GH4 cinema 4K mode non-existent!
  • I bought a 6 month old used GH4 today. For some strange reason when i switch to the 24hz cinema mode, I get no Cinema 4K or any 4K option!! All i get is the Fulll HD 24fps mode. Also, the AVCHD and MP4 options are greyed out in this mode and i only get the MP4(Lpcm) and MOV modes to select from. I am using fast cards so that is not an issue. I am in Movie Mode. Also, its the same story in MOV (No 4K or C4K option). Does someone know what is happening here?
  • 2 Replies sorted by
  • Did a Reset and it worked. Maybe previous owner settings.
  • Maybe the variable frame rate was on and set to a non standard frame rate.
