D 2-channel portable receiver forms part of a complete UWP-D audio system offering the sound quality of digital audio processing combined with the reliability of analogue FM modulation. The URX-P03D offers wide frequency coverage with up to 72 MHz bandwidth (depending on region) across a wide range of channels, with a choice of models to choose from. Easy-to-use features include a large display and small size to fit neatly on any size camcorder or DSLR camera, automatic channel setting function, headphone output, USB connection for power supply and line input availability. The receiver also has external mic input for an additional wired microphone and 3 channel mixer function.
More about two channel receiver
We actually plan to move to this Sony system to all exhibitions coverage sound.
Today special deal for D11 at $399 only
I got a few more people to join the Sony camp thanks to that sale :-D
Updates coming
With a new compact and lightweight design, the latest UWP-D wireless microphone series offer NFC sync for easy and fast channel setting and supports a Multi-Interface Shoe™ (MI shoe) with Digital Audio Interface that achieves high-quality sound with low noise for Sony's PXW-Z280 and PXW-Z190 XDCAM camcorders. The new UWP-D series provides advanced integration with the camcorders for enhanced usability.
                  Feels like a FS7 mk2 announcement, but for Sony audio.
Not quite as small as the FS5 mk2 was.... but still, not much of a step forward? Maybe the reviews will reveal it is a bigger deal than I feel it is. Sony isn't doing a great job at selling me on this, even though I'm a big big fan of their UWP-D11!
Their thing is that it will be tightly integrated with cameras. So you can see info in viewfinder or on the screen if connected via Sony hotshoe.
Unless they release a firmware update for their very popular FS5/FS7 and other cameras (their mirrorless perhaps?) then it is no good only being in a feature in a couple of new cameras.
Most probably they will :-)
Old one on sale
Sony UWP-D11 Camera-Mount Wireless Omni Lavalier Microphone System for $399
New video out Sony's pro digital wireless (much higher end than their prosumer UWP-D range):
