Leant my camera to someone and now when I turn the shutter speed wheel it changes in decimal places i.e 50, 49.4, 49.8, anybody know what I need to change back in the menu? Thank you.
@caveport Thanks. Funnily enough I realised it today when I used synchro scan again and found the same thing.
my apologies for incorrect info. It is Synchro Scan mode designed to reduce lighting flicker.
Interesting. Never seen it before. Merci.
It is variable framerate mode. The manual tells you everything about it.
Bizarre it was.
@Vesku I have now! That did the trick thank you.
50, 49.4, 49.8 sounds very odd. Have you made default reset?
Thanks but nope, not it.
Sounds like it's in shutter angle mode instead of shutter speed. You can switch it back somewhere in the menus.
