TASCAM Hi-Res Editor
    Features:
    • Native DSD audio editing and playback, at sampling rates from 2.8MHz to 11.2MHz
    • WAV file editing and playback support up to 384kHz/32-bit
    • Uses standard ASIO 2.1 audio drivers
    • Set in and out points with waveform audio display for trim/export
    • Set overall gain of file (PCM files only)
    • Split long files into multiple tracks
    • Combine function joins two audio files into one
    • Convert audio files from DSD to PCM or vice-versa
    • Convert PCM sampling frequency and bit depth
    • Runs on Windows (using Windows Standard audio driver or ASIO 2.1)
    http://tascam.com/product/hi-res_editor/images/
  • 5 Replies sorted by
  • I have some in the garage, but I rarely use them, certainly not any stereo devices.
  • @DrDave you would have a audio interface of some sort right? (USB2-USB3-Firewire-Thunderbolt-PCI)
  • I don't get it, but, thankfully, I guess it's "need to know" basis. It just looks like one of those big heavy boxes I got rid of years ago.
  • @DrDave this software is intended to allow DSD playback through DSD mastering and playback boxes, such as the Tascam DA-3000
    The software will be released for Mac as well soon.
  • Am I missing something, or is this a box that does less than software?
