Here is something I am doing out of the kindness of my heart.
Osiris LUT's, the world's best base grades... Take this setting into Davinci Resolve 12, apply this LUT (See link...) and enjoy instant "higher-dynamic range" LOG footage that rivals the Arri image (almost!)
https://www.dropbox.com/s/zw104esm5ctwtlq/KDX%20-%20LOG.cube?dl=0
There is only one file here, not all of them, so I am not robbing the parent company of their sales, but I just happen to be sharing the best one of the lot! Buy all of them if you like this one! There is a lot of variation...
Yes, it is a .cube file, NOT a virus filled .exe file... I am putting my word and reputation on the line here that it is a safe file... You have to know how to use it though!
Post your graded shots here with the results of the epic Panasonic fail in the implementation of the V-Log settings! Enjoy,
gammaLite is my gamma-encoded color space for color correction of GH4 footage in Adobe Premiere. I also have a log-encoded color space for DaVinci Resolve, FCPX, and Sony Vegas Pro.
@aaronchicago, thanks!
For anyone, what is GammaLite @Gardner mentioned above?
@aaronchicago, that video is badass. The GH4 shine there very well. Great work, thanks for sharing.
@balazer Thank you for answering my questions and I look forward to using your LUT for my projects next year!
@Gardner, a typical display LUT is designed for footage shot with a certain exposure and proper white balance. Those LUTs don't facilitate basic color correction. My LUTs are designed to enable white balance correction, exposure compensation, and contrast adjustment in the intermediate color space. That's the main difference. Beyond that I can't say much about the Leeming LUT because I haven't tried it. I'm sure it's fine. It's just a very different approach.
@balazer Thank you. One more question -- How would you compare your LUT to the Leeming LUT?
@Gardner, sharpness and noise reduction settings are totally up to you, since they have no effect on color. Some GH4 users may have a recommendation.
@balazer What settings would you recommend for Sharpness and NR for GammaLite in Camera?
@Tjabo @Iban_Corominas Thanks! I shot the rooftop stuff with C100 MkII. The car slow motion shots were 60fps slowed 40% to 24p.
@aaronchicago Great work! It looks fantastic, did you use 48fps on the car shot??
@aaronchicago, I think you nailed that!! Phenomenal shooting and editing. Not to mention, the GH4 seems to do what looks to me like a really professional job now. Of course it't not perfect, but what is.
What did you use to shoot the rooftop stuff, A7s?
New video that I shot primarily with V Log L. Everything except the rooftop shots are the GH4.
Yep, saw that one, didn't help much. But it is interesting how you're not really losing anything pumping the ISO.
@belfryman you are right, but here the focus of the video is to show that a lot of people avoid high ISO and end up under exposing which is often worse (for noise) than raising ISO.
There is some additional discussion on the blog, regarding the banding, which can be "minimised" by adding a small amount (5%) of Film Convert grain (not used on this footage).
I'm seeing stacks of banding on the wall myself, fine if you just look at the woman's face. Is that just me?
Thanks for that! Good video, and that guy has some other good stuff too.
Some interesting discussion on the creator's blog:
http://www.60fotogramas.com/gh4-mejor-configuracion-en-v-log-y-una-alternativa-el-leeming-lut/
google translate gives a good translation.
https://en.wikipedia.org/wiki/Shot_noise
At low ISO settings, shot noise dominates over sensor readout noise.
I'm not sure what 'shot noise' is. Nearly all noise is the inherent sensor noise and maximising the amount of light hitting the sensor will ensure that the signal to noise ratio is maximised. In electronic cameras, ISO is an electronic gain (after the sensor) which will increase the signal AND the residual sensor noise. Most cameras have built in noise reduction which is optimised for that particular camera. Using gain adjustment in post production will lift the noise as well as the signal, but without the manufacturers noise reduction. This is usually a noisier result than using an appropriate ISO and optimum exposure in camera. Under-exposing and lifting gain in post, is usually the noisiest option and does not increase dynamic range. The best dynamic range is with optimum exposure.
With the GH4 I find the best (lowest noise) results are by using an appropriate ISO for the available light conditions and exposing to maintain clean highlights. Also being careful with white balance is important to noise visibility due to the 8bit 4:2:0 H264 codec. The colour channels are fairly low resolution and if the white balance is pushed a lot in post-production, the image can start getting VERY noisey.
I think the lesson is to get as much light as possible to sensor to have less "shot noise". If the "shot noise" is always the same why not underexpose with low iso and get better dynamic range.
In practice we must increase iso because we have not enough light to use low iso. Then we have more noise. If we overexpose heavily high iso we get less noise but loose highlight detail. Is it a compromise between noise/dynamic range. If I under expose at iso 200 and adjust image to normal I get good dyn range but more noise in shadows. It is like using iso200 for highlights and iso1600 for shadows at the same time.
@Tjabo, sorry, I should have explained how that video was created. I asked Mckinise to shoot it for me, holding the exposure constant while ramping the ISO from 400 to 6400 in third stop intervals. In the YouTube video I ran his ramp twice. In the first time, the bottom half is V-Log L without any transformation, and the top half has exposure compensation applied to compensate for the changing ISO setting, and Rec.709 rendering. The second time is just like the top half of the first time. The noise is most apparent in the dark area above the keyboard. What I wanted you to see is how the noise is virtually unchanged (when exposure compensation is applied) even as the ISO is changed from 400 to 6400. YouTube has turned that noise from grain into overcompressed mush, but that doesn't alter the conclusion: the ISO setting has very little impact on the noise. It's a counter-intuitive conclusion. All our experience has taught us that ISO 6400 must have a lot more noise than ISO 400. But it's only because when you increase the ISO setting, you're usually doing it to compensate for a low exposure. A low exposure is the source of most of the noise, not the higher ISO setting. When you hold the exposure constant, increasing the ISO setting doesn't increase the noise much at all. (at least not until you get to really high ISO settings, and then sensor noise starts to be a bigger factor) It's because shot noise is the largest contributor to overall noise at low and medium ISO settings. Shot noise is inherent to the light of the image falling on the sensor. (and compounded by the sensor's fill factor, quantum efficiency, and colored filter losses) Changing camera settings doesn't change the shot noise. Changing the exposure (shutter speed, aperture, lighting) does change the shot noise.
